Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Sat Apr 06, 2013 4:14 pm Post subject: Leaking Oil Filler |
what is causing my oil filler to leak? It is dripping onto the manifold - I checked the oil filler cap - rubber gasket is still plyable and it seems to close properly. I have the stock oil bath air filter.
I doubt the picture provides any clues, but here it is (and before you comment - I did have the hose and the cap on it!)
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Sat Apr 06, 2013 7:18 pm Post subject: |
Nut inside holding it on not tight or a rust hole at the bottom were water would lay. |
Posted: Sat Apr 06, 2013 9:35 pm Post subject: |
Ron - thanks for the reply. I didn't know there was a nut inside that filler...can't see one. Been reading about "blow by" on the samba. Excessive crankcase pressure? |
Posted: Sat Apr 06, 2013 10:00 pm Post subject: |
There is a big hollow nut that holds the filler to the tower, it takes a special tool to loosen and tighten. There is also a gasket between the filler and tower that dies with age.
Yes too much crankcase pressure will cause leaks. |
Posted: Sun Apr 07, 2013 2:23 pm Post subject: |
thanks Wildthings. I ordered one from jbugs. Here is a picture of the oil filler removal tool - for anyone needing the info in the future. |
NY thing Samba Member
Joined: March 23, 2010 Posts: 100 Location: Queens New York
Posted: Sun Apr 07, 2013 5:50 pm Post subject: |
Mine does the same thing sometimes. I THINK my filler has a whole in the underside. It does it when I pour oil in it too fast too. |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Tue Apr 09, 2013 8:26 pm Post subject: |
look on the bottom if your oil fillerif it looks like this this is your leak you can even see where someone tried to weld this one up those are holes caused by the water in the oil
OVLWNDO Samba Member
Joined: June 09, 2005 Posts: 225 Location: San Mateo, CA
Posted: Wed Apr 10, 2013 8:22 pm Post subject: |
FYI you can use an internal pipe wrench to R&R the oil filler securing nut.
You can pick these up at just about any hardware store.
