Slow 1200 Samba Member
Posted: Mon Mar 18, 2013 3:00 pm Post subject: Zero compression on #2! |
title says it all, tested compression and cyl. 2 came at 0! I recently adjusted the valves so if they are tight I guess I have a stretching valve or a dropped seat.
In any case the plug on that cylinder was oily so it sounds more like rings (or worse )
engine only has 50.000km on it but it sat for a long time, so maybe that cylinder rusted and got scored when it was started...
strangely enough the car didn't run that bad |
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Mon Mar 18, 2013 3:21 pm Post subject: |
number of things.
burned exhaust valve.
dropped seat.
warped head/loose studs and not sealing.
melted piston.
collapsed ring land on piston.
Bent valve/stuck valve.
Glazed bores.
Broken rings.
Stuck rings.
and probably more things but are unlikely so I wont list them.
in bold is what it likely to be given the history of your engine from the other thread. |
Posted: Mon Mar 18, 2013 11:56 pm Post subject: |
yup those are basically all the alternatives, today I'll pop the rocker cover to see what's in there, I adjusted the valves not that long ago so if there's a tight valve it's probably stretching (or the seat is going away) |
Posted: Sat Mar 23, 2013 8:17 am Post subject: |
ok so there's nothing out of the ordinary in the rocker area, valve clearances are fine, nothing broken, no valve sinking or sticking out...so I think I have a burnt valve (and it's been burnt all along) and/or broken ring(s)
I guess it's time to pull the engine and take it apart |
supaninja Samba Member
Posted: Sun Mar 24, 2013 2:10 am Post subject: |
since I don't have a proper space to work (car is in a shared parking space) pulling the engine there is out of the question, so I'm actually considering just pulling the right head on the spot, not the greatest idea I know |
vdubin Samba Member
Joined: September 09, 2006 Posts: 305 Location: Huntsville, Al
Posted: Sun Mar 24, 2013 4:11 am Post subject: |
if all you need to do is a top end rebuild, that takes just a few hours. with a jack and stands you can pull it and rebuild right there. I had to do it in my apt parking lot one time. I was almost done when a cop came and hassled me, but with no leaks or mess and I was in my parking spot only he left me. I would get a p/c set just to be safe or pull the motor and pop the head, asses the damage, bag the motor, reinstal and get your parts. next weekend rebuild. a tip... check your gland nut while you are at it. the needle bearing wears and is often ignored. |
Posted: Mon Apr 01, 2013 11:03 am Post subject: |
images are worth a thousand words
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22697 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Apr 01, 2013 1:41 pm Post subject: |
supaninja wrote: |
The smoking gun...sweet! Now put a new head on it drive that thing. |
Why? If the head's not cracked and the seat looks OK, lap another valve in, do the brake fluid test*, and slap it back on, Slappy.
*Fill your exhaust or intake port with brake fluid. Let it sit for half an hour. No brake fluid through the valve is perfect, a little bit weeping through is acceptable, but if it disappears through the valve, it's not seating. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vlad01 Samba Member
Posted: Mon Apr 01, 2013 4:58 pm Post subject: |
Tram wrote: |
supaninja wrote: |
*Fill your exhaust or intake port with brake fluid. Let it sit for half an hour. No brake fluid through the valve is perfect, a little bit weeping through is acceptable, but if it disappears through the valve, it's not seating. |
with temps that thing reached, it is well and truly toast.
the metallurgy of the head is now useless.
replace the head.
you can see in the pics that head it warped like a banana (evidence of not sealing evenly) |
Posted: Mon Apr 01, 2013 5:28 pm Post subject: |
vlad01 wrote: |
Tram wrote: |
supaninja wrote: |
replace the head.
Bryan67 wrote: |
vlad01 Samba Member
Posted: Mon Apr 01, 2013 5:36 pm Post subject: |
Tram wrote: |
vlad01 wrote: |
Tram wrote: |
supaninja wrote: |
replace the head.
Posted: Mon Apr 01, 2013 5:42 pm Post subject: |
vlad01 wrote: |
Tram wrote: |
vlad01 wrote: |
Tram wrote: |
supaninja wrote: |
replace the head.
Vlad, you can't see shit in that photo as far as "warping", and I'm really beginning to doubt that you have any actual hands- on experience in serious VW wrenching. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vlad01 Samba Member
Posted: Mon Apr 01, 2013 6:01 pm Post subject: |
Tram wrote: |
vlad01 wrote: |
Tram wrote: |
vlad01 wrote: |
Tram wrote: |
supaninja wrote: |
replace the head.
Vlad, you can't see shit in that photo as far as "warping", and I'm really beginning to doubt that you have any actual hands- on experience in serious VW wrenching. |
I can guarantee that will be warped to some extent and much weakened. Yes the photo its great but you can still see how bad that head is.
why when new heads are available would you attempt to repair a burned out 40+ year old crusty of head? that makes no sense when the costing of repairs run with what head/s would cost brand new.
only time I would fix an old head it when they NLA and even then I would go source few 2nd ones to choose the best for reconditioning.
I seriously doubt you consider all accepts of what you are looking at when you look at it.
yes? the photo you can't tell much? so how is it look repairable to you when you can't even tell what fabric texture you are looking at on your monitor |
Posted: Mon Apr 01, 2013 6:31 pm Post subject: |
vlad01 wrote: |
Tram wrote: |
vlad01 wrote: |
Tram wrote: |
vlad01 wrote: |
Tram wrote: |
supaninja wrote: |
replace the head.
35+ years of experience in dealing with this stuff. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vlad01 Samba Member
Posted: Mon Apr 01, 2013 6:38 pm Post subject: |
Tram wrote: |
vlad01 wrote: |
Tram wrote: |
vlad01 wrote: |
Tram wrote: |
vlad01 wrote: |
Tram wrote: |
supaninja wrote: |
replace the head.
35+ years of experience in dealing with this stuff. |
35+ of stubbornness. times change, nothing ever stays the same.
no point arguing will you anymore. I am finish waiting my time. |
Posted: Mon Apr 01, 2013 6:40 pm Post subject: |
vlad01 wrote: |
Tram wrote: |
vlad01 wrote: |
Tram wrote: |
vlad01 wrote: |
Tram wrote: |
vlad01 wrote: |
Tram wrote: |
supaninja wrote: |
replace the head.
How does changing times affect the laws of physics, pray tell?
I think all of your time is a waste sometimes. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Apr 01, 2013 11:42 pm Post subject: |
the seat doesn't look good (that's my x-ray vision at work of course), but anyway I'll take it to the machine shop and we'll see what they say
I'd rather keep the 311 heads
and anyway if I replace one head I'd have to buy two so they're matching...not that cheap if you ask me |
