Need a GOOD Ignition Switch
1967250s
1967250s is offline
PostPosted: Tue Apr 23, 2013 7:49 pm    Post subject: Need a GOOD Ignition Switch Reply with quote
Ok, 72 Deluxe, need a good ignition switch, do not want cheap chinese fire starter, who has the best? Will an earlier switch with metal housing like the '70 switch at autohauz work? I had a metal one originally and it finally wore out after +400K, tried the one available and promptly had a dash smoking while driving. The plastic ones don't fit and work properly, and I've already worn out 3!! Did a search and I get 40 pages of hits. HELP, PLEASE!
I am an electronics tech, so I know what I'm doing, but finding this is pissing me off.
germansupplyscott
germansupplyscott is offline
PostPosted: Tue Apr 23, 2013 7:53 pm    Post subject: Reply with quote
the new production 111 905 865 F switches are marginal quality. there is nothing new being made - that i am aware of - that is really good. NOS german obviously good, but to find them is nearly impossible. there isn't one brand that's better than another, most likely anything that's new production, from any vendor, is all the same. i don't think the 311 905 865 A/B switch will work, even if they fit they are not any better i don't think.
SL
420GOAT
Location: Wilmington, CA on a nice quiet street but still in the 'hood
420GOAT is offline
PostPosted: Tue Apr 23, 2013 8:38 pm    Post subject: Reply with quote
try to at least get a Brazilian one.
once you realize im not impressed we will get along just fine
tootype2crazy
tootype2crazy is offline
PostPosted: Tue Apr 23, 2013 9:49 pm    Post subject: Reply with quote
I had tons of trouble with cheapo switches until I managed to find a NOS item. Hopefully it will last another 30 years as the original one did.
air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's)
westcoastmarek
westcoastmarek is offline
PostPosted: Tue Apr 23, 2013 10:02 pm    Post subject: Reply with quote
why not a used one from your local wrecker?
1979 Westy Auto
sold...
1979 VW bus, 2L FI, now with a rivi top
1971 7 pass. deluxe
1974 Beetle
fusername
fusername is offline
PostPosted: Wed Apr 24, 2013 5:27 am    Post subject: Reply with quote
I got a new switch, after burning thru three of em just cut the wire for the starter and ran it to a push button under the dash. there is no good new switch. but only the start position kept burning out on mine, so i removed it.
[email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote:
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine!
stevespeirs
stevespeirs is offline
PostPosted: Wed Apr 24, 2013 6:00 am    Post subject: Reply with quote
Got my replacement from BustedBus a few weeks ago. Great service, fast shipping and can't complain about the price either.
http://bustedbus.com
Good luck!
blacktruck
blacktruck is offline
PostPosted: Wed Apr 24, 2013 6:11 am    Post subject: Reply with quote
fuser is on the right tip,I think a "hot start" relay takes the load off the switch so it lasts longer.
Both is prolly the everlast version Embarassed
SGKent Premium Member
SGKent is offline
PostPosted: Wed Apr 24, 2013 8:19 am    Post subject: Reply with quote
it isn't always the starter that is causing the issue. People add accessories and larger headlight bulbs without allowing for the extra current.
The Avatar - the Baseball Hall of Fame, Ted Williams in his WWII P-38, has always been my hero since the very first time my dad took me down to the Boston Red Sox dugout after a game. They flew together in WWII. Ted liked to fish. Maybe as I get older it's time to do some fishing too. Smile Have a great day with your bus!
Preserve YOUR Freedom of Speech, Avoid Amazon, Facebook, Twitter, Google, and Apple.
End the War Against the Middle Class and Poor! ETWAU ~ http://etwau.org
Stuartzickefoose
Samba Post Whore
Stuartzickefoose is offline
PostPosted: Wed Apr 24, 2013 8:44 am    Post subject: Reply with quote
its sounds more like you have a second issue going on that is burning out your ignition switch prematurely. what stops working first when it goes out?
Stuart Zickefoose
206-841-7324
[email protected]
1967250s
1967250s is offline
PostPosted: Wed Apr 24, 2013 5:33 pm    Post subject: Reply with quote
Nope, no other issues, Stuart. As I said, I'm an electronics tech, on aircraft, Navy trained. Over 30 years experience fixing things the right way. Everything else on the car works perfectly. I tried several switches and the internal moldings of the stops are wrong. Once the switch is installed, I can't pull the key out as it won't rotate -rearward/counterclockwise- enough to release the tumblers that lock the key in the slot. Along with sub-par wire covering that is not heat resistant enough, wires with too fine copper strands, and the plastic housing that melts when you have to crank for more than a second. The car starts within a couple of cranks, no extra loads on battery.
Stuartzickefoose
Samba Post Whore
PostPosted: Wed Apr 24, 2013 5:37 pm    Post subject: Reply with quote
at least you know what your doing. thats always a plus. Very Happy
how about installing a hot start relay to take the load off the ignition switch then?
Stuart Zickefoose
206-841-7324
[email protected]
1967250s
1967250s is offline
PostPosted: Wed Apr 24, 2013 7:20 pm    Post subject: Reply with quote
I'm thinking about it^^^
