Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Mon May 06, 2013 7:40 am Post subject: |
I am using a 15" x 6" Mercedes steel wheel for my spare, mounted with a 205/65-15 tire. The tire is VERY close in circumference to the 225/55-16 tires I'm using, and the wheel fits over the Volks cafe Audi brakes up front. I took out the tire retainers in the clamshell and added a few washers under the retaining bolt and all is well. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
bosruten Samba Member
Posted: Mon May 06, 2013 7:23 pm Post subject: |
Jake de Villiers wrote: |
I am using a 15" x 6" Mercedes steel wheel for my spare, mounted with a 205/65-15 tire. The tire is VERY close in circumference to the 225/55-16 tires I'm using, and the wheel fits over the Volks cafe Audi brakes up front. I took out the tire retainers in the clamshell and added a few washers under the retaining bolt and all is well. |
Thanks! How far would you drive on that spare?...I do have a decoupler. _________________ '87 Syncro Weekender |
Posted: Tue May 07, 2013 8:15 am Post subject: |
bosruten wrote: |
Thanks! How far would you drive on that spare?...I do have a decoupler. |
The Continentals on the van are 811 revs/mile and the Uniroyal spare is 815 revs/mile. I haven't tried driving the van with it on the rear to see if it triggers the posi diff but I don't think it would be a problem. If I had to drive a couple of hundred miles, I'd probably put the spare on the front. _________________ '84 Vanagon GL 1.9 WBX
Posted: Tue May 07, 2013 4:29 pm Post subject: |
Christopher Schimke wrote: |
That wheel is 7.5" wide with a 40mm offset. Being wider will hamper your efforts to fit it into the clamshell and the additional width plus the additional offset will force you to run different spacers than you would with the CLK wheels.
You can still buy brand new CLK steel wheels at the Mercedes dealer for not much more money than that. Ask for part number 2034000302. That wheel will be the same size and offset as your forged alloy CLK wheels and will use the same hardware. |
Using that part #, I am shown C240 rims? I use #'s to search Canadian tire...so I enter C240 and come up with this... http://tires.canadiantire.ca/en/wheels/steel-wheel...l/0096135/ .I tried shopping around Mercedes places locally...no help My wife is heading off on a trip, I'd like to get this sorted before she leaves. _________________ '87 Syncro Weekender |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 1868 Location: Pittsburgh PA (ish)
Santana Samba Member
Joined: March 18, 2008 Posts: 146 Location: T-Town, WA
Posted: Sun May 12, 2013 2:51 am Post subject: |
Those appear to be the Ronal R-28's. I used to run a set of those a couple of years ago. They bolted right on with no spacers or modification of any kind. Really a nice quality wheel, it is a shame they aren't making them anymore.
_________________ PHOTO GALLERY |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Sun May 12, 2013 8:11 am Post subject: |
I also had a set of those r-28's, I thought it was of the best looking wheels available for the vanagon.
I do not remember which type of ball seat I was running with those, whether they were conical or ball seat.
The et kicks it out away from the van 10 mm, which in my opinion is not a big deal.
I had these on a 2wd van, with 225-55-16 on them, and there was no issue with the sliding door, although it was very close fully opened. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
TequilaSunSet Samba Member
Joined: May 30, 2012 Posts: 2109 Location: Philippines
Posted: Sun May 12, 2013 10:12 am Post subject: |
Piling on, I'm looking at these...
_________________ Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me |
KDI_CUSTOMS Samba Member
Joined: November 07, 2009 Posts: 91 Location: Maryland
Posted: Mon May 13, 2013 2:57 pm Post subject: |
Santana and Levi....you guys say a wheel with an ET20 will fit the Vanagon. Any chance you two or Chris would know if 17x8 or 18x8 ET20 would fit or would I have clearance issues for the front wheels? Just curious cause I found some cheap BMW wheels Id like to get.
Argos33 Samba Member
Joined: May 09, 2012 Posts: 68 Location: Arvada, Colorado
Posted: Mon May 13, 2013 10:03 pm Post subject: |
Hey samba friends,
I got these tires from my brother and am trying to figure out what lug bolts and spacers I need. They are 15" wheels off of a mercedes. It says 6 1/2J x 15H2 and ET44.
So I will need ~7mm spacers for each wheel and lug bolts (that match the hole profile) and long enough to reach the threads? Thanks
Evan |
briansr1 Samba Member
Posted: Wed May 15, 2013 8:10 pm Post subject: 85 Vanagon Wheels from a 2002 Eurovan |
Does anyone one know if the wheels from a 2002 eurovan fit a 1985 vanagon? Will they need spacers and what thickness.
Thanks,
Brian |
Posted: Thu May 16, 2013 6:34 am Post subject: |
Argos33 wrote: |
Hey samba friends,
Evan |
I would recommend 10mm spacers for the front and 15mm spacers for the rear along with longer rear wheel studs and small ball seat hardware. You will also have to drill out the lug holes (37/64" is recommended). _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Thu May 16, 2013 6:38 am Post subject: Re: 85 Vanagon Wheels from a 2002 Eurovan |
briansr1 wrote: |
Thanks,
Brian |
I'm assuming that your '85 is a 2wd? There are several versions of Eurovan wheels with quite a few different sizes a offsets. We would have to know exactly which ones you are working with in order ton know what hardware you will need.
One thing to remember about any Eurovan wheel set is that you have to have the centerbores machined to 66.56mm in order to fit over the Vanagon hubs. This is true for almost all Audi and late VW wheels. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Thu May 16, 2013 6:45 am Post subject: |
KDI_CUSTOMS wrote: |
Santana and Levi....you guys say a wheel with an ET20 will fit the Vanagon. Any chance you two or Chris would know if 17x8 or 18x8 ET20 would fit or would I have clearance issues for the front wheels? Just curious cause I found some cheap BMW wheels Id like to get. |
Well, BMW wheels have a 5x120 bolt pattern and the Vanagon is 5x112.
As for ET20 wheels, I generally wouldn't recommend them, especially on a van that is any lower than a standard Vanagon. Sure they will bolt on and people have run them and been happy, but depending on the wheel/tire width, they can also cause rubbing issues at the upper front fender lips (the lower the van the worse this issue) and the sliding door. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
1971BugGuy Samba Member
Joined: October 16, 2004 Posts: 426 Location: Ontario, CANADA
Posted: Sat May 18, 2013 12:13 pm Post subject: |
Ok, so I got me a set of wheels that I'm told were from a Mercedes CLK although I have been unable to verify that as of yet. Anyhow, I have bored out the holes to accommodate the 14mm studs/bolts. The rear wheel studs do not protrude through the rim but instead the tip of the stud rests approximately 1mm below the bottom of the ball seat. what length of stud should I use if I plan to use closed nuts to complete the job? Also, what length of bolt is recommended. Feel free to chime in Loogy as I will be ordering the parts from you.
_________________ Only a fool or a child would judge a project before it reaches its completion.
1971 Super Beetle
1986 Vanagon Westfalia Weekender |
PAULPIERCEFAN34 Samba Member
Joined: October 19, 2012 Posts: 17 Location: Northern Ca
Posted: Sun May 19, 2013 12:46 pm Post subject: VW Golf wheels; Will they work? Please reply. |
These wheels are 5x112, they are 18' rims, Im guessing that theres no place for the center cap to go. Please tell me anything, thanks.
Posted: Sun May 19, 2013 12:48 pm Post subject: |
Wheel hunting is a PITA... and I keep bugging poor Christopher.
I am all over the map trying to figure this crap out, from used Benz rims to new stuff, offset, size, clearance, studs and pressed in, bolts, lugs, drilling no drilling, spacers...
At this point I am trying to rein in the cost somewhat (out the door cost). CL has proven to have nothing but shit, so now I am looking at new wheels. I don't want to raise the van, and will lose 1.5" of ground clearnace with the 1.8t... so I might lower it if I raise the height in wheel size to get back to square one. I'm looking at:
VC Mefro 16" Thinking of painting contrasting or black, maybe even a hubcap added.
BRM Repo in 15" or 17" Painting the inside of spoke contrasting?
Any suggestions or pics with these mounted on your vanagon? _________________ Don't harsh my mellow...
1967 Bug- Gone
Posted: Mon May 20, 2013 7:19 am Post subject: |
1971BugGuy wrote: |
I would go with a set of 56mm rear studs, small ball seat lug nuts and a set of 45mm small ball seat front lug bolts. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
