Lifted Van, Cargo Space Below
syncrodoka
syncrodoka is online now
PostPosted: Wed Apr 17, 2013 2:25 pm    Post subject: Reply with quote
Bntbrl wrote:
Thycol comes in various sizes, even if that doesn't work a tube of seam sealer, even cookie dough bag would seal it. Those sealers are already in use throughout the rest of the bus. The seam sealer would be harder to remove if you wanted to take the box back off but not sure why you'd need to really.
You don't have to believe me if you don't want to but it isn't speculation. That is what i have been told by someone that has had one of these installed for years and has had issues sealing it from dust ingress.
He is very capable and i believe him.
Team WorldTour
Team WorldTour is offline
PostPosted: Wed Apr 17, 2013 2:45 pm    Post subject: Reply with quote
I think, just as an homage' to the rear engine hatch, make a lid that looks and latches in a similar manner.
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
Syncronoid
Syncronoid is offline
PostPosted: Wed Apr 17, 2013 4:06 pm    Post subject: Reply with quote
The box itself if 12 gauge steel, well thicker than what was cut out. The box is bolted with 6 bolts into the reinforced edges, not just the thin, corrugated sheet metal that was cut out. The combination of the 12 gauge steel, 6 bolts and reinforced edges more than makes up for what was cut out. I will post pictures shortly.
p.s. I can stand in the box and jump up and down without the bottom flexing. It is very bomber and well secured to the frame.
PDXWesty wrote:
Maybe it's just me, but after looking at those pictures, doesn't it seem like you're taking a lot of the structural inegrity out of the van floor? You're cutting a long slot perpendicular to the ribbing of the sheet metal that spans between the frame rails. Will you lose stiffness in the unibody? I liked it at first but now it looks kind of odd seeing a big hole there.
'90 Syncro Westy w/GW2.5L
danfromsyr
danfromsyr is offline
PostPosted: Wed Apr 17, 2013 4:20 pm    Post subject: Reply with quote
don't look too close then at the floor in the Reimo hightop vanagon campers.
they cut out the center flooring to put ina recessed shower pan.
the vanagon isn't a true unibody, as it's unibody on frame.. there's still the 2 large box beams (not C-frames like other/older trucks).
it'll be fine.. Wink
Abscate wrote:
Syncronoid
PostPosted: Wed Apr 17, 2013 4:40 pm    Post subject: Reply with quote
Here's the progress I made today, mostly getting things sealed, final bolt selection and getting the temporary cover cut to fit (still need my sander from my neighbor to dial in the edges).
Cut the two existing bolts out as they were slightly corroded and did not allow enough space between it and the side of the box to fit a nut over.
Silicone injected into openings to seal out dust and moisture.
Rear and front rubber insulation strip to seal the rear of the box where, as a result of the cross cut, left a 1/4 inch gap between the flange and floor.
...front....
Bolt connection. 6 in all.....
Rubber pad cut to fit...
Now just waiting for my neighbor to return my sander so I can finish the temporary wood cover...
[/url]
syncrodoka
PostPosted: Wed Apr 17, 2013 5:14 pm    Post subject: Reply with quote
The rubber pad at the bottom is a nice touch.
Syncronoid
PostPosted: Wed Apr 17, 2013 5:16 pm    Post subject: Reply with quote
Don't want stuff rattling around on that steel floor.
syncrodoka
PostPosted: Wed Apr 17, 2013 5:23 pm    Post subject: Reply with quote
I concur.
I am gonna use the container for recovery items or things that go boom at the range so something on the bottom is a good idea.
Is it just some bulk type rubber carpeting stuff from the local hardware store?
Bntbrl
Bntbrl is offline
PostPosted: Wed Apr 17, 2013 5:42 pm    Post subject: Reply with quote
@SyncroDoka I believe you as I can easily see where it will be a source for leaks. I was just mulling over solutions. I don't have any idea how he sealed or built his (your friend SD) but I'd like to in order to have an idea about what's going on. I want to do this to mine and if I can figure out how to seal it without going in and out several times I'd be grateful.
1984 Vanagon Westfalia 1.9 wbx
www.DIYSeattle.com
Syncronoid
PostPosted: Wed Apr 17, 2013 7:32 pm    Post subject: Reply with quote
Some parting shots for this phase of the installation.....
Bomber temporary lid....
What smugglers compartment, officer???
Oh that! That's just my wife's ironing board.
Still plenty of clearence.
Syncronoid
PostPosted: Wed Apr 17, 2013 7:36 pm    Post subject: Reply with quote
syncrodoka wrote:
I concur.
Yep, from Home Depot's door mat department. Comes in a roll 4ft wide. $2.25/ft.
PDX_Guy
PDX_Guy is offline
PostPosted: Thu Apr 18, 2013 9:25 am    Post subject: Reply with quote
If you put a drain plug in it you could use it as a built in cooler for thirst quenching refreshments.
Love the idea and look. Going on my list of things I going to do when I get the time Smile
Certified VW Newbie
1986 Westfalia Syncro
Syncronoid
PostPosted: Thu Apr 18, 2013 9:35 am    Post subject: Reply with quote
Yep! Thought of that, but would best be accomplished with some spray-on insulation on the exterior.
purplepeopleeater
purplepeopleeater is offline
PostPosted: Thu Apr 18, 2013 9:36 am    Post subject: Reply with quote
a shower pan....Hmm.. Cool
73thingsale
73thingsale is offline
PostPosted: Thu Apr 18, 2013 10:31 am    Post subject: potential storage Reply with quote
Wonder if line-x or other product used for sealing would keep smells from emanating from within that box. Like if you put a sandwich in there and forgot about it for several days, would a dog notice it before a person? Hmmm. Or perhaps a green smoothie bottle, they can stink up a place pretty quick.
So if you went to Tijuana and the border guys run that mirror under the van, ya think they'll notice?
Dave
86 GL Hardtop Blue
purplepeopleeater
PostPosted: Thu Apr 18, 2013 10:34 am    Post subject: Re: potential storage Reply with quote
LOL, are you perhaps wanting to transport bails of certian items?
They'll find it and you'll end up with a cavity search.
Bntbrl
Bntbrl is offline
PostPosted: Thu Apr 18, 2013 10:48 am    Post subject: Reply with quote
Could use it for all sorts of uses. Potty tank, shower pan, storage.
www.DIYSeattle.com
purplepeopleeater
PostPosted: Thu Apr 18, 2013 10:52 am    Post subject: Reply with quote
mostly I'm thinking floor safe, tools.
r39o
Samba Polizei
r39o is offline
PostPosted: Thu Apr 18, 2013 12:13 pm    Post subject: Re: potential storage Reply with quote
You are trying to make a funny, aren't you?
Remember we are very touchy about some topics........
BTW: I like this a lot too, but won't work on my van as there is a propane tank there and the other side a water tank. And where to put that extra AC condenser?????
73thingsale
PostPosted: Thu Apr 18, 2013 12:33 pm    Post subject: You caught me Reply with quote
I was being a little covertly overt. Smile
Not to highjack a thread, but just a short aside...
I have read many posts about how people get hassled driving these old vans. I just recently tinted my windows really dark, and I get some apprehensive looks now. I pulled over into some shade yesterday to take a call from work that I knew would last several minutes, so I wanted to be out of the sun. Turns out the closest shady spot was a parking lot at an apartment complex. I kept seeing the curtains move in two of the windows in the building across from me while I talked on the phone. Then I left without ever getting out of the car. Reckon I'll be on a watch list or something now.
Plenty of things you could store in a space such as described in this thread. I was just thinking back to a thread I had read about someone who had the dogs sniff out an old roach in a van they had just recently acquired, I think crossing into or back from Canada. Tough to explain something like that, I suppose.
Dave
86 GL Hardtop Blue
Page 5 of 8
