brownie Samba Member
Posted: Thu Jun 14, 2012 3:01 pm Post subject: Disc Brakes - 911 on a bus |
Ok im trying to figure out something here i have a 65 bus and going to run Porsche wheels,i will be running the 944 brakes on the front but on the back i will be useing 911 brakes I have a swing axle type 3 tranny,what do i need to do to run the 911 brakes on the back is there a adapater or ? thanks for any info. |
walkthru Samba Member
Posted: Thu Jun 14, 2012 6:07 pm Post subject: |
contact Lanner @ Vdub Engineering. He has everything you need. Great guy, service, quality parts. |
petevdub Samba Member
Joined: January 01, 2005 Posts: 205 Location: Toronto, Canada
Posted: Thu Jun 14, 2012 7:04 pm Post subject: |
^^^^ yeah, what he said.
Lanner is THE brake guru!
My '65, brakes a-la-Lanner/VDubEngineering!
_________________ '72 super
'65 21w
'52 split 11C |
Posted: Fri Jun 15, 2012 4:08 pm Post subject: |
ok cool thanks |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1302 Location: North Carolina
Posted: Tue May 14, 2013 12:19 pm Post subject: |
Picked up a complete Porsche 944(1984) front disc brake assembly off of Craigs list for $150 which I to install on my wife's 13 window delux. The seller also has the complete rear brake assembly(steel trailing arms & all) for another $150....I don't think I can pass it up!
I'm in the process of doing the IRS conversion and already have most of the type 1 parts and was planning to go with the beetle rear disc brakes with redrilled Porsche pattern rotors. If I substitute the 944 trailing arms & all will the beetle CV joint bolt directly to the 944 stud axle?
Thanks |
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Tue May 14, 2013 11:16 pm Post subject: |
petevdub wrote: |
That is the Bees Knees!!!
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
karl h Samba Member
Joined: October 10, 2005 Posts: 578 Location: austria
Posted: Wed May 15, 2013 3:26 am Post subject: |
DerrickfromNC1 wrote: |
Thanks |
no, the bug CV joint is smaller, you can use a bug stub, they just fit in without modifications. if you have the 944 rear trailing arms (Steel) you can just swap the inner rubber bushing for a bug bushing and use the 944 arm, they are the same as on a bug. if you have acesss to a 944 body, you can even use the brackets to weld these to your Type 2 torsion tube and leave the 944 inner bushings in place.
-edit- you can also just use a 944 or thing CV on your bug axle
either way, you have to experiment with the brake cable, i dont know if it will fit (in lenght) without modifications. _________________ 61 panel: http://www.thesamba.com/vw/forum/viewtopic.php?t=465022
68 ghia vert
arctic alice (63 on irs): http://cal-look.no/lounge/index.php/topic,27456.0.html
86 Caravelle
04 new beetle vert |
Posted: Wed May 15, 2013 2:20 pm Post subject: |
karl h wrote: |
Thanks |
either way, you have to experiment with the brake cable, i dont know if it will fit (in lenght) without modifications. |
It sounds like it would be just as easy to take the 944 backing plates, rotor/hub and calipers and use the bug trailing arms and axle studs. If it makes a difference I plan to go with the Westwagons IRS kit with the adjustable springplates.
Thanks |
