65VW69Stang Samba Member
Joined: June 22, 2012 Posts: 16 Location: Rapid City South Dakota
Posted: Tue Apr 02, 2013 7:51 pm Post subject: Trans help |
Have a 65 bus rgbs and would like to remove rgbs and keep trans, is this possible. |
joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
Posted: Tue Apr 02, 2013 8:40 pm Post subject: |
I want to lower this bus just minor, not a lot, basically want to keep good ride ditch the rgbs so it is hi way drivable. |
Posted: Tue Apr 02, 2013 8:47 pm Post subject: |
This is the height I would like on budget.
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Tue Apr 02, 2013 9:06 pm Post subject: |
Removing RGBs is automatic 3-1/2" drop. You should sell your trans and RGBs drum to drum and go get yourself a beetle trans and straight axle kit if that's what you're after. Your trans turns the wrong direction for removal of the RGBs--you'd have to pull it apart, flip the diff, reset the backlash using tools you don't have etc.
Go to the lowering thread and follow along until you get it.
You don't need to lower the bus to get different highway gear ratios. What is your first priority--lower ride height or lower freeway RPMs? |
Posted: Tue Apr 02, 2013 9:29 pm Post subject: |
Both are priority. Just on budget doing it. |
Posted: Tue Apr 02, 2013 10:19 pm Post subject: |
Okay, well since you want to talk about lowering, there is already a mega-thread for it where the rest of your questions belong.
http://www.thesamba.com/vw/forum/viewtopic.php?t=66927
From there, you should be able to cost out your project. Just understand that you will be money ahead selling what you have as a complete assembly and starting with a late 60s beetle or type 3 trans and using varying mixes of parts to get the final gear ratio and brakes you want/can afford. It's also easier to do it that way unless you own the specialized tools necessary to set the tolerances when reassembling your differential in the other side of your trans case.
Good luck with your project! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69820 Location: Phoenix Metro
