Fhak915 Samba Member
Joined: July 14, 2010 Posts: 57 Location: Sebastopol CA
Posted: Wed Oct 31, 2012 6:09 pm Post subject: |
Quote: |
Do you have any pics of your work Fhak915 & danfromsyr? |
Mzalac,
I have not done it but I did take the sliders apart and modify them for rear sliders. I am very sure I could do it. Was actually thinking doing this since I have an Adventure wagon and the driver sided slider is nonfunctional because it is blocked by the cabinets. Check out my Gallery photos of the rear slider. It is do-able but the lock bar needs to be had from passenger side window to do it right. _________________ Frank
86 AW EJ22 |
heidi85ho Samba Member
Joined: October 17, 2009 Posts: 298 Location: Williamsburg,Virginia
Posted: Sat Nov 03, 2012 1:01 pm Post subject: |
just thinking outloud.......could you not remove both drivers side and passenger side windows and then re-install the drivers side window on the passenger side, and vice versa? would not then the locking channels be on the bottom and open from the rear? _________________ 85 westy-1.9-standard trans, FAS GenV 2.0 |
danfromsyr Samba Member
Posted: Sat Nov 03, 2012 1:12 pm Post subject: |
can't flip sides on the 85+ pass side sliding windows (sliding door window) as it's smaller than the drivers side with the new easy handle & mechanism.. so you have to get creative on that..
no pics of the work, just went out and got-r-dun they're really not that difficult to dissassemble and reassemble.. it helps to get a long nuff bar clamp that will also spread to open the frames and to reclose the frame to the glass.
heidi85ho wrote: |
just thinking outloud.......could you not remove both drivers side and passenger side windows and then re-install the drivers side window on the passenger side, and vice versa? would not then the locking channels be on the bottom and open from the rear? |
Abscate wrote: |
mzalac Samba Member
Posted: Wed Nov 28, 2012 11:01 pm Post subject: |
I had my sliding windows reversed.
_________________ 1989 Westfalia 2.1L OEM
"Life is like a game of cards. The hand that is dealt you represents determinism; the way you play it is free will." Jawaharal Nehru |
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Thu Nov 29, 2012 9:25 am Post subject: |
mzalac wrote: |
I had my sliding windows reversed. |
I removed your other identical posts and left your remaining post here, as it seemed to appy the best. Please don't crosspost, aka post the same thing in multiple threads. _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
Camp&Ride Samba Member
Posted: Thu Nov 29, 2012 5:04 pm Post subject: |
mzalak - let us know how this turns out. Am wondering about extra noise/water seepage from flipping the windows. Also, any pics of the slider reversal process would be great! _________________ 2WD 86 Westy
Zetec Inside |
Posted: Tue Dec 04, 2012 1:49 pm Post subject: |
$229 is definately closer to where it should be.. a nice price point compared to $399 as originally listed.
as for the reveresed window channel leaking that's a no, there isnt that much hydraulic/air pressure on the side to force the water inside. and the seal channel makes a physical dam to block surface pushed water.
where I had a leak was the new bottom cut in the aluminum channel where I had to shorten it. I was supposed to use some clear silicone in the gap/joint when I put it back together. and either forgot or figured it wouldn't get around the glass. but I've since sealed that cut int he channel with a surface applicaation of silicone. (inside the channel would have been better though). _________________
Abscate wrote: |
BC Westie Samba Member
Joined: September 05, 2007 Posts: 331 Location: British Columbia
Posted: Tue Dec 04, 2012 5:33 pm Post subject: |
When I picked up one of my van from the body shop 2 years ago after a full paint job they reveresed the windows accidently. I thought well I will live with it and try it out as it does seem logical and gives more air for sleeping.
The only draw back I had was water on the highway would get blown into the van where the slider meets the other piece of glass. I might of needed new felt but I decided to just go back to the body shop and have them flipped back to their normal postion and problem solved. ***This only happened at HWY speeds***
I am a fan of the rear windows to slider conversions. _________________ 1980 Vanagon Cali Import 86,000Miles
1981 Vanagon (Auto) 219,000kms
1981 Westfalia (Auto) Cali Import 169,000Miles
1981 Westfalia 300,000kms
1982 Westfalia Cali Import 193,000Miles
1982 Westfalia (Auto) 205,000Kms
1984 Vanagon 306,000kms
1987 Vanagon GL 300,000Kms |
jsmitch11 Samba Member
Joined: July 02, 2011 Posts: 337 Location: Seattle, WA
Posted: Tue Dec 04, 2012 6:04 pm Post subject: |
They are clearing them out because they DO NOT FIT!!!! I have helped install 3 of these windows and they are a major PITA. You have to remove the piece between the plastic vents and the glass and use sikaflex or sealent instead and it stills in incredibly hard. I can't believe they even sell them....if I were them I would be ashamed to put my name on those! _________________ 1984 Vanagon Westfalia Syncro Hightop
1986 Vanagon Syncro(RIP)
1989 Vanagon Wolfsburg Whitestar Edition(RIP)
My Van syncro conversion/restoration
http://www.thesamba.com/vw/forum/viewtopic.php?t=535730&highlight=black+diamond |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Tue Dec 04, 2012 6:08 pm Post subject: |
jsmitch11 wrote: |
they DO NOT FIT!!!! |
Unfortunately I have heard the same. |
goffoz Samba Member
Posted: Tue Dec 04, 2012 10:21 pm Post subject: |
jsmitch11 wrote: |
They are clearing them out because they DO NOT FIT!!!! I have helped install 3 of these windows and they are a major PITA. You have to remove the piece between the plastic vents and the glass and use sikaflex or sealent instead and it stills in incredibly hard. I can't believe they even sell them....if I were them I would be ashamed to put my name on those! |
Well that explains a difficult weekend, I recently experienced.
Told a buddy "Sure I can help you with that, done a few of them"Made me feel like a Dolt.
....thanks GW..suckered again
Glad I placed my last order with VC, good cookies |
mzalac Samba Member
Posted: Thu May 02, 2013 2:31 pm Post subject: |
Almost finished with my sliding windows.
Just need to paint my white screen frames black.
So far no extra wind noise or rain leakage.
goffoz Samba Member
Posted: Thu May 02, 2013 8:36 pm Post subject: |
Dude ..."black on black",,love it
...don't forget...always park in the shadows
Tell us a little about the paint
thanks |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
nemobuscaptain Samba Member
mzalac Samba Member
Posted: Fri May 03, 2013 10:48 pm Post subject: |
yep, you guys are right.
I should of done what u guys did.
darn it!!! _________________ 1989 Westfalia 2.1L OEM
mzalac Samba Member
Posted: Wed May 22, 2013 2:14 pm Post subject: |
Here's my step-by-step:
Posted: Wed May 22, 2013 4:42 pm Post subject: |
you can't swap side to side on the 85-91
the slider door window is smaller than the DS sliding window.
so you have to dissassemble and swap the parts. w/o the latch ending up on the top. _________________
Abscate wrote: |
