r39o Samba Polizei
Posted: Tue Apr 30, 2013 11:46 am Post subject: Sliding door handle re-keying how-to |
Per request here is a translation from German for the following threads:
http://www.thesamba.com/vw/forum/viewtopic.php?t=553863
http://www.thesamba.com/vw/forum/viewtopic.php?t=392080
http://www.thesamba.com/vw/forum/viewtopic.php?t=419907
DON"T FORGET TO GREASE!
Now is a good time to replace the body mounted handle seal.
Remove the handle by taking door panel off and lock screw out.
DON'T LOSE ANY PARTS!
_________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
One more islander... Samba Member
Joined: May 14, 2010 Posts: 399 Location: Canada: British Columbia West Coast
Posted: Tue Apr 30, 2013 3:35 pm Post subject: |
Duly bookmarked. Thanks! |
r39o Samba Polizei
Posted: Tue Apr 30, 2013 4:06 pm Post subject: |
One more islander... wrote: |
No need. It is in the FAQ.
The various lock threads all reference each other too now.
(NOTE: The rear hatch lock is next......) _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
Posted: Tue Apr 30, 2013 5:51 pm Post subject: |
r39o wrote: |
(NOTE: The rear hatch lock is next......) |
Small and large button?? _________________
TheAndante wrote: |
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer |
westofcenter Samba Member
Joined: March 16, 2012 Posts: 34 Location: Bloomfield, NY
Posted: Mon May 13, 2013 4:32 pm Post subject: 82 Hatch Key Redo |
So I am attempting to get my hatch key to match my other keys and am having trouble removing the tumbler. I cannot insert my key and I am assuming it is unlocked since I can open the door. I cannot see any pin or release screw to gain access to the tumbler? Anybody have the trick?
_________________ 1982 Westy
1986 Vanagon GL |
Posted: Mon May 13, 2013 5:48 pm Post subject: Re: 82 Hatch Key Redo |
westofcenter wrote: |
So I am attempting to get my hatch key to match my other keys and am having trouble removing the tumbler. I cannot insert my key and I am assuming it is unlocked since I can open the door. I cannot see any pin or release screw to gain access to the tumbler? Anybody have the trick? |
My small button rear hatch lock was hosed in the unlocked position. I found out that in order to get the tumbler out it needs to be in the locked position. I still have it like this.
I went to a j/y and I watched a guy hack one up,with a Dremel, because he did not know what he was doing.
I went to my parts guy and he found a brand new one. It had ten years of dust on it and to the tune of $180.00. I was just so happy I could lock my van up again. My surfboards were safe again.
I do not think that this part is even available.
Maybe send it off to one of the VW locksmiths here on Samba? _________________
TheAndante wrote: |
70 KG Coup
Posted: Mon May 13, 2013 6:17 pm Post subject: Re: 82 Hatch Key Redo |
70coupyel wrote: |
Maybe send it off to one of the VW locksmiths here on Samba? |
So, were you able to get your locks matched up? Doors, ignition, and hatch all the same key? _________________ 1982 Westy
1986 Vanagon GL |
odamark Samba Member
Joined: August 03, 2006 Posts: 10 Location: Auburn, CA.
Posted: Mon May 27, 2013 4:18 pm Post subject: Slider Door |
The spring was a little tricky but much easier (once I figured it out) than the door spring. Locks updated, cleaned and reinstalled! Thanks, I appreciate the help. |
yiucycle Samba Member
Posted: Fri Feb 21, 2014 6:34 pm Post subject: Re: 82 Hatch Key Redo |
Thanks again for the post, i was able to rekey my sliding door and rear hitch door. Now i can lock the hatch instead of using a wood block to lock it.
As for the hitch lock, if it is lock in the "open" position, which prevent it from accessing the pin(which holds the lock core and that triangle push widge thing). You can try dremel/drill access holes 90 degree from the original access hole. you will need two, one on each side to form a cross. then push the pin out from the newly drill access hole. Afterward, you can pull the widge out and push the lock core out the other side.
FYI: i never done this method since the PO didn't place the pin back so i was able to pull the wedge out and push the lock core out. But this method will save you the trouble of sourcing any other hitch lock and save $180.
[/quote] _________________ 1980 2.8LV6 Fiero ASI/Riviera Vanagon
"there is no point in being embarrassed of all the stupid shit i done and will continue to do"
rmcd Samba Member
Joined: October 29, 2010 Posts: 1348 Location: PNW - its a dry rain.
Posted: Thu Apr 23, 2015 7:12 am Post subject: |
I can't find any explanation how to remove the last part of the slider handle lock. I've removed the grub screw and lock cylinder in preparation for powder coating. How do you remove the last piece?
_________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1000 Location: Oakland CA
Posted: Thu Apr 23, 2015 8:34 am Post subject: |
If the lock cylinder is out, you've done it all. The remaining silver part at the bottom with the lock code stamped on it does not come out (afaik). Make sure they tape off everything that is not visible from the outside of the van so the size of the holes does not change (too much powder can be too thick to reinstall moving parts). _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012)
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Thu Apr 23, 2015 8:53 am Post subject: |
Paint stripper on a q-tip for more pecise placement will remove any powdercoat that gets into holes that the powdercoater inevitably will not mask off. As long as you have the cylinder, the spring and the locking bar out you are good to go. |
rmcd Samba Member
Posted: Thu Apr 23, 2015 8:58 pm Post subject: |
Removing the black plastic finger cover is the hardest part of the process, the cover isn't simply snapped into place. There are a pair of metal posts that protrude from the handle under the cover that slide onto a pair of metal sleeved keepers in the cover. |
VeeDubDaySpa Samba Member
Joined: February 29, 2008 Posts: 368 Location: Bend, OR
Posted: Wed May 06, 2015 8:12 pm Post subject: |
Syncrodoka, so how do you remove the plastic part without ruining it?? _________________ North American Hightop Installer/Distributor
Current stock (5)
Hot Water Systems
90 Syncro NAHT Vanagon RHINO
86 "Syncro" Van DIAMOND
87 Syncro Hightop WestyCamper ROCKY (for sale soon)
79 bay window OLIVER |
Posted: Wed May 06, 2015 8:55 pm Post subject: |
I have the older version of this snap-on radiator pick that I slip in at the end of the handle and gently pry the plastic grip off with.
There are 2 metal tabs that are cast into the back of the handle on the flat part that snap into a pair of tabs on the the plastic grip. |
windnsea Samba Member
Joined: May 07, 2008 Posts: 424 Location: Pasadena, CA
Posted: Tue Jun 09, 2015 8:32 am Post subject: |
Could someone clarify for me the issue of the 'grub screw and cover'? The original posting suggests drilling out the grub screw, and then after resetting the lock tumblers reinserting it. My question is - are you just drilling out a cover and then unscrewing the screw, or if drilling out both, what will be used then as a grub screw? Part number or ?? - do you have to rethread the screw hole for a larger set screw, and if so, what size was used.
Thanks in advance.
Windnsea
I'm tired of hauling around two keys!! |
Posted: Tue Jun 09, 2015 8:47 am Post subject: |
Don't drill out anything. There is some threadlock on the grub screw that needs to be picked out before it is backed out. |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Tue Jun 09, 2015 8:50 am Post subject: |
you don't need to drill out the grub screw. It's a very small screw with a small plastic cover on it. Pull the plastic cover out and use a s mall screwdriver to take the screw out. Proceed in reverse upon reassembling.
Pascal Samba Member
Joined: January 13, 2006 Posts: 825 Location: Fredericton, NB, Canada
Posted: Mon Oct 16, 2023 5:23 am Post subject: Re: Sliding door handle re-keying how-to |
Has anyone found a replacement seal that fits on the sliding door lock cylinder that is in this picture?
Is it the same seal that fits the front door cylinders that is 111837227B and NLA? I can’t find the part number on ETKA for the slider door cylinder seal. Thanks _________________ '84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby |
