VTAthing Samba Member
Joined: September 03, 2004 Posts: 23 Location: Ventura Ca.
Posted: Sun Jan 30, 2005 10:03 am Post subject: Thing seatbelt bolt size..? |
Hello, I was wondering if anyone would know the size (im guessing in MM?) of the bolt that goes into the seat belt holes on my thing as well as the length ? Im putting in new seat belts and need to but the correct bolt size.....Thanks for your time Dave |
germansupplyscott Samba Member
Posted: Sun Jan 30, 2005 11:28 am Post subject: |
m10 x 1.0, it is fine thread. seatbelt fasteners are also very hard, usually grade 10.9 or better. i think it is about 26mm long. _________________ SL |
Vw4x4 Samba Member
Joined: May 18, 2004 Posts: 211 Location: SUNNY CALIFORNIA
Posted: Sun Jan 30, 2005 12:04 pm Post subject: |
Dave,
Usually when you buy new seat belts, they come with their own hardware, bolts, washers,etc. The info that Scott is pretty acurated. |
kubelmann Samba Member
Posted: Sun Jan 30, 2005 4:07 pm Post subject: |
The original Seat belt bolts have the thread as Scott said but they also have a larger smooth shaft that allows the seat belt to rotate. They are a very hrad bolt ( grade 10+) that will be nearly impossible to replace other than the original part. I would contact Mike Basso at Things Unlimited as he will sell you the correct parts for a fair price. If he is unable to help you I have some spare seat belt bolts that will solve your problem. I highly reccomend you use only the actual part. K-mann |
Posted: Tue Feb 01, 2005 6:45 pm Post subject: |
Thanks everyone for the info On the parts.... |
