oshima Samba Member
Joined: December 12, 2011 Posts: 112 Location: Knoxville, TN
Posted: Fri May 10, 2013 11:00 am Post subject: 1978 - Fuel ends up in engine compartment. At wits end. |
Hi everyone,
I have a 1978 FI bus. The thing has been sitting for ten years, so I did all the usual replacements/tune ups to get it going again, and it runs swimmingly. Unfortunately, I have a problem where the whole left side of the engine compartment behind the tail light is soaked with gasoline after I drive it for more than a minute or two. I have replaced every hose and grommet, and have checked every inch of fuel line for spilled fuel, and there is none anywhere. None of the injectors have fuel on the outside of them, and none of the hoses have fuel on the outside either. There is no gasoline anywhere else in the engine compartment - it's bone-dry.
If I run it and rev the engine while it is sitting still, it won't soak the compartment; it's only if I actually drive it.
Any ideas? |
hansie Samba Member
Joined: August 29, 2007 Posts: 476 Location: Beach Lake, PA
Posted: Fri May 10, 2013 11:08 am Post subject: |
Is your tank full ? Do you have your canister hooked up ? _________________ Karl Bower |
Paintedbus Samba Member
Joined: September 14, 2003 Posts: 679 Location: salem, ma
Posted: Fri May 10, 2013 11:10 am Post subject: |
i bet you didnt get the 2" hose behind the spare tire well. Its a pain the the ass to get to, but crawl up in there and look. thats your problem and the cause of most stubborn fuel smells in a baywindow bus. I have watched gas pour out of that on my bus hen i over filled it, if you take a corner hard, it would spill out there too. _________________ Champagne Edition Roadtrip monster "Juakali"
~"Paintedbus" Ken~
The Mobile Muralist
WWW.PAINTEDBUSART.COM
Posted: Fri May 10, 2013 11:11 am Post subject: |
the red one is always broken.
(edited for clarity) _________________ Champagne Edition Roadtrip monster "Juakali"
~"Paintedbus" Ken~
The Mobile Muralist
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Fri May 10, 2013 11:13 am Post subject: |
My experience is limited in this area, but I would ask if you removed the fuel tank and replaced all the vapor lines and the fuel filler tube. Sometimes if these lines are cracked, on a reasonably full tank the fuel will slosh out of the cracks and dribble down all over the place. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Fri May 10, 2013 11:21 am Post subject: |
I fixed a 1978 that had a small engine fire.
Once everything was cleaned up I finally found the cause.
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Fri May 10, 2013 11:24 am Post subject: |
yeah, but he is saying its on the left side, behind the tail light... thats right next to the red #24. The filler neck and most of the easy-to-reach vapor recovery lines on the fuel tank are blocked off/ no where near the location he is finding the gas. If any of those leaked, it would either be under the bus or behind the rear passenger tire (been there w/ a filler neck leak)
As this is a really common problem on late bays, I bet that his problem has nothing to do with the filler neck, charcoal canister or fuel tank directly, nor the fuel injection lines. Its common enough that unless you have replaced this tiny little joining hose, I can guarantee that its broken. _________________ Champagne Edition Roadtrip monster "Juakali"
~"Paintedbus" Ken~
The Mobile Muralist
WWW.PAINTEDBUSART.COM |
poptop tom Samba Member
Joined: July 27, 2004 Posts: 1607 Location: The Hoosier State
Posted: Fri May 10, 2013 11:28 am Post subject: |
I think Ken is on the right track with his issue. _________________ '76 Deluxe Campmobile |
Posted: Fri May 10, 2013 11:53 am Post subject: |
I agree. Assuming his tank is pretty full. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
oshima Samba Member
Posted: Fri May 10, 2013 12:57 pm Post subject: |
Thanks guys, you nailed it. I actually managed to find it, as I saw a single drip drop down before I checked back here. Glad my girlfriend saw it - I lack the sense of smell for gasoline after replacing every line on this car.
After sitting for ~10 years, the car is running perfectly. Lifters are operating normally (thank you hydraulics) and after replacing the spark plugs and lines, and Jamie Sue is running better than ever.
Still though; I definitely want to check out the vent lines above the gas tank. I can still smell gasoline vapor. Do I need to drop the engine to get to those? Maybe I can train a squirrel to go up there and do it? |
SGKent Samba Member
Posted: Fri May 10, 2013 1:06 pm Post subject: |
You can get to those hoses with a little effort with the engine in but it is certainly easier with the engine out. Also a good time to check if your gas gauge works right before you do it. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
You need to remove the firewall which is possible with the engine installed. Keep in mind that there are two screw holding it that are accessed from under the bus looking straight up. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Fri May 10, 2013 1:10 pm Post subject: |
good to hear! if ou want to do the rest of those lines, then aeromech is right on target. no engine removal needed for that, just some skinny little arms and some patience! _________________ Champagne Edition Roadtrip monster "Juakali"
~"Paintedbus" Ken~
The Mobile Muralist
Posted: Fri May 10, 2013 1:11 pm Post subject: |
oshima wrote: |
You probably also want to do the fuel filler hoses while you are at it. They too are easier with the engine out. |
