rotezora Samba Member
Posted: Wed May 08, 2013 2:23 am Post subject: 1978 CE Westy with uncommon 32/36 DFAV Weber carb?! |
Hi,
Just recently this nice CE Westy came home from US into my hands
The former owner done some modifications. The origianl ignition was taken out and for that a Weber Carburator was put there.
32/36 DFAV 23A K7
The Problem is that this piece is poorly installed. Some tubes are just closed with a screw. Also the mixture is way too rich. I'll tried to connect the cold start with the ignition (pin 15) but this grilled some fuse
Is this okay to close the tubes like that?
Does anyone have this combination working in their Bus? Is it a good solution, regarding maintainability, fuel consumption and performance?
Was this sort of carb already used in the late 70s?
Would be great to find some fellows with the same configuration, because here in germany this combination is rather unknown.
best regards,
Marco
ps. if the former owner recognize his bus - it would be great to know him. not for punishment of the changes made  |
Posted: Wed May 08, 2013 5:38 am Post subject: |
Marco, There has been a lot of discussion here on Samba about these carbs. The Type 4 engine does not have any way to heat the intake manifold so the use of any center mount carb is going to be a problem as the carb will run icy cold even in warmer weather. They can be made to run decently but this takes a lot of fabricating to do well. Out of the box the carb tend to run lean coming off idle and have a bad bog, so many people jet their carb to run overly rich to prevent this, it sounds like that is how your carb is set up.
If you have any kind of pollution standards you need to meet, you will probably not be able to do it with this carb and should go back to the stock FI or maybe dual carbs since that is what I believe many European Type 4 powered buses used.
Here is a thread that covers many of the issues with these carbs.
http://www.thesamba.com/vw/forum/viewtopic.php?t=217070 |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42382 Location: at the beach
Posted: Wed May 08, 2013 5:53 am Post subject: |
totally agree with Wildthings. Those carbs were designed for water cooled manifolds where the port runners came off the same side, not opposing runner air cooled. They can be tuned to run effectively but one will never pass smog with them. The droplets will never effectively vaporize unless you are running preheated air. And, unless you can turn that preheated air off or regulate the temperature once it gets too hot it'll start a fire the first long hard grade you climb on a summer day which will melt the inside of the carb and maybe valve ports. Been there in a CJ7 when the preheat tube valve stuck open on a long climb and it started a stack fire. Car died but just in those 20 seconds or so as it died it made a puddle out of the intake manifold aluminum electric preheat disk. It melted that aluminum round thing with the wire in the photo below.
_________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Randy in Maine Samba Member
Posted: Wed May 08, 2013 9:08 am Post subject: |
If it were me, I would be looking for a decent set of dual carbs for this bus.
Italian or Spanish Weber 40 IDFs would be my first choice. |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Wed May 08, 2013 9:20 am Post subject: |
Randy in Maine wrote: |
I agree. To add to that get your yourself some cable/pulley linkage as seen here: http://www.tangerineracing.com/engine.htm This type of linkage is vastly superior to any other kind out there, it is super easy to sync and will stay in sync much longer than cross-bar or bell crank. It is also easier on the throttle bushings. The only problem is that it is expensive _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
Posted: Fri May 10, 2013 3:05 am Post subject: |
hey,
thanks for the hints.
bigger modifications are no option now. Double weber are surely nice but also expensive.
i'll just try the get it running and if there are any hints for adjust the current setup i would appreciate that
marco |
Bleyseng Samba Member
Posted: Fri May 10, 2013 6:19 am Post subject: |
Get ahold of samba member Bursch in Bussum,NL as they might still have a OEM set of dual solexes for a bus. They run megasquirt fi on their camper that has gone to China and South Africa!
Or source a complete fuel injection set up for your bus and toss that piece of crap carb into the garbage as it will never run right on your bus. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 3185 Location: South Benfleet, Essex, UK
Posted: Fri May 10, 2013 8:31 am Post subject: |
Bleyseng wrote: |
Or source a complete fuel injection set up for your bus and toss that piece of crap carb into the garbage as it will never run right on your bus. |
Ralph & Lucas van den Houten's VW Type 2, is of North American specification, and had originally had Bosch L-Jetronic fuel injection, rather than twin Solex carburettors, like we have in Great Britain, for the 1972~79 VW 17/18/2000 Type 2 & 1980~83 VW 2000 Vanagon. _________________ Regards.
Nigel A. Skeet
https://vwt2oc.co.uk |
Posted: Fri May 10, 2013 6:20 pm Post subject: |
Yes, I know that but they had a set of Solexes sitting on the shelf from a parts bus. They run Megasquirt and also Ljet as a back up. Its worth a shot to see if they still have em and will sell them as anything is better than that single carb.
They live not too far from my sister in law...as this is me working on their bus.
Pcrog027 Samba Member
Joined: January 17, 2011 Posts: 98 Location: Berks County, Pa
Posted: Fri May 10, 2013 7:10 pm Post subject: |
I have that carb on my 77 riviera. I dont even run it when its below freezing outside. I just got a full FI setup which has taken me 2 years to locate. Hopefully I will move away from that weber this summer! I dont know where you are located but if its below 25 latitudes you will be fine. |
Posted: Sat May 11, 2013 7:39 am Post subject: |
Pcrog027 wrote: |
His location is listed as "Berlin" so he is in Germany. Can get pretty cold there so the single carb will be problem. FI is the best choice if he can locate a complete setup but there are stock dual solex setups out there. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
Posted: Sat May 11, 2013 10:28 am Post subject: |
If you can find the pieced off of a European bus for the air preheat, building an adapter for the carb is easy enough, I am assuming they had this system. This will allow the bus to be driven down to temperatures of 5°C easily enough.
This is the setup I ran for years and it worked well enough, it used the heater box as a hot air source. I later got all the VW pieces together and used them instead of the heater box. Using the VW pieces made a noticeable improvement in how fast hot air got to the carb.
