Installing 2.5" Drop Spindles On A '64 Bug With Drums
BGLOCOTE
BGLOCOTE is offline
PostPosted: Wed May 25, 2011 8:06 pm    Post subject: Reply with quote
I spoke with the local bug shop and with the cost of the spindals and the labor to reinstall my bushings and link pins it was about the same price as having adjusters installed on my stock beam so which way should I go?
1955 TYPE 1 Under Construction
1962 TYPE 1 SOLD
Looking for 54-55 TYPE 1 finger tin.
UNITED STATES SUBMARINE VETERAN
BGLOCOTE
BGLOCOTE is offline
PostPosted: Thu May 26, 2011 7:14 pm    Post subject: Reply with quote
Anyone have any ideas?
1962 TYPE 1 SOLD
tb03830
tb03830 is offline
PostPosted: Fri May 27, 2011 8:18 am    Post subject: Reply with quote
My suggestion is to go with spindles. They reproduce the stock ride with shocks and are a little heavier duty than the origionals. Mine work great.
I also have adjusters but do not use them for now. All kinds of other things to consider with adjusters like new shocks, Wedges, bumpier ride and you always find things wrong.
"Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower.
BGLOCOTE
BGLOCOTE is offline
PostPosted: Fri May 27, 2011 9:50 am    Post subject: Reply with quote
Thanks for the advice. I will probably go that route. I just thought it would be cool to be able to adjust the ride height.
1962 TYPE 1 SOLD
s1b
s1b is offline
PostPosted: Fri May 27, 2011 11:21 am    Post subject: Reply with quote
Will the tires rub with a stock width beam and drop spindles?
Joey
Joey is offline
PostPosted: Fri May 27, 2011 2:07 pm    Post subject: Reply with quote
Stock size tires (165R15) on stock rims will rub when cornering with dropped spindles. Even with 145R15 tires you'll still get a bit of rubbing... at least I did on my '65.
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
Tin Badge
Tin Badge is offline
PostPosted: Mon Sep 12, 2011 5:27 pm    Post subject: Reply with quote
Thanks for the post this helped a lot in doing mine. Very Happy Also I was not as brave and bought mine off widefive.net already done they were just plug and play but the other info you posted as far as removal and such helped greatly. Thanks again.
mykidsbug
mykidsbug is offline
PostPosted: Tue Sep 13, 2011 3:58 pm    Post subject: Reply with quote
I wonder if you can get a front Beam with the adjuster and lower a bug 2.5.. also if you can use regular tires. my 135's are hard to get..
Tin Badge
PostPosted: Tue Sep 13, 2011 11:16 pm    Post subject: Reply with quote
You might look here in these two threads they help me along a lot as well as this one.Good luck with your project.
http://www.thesamba.com/vw/forum/viewtopic.php?t=143094&start=0
http://www.thesamba.com/vw/forum/viewtopic.php?t=247735&start=0
jims65
jims65 is offline
PostPosted: Tue Mar 06, 2012 4:48 pm    Post subject: Reply with quote
Hey guys sorry for bringing up an old thread but I was wondering if running dropped spindles on a stock width beam would rub. When i bought the car it had some torsion bars pulled so its not stock height. I have empi 5 spokes and 135's in the front .
Tin Badge
PostPosted: Mon Mar 12, 2012 11:56 pm    Post subject: Reply with quote
They might with some of the torsion bars pulled. You would just have to try it and find out in my opinion. And if it dose then start adding the bars till you get what your striving for. Mine is a stock frontend and just drop spindles and I am running 145's and have not had any rubbing issues even with a front passenger. Both of us 220 each. Good Luck!
gitchesum
gitchesum is offline
PostPosted: Mon Jul 30, 2012 8:22 am    Post subject: Reply with quote
Jean Michel wrote:
I just want to say that for those wanting to do this modification to their bug and want to fit the Porsche 356 brakes, that it can be done with the early 356 A Brakes only (small modification to the spindle or backing plate required) Dropped Spindles will not work with 356 B brakes as the backing plates for these are very diffrent to the 356 A brakes, which are diffrent again to the early 356 A Brakes! The B brakes are 1 cm larger in diameter to the A brakes and drums and backing plates can not be interchanged!
Not sure about that at all....I took my CB spindles to my extra set of 356B brakes, the front fits fine on the backing plate...I do have to figure out the bearing issue however. The Porsche bearing has a bigger ID than the VW bearing. Hoping I can put VW bearings in the Porsche drum.
My bug now has 356B brakes on it already, just don't remember what I did about the bearings..plus I'm putting a 4 in/2 1/2 spindles/BRM's on it this time around.
Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go...
topgun13b
topgun13b is offline
PostPosted: Sat Oct 06, 2012 8:11 pm    Post subject: 1960 vw beetle Spindl Reply with quote
I need your advice Very Happy I got my 1960 bug, and its already lowered and the beam shorted. I would like to rise it up a little bit from the front because its very low and diffecult to put it on the trailer. Could I loose the spindl and take off the two arms that connected to the spindel and the the beem, then move the two arms one step down, and then connect the spindel again? is that going to risa the car a little bit? and is it going to work?
Vintagespeed
Vintagespeed is offline
PostPosted: Fri Jan 18, 2013 5:04 pm    Post subject: Re: UPDATE Reply with quote
Focker wrote:
bugdozer wrote:
...Do you have any rubbing after installing the spindles?
Yesterday I decided to lower the rear one notch (outer spline) just to level the bug. It's a simple task unless your E-Brake cable is short like mine...PITA. Some guys I know had longer cables which allowed them to swing the rear drum back and out of the way.
I think I accomplished the goal of leveling but what I didn't expect is that the rubbing up front was cut down to less than half (In my experience). I zipped around some of the same corners that I had rubbing issues and it was a lot less noticeable. If I end up running 145's up front (165's currently) it should be even less. My concern is that the "Rake" from the smaller tire diameter will cause the tires to rub again since they will be up inside the fender more.
I'm sure there is some kind of Physics involved that explains the whole thing...Obviously I'm no Biologist. Laughing
Here is a new comparison shot...Starting with the lowered front.
Here is after the rear was completed...Yes I drove around and let everything settle.
did you get those 145s on? A little rake was great, and should be back with smaler front tires.
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
netsniper
netsniper is offline
PostPosted: Sat Apr 20, 2013 1:27 pm    Post subject: Reply with quote
Just been looking at some dropped spindles for the front of my bug and I'm a bit confused???? How do I know if I need a Link pin set or ball joint set???
http://www.limebug.net/product/view/1630/t1-beetle...-joint-559
http://www.limebug.net/product/view/1755/t1-beetle...nk-pin-357
All though my bug is a 66 its been made up of all sorts of parts including 4 stud hubs
This pic might help ??
[/img]
Miklo
¡Chale!
Miklo is offline
PostPosted: Sat Apr 20, 2013 2:31 pm    Post subject: Reply with quote
You'll need a pair of ball joint spindles netsniper.
Miklo
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote:
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche...
netsniper
PostPosted: Sat Apr 20, 2013 3:18 pm    Post subject: Reply with quote
Thank you
netsniper
PostPosted: Fri May 03, 2013 3:59 am    Post subject: Reply with quote
What tools do I need to fit spindles on my bug
slaphappytrav
slaphappytrav is offline
PostPosted: Fri Apr 04, 2014 8:17 pm    Post subject: Reply with quote
11 month old thread, but I started this project tonight!
netsniper
PostPosted: Sat Apr 05, 2014 1:15 am    Post subject: Reply with quote
I've done mine now and it was very easy.
Page 3 of 4
