75smith Samba Member
Posted: Wed Nov 28, 2012 2:33 pm Post subject: Engine Build topics |
This topic is to create a place in which to find step by step engine builds, both performance and stock based.
So I pretty much want to create a list of forum engine builds-either ongoing or completed, that proceeded in a step by step build up, because I feel there is much information from those builds, stock, performance, and whatever.
NCdad's - 1955cc / 1956cc Engine Build
Altewagen-Grapes of Wrath $200 engine rebuild
Maboyce-Stock 1600 DP rebuild, step by step
skills@eurocarsplus-My attempt at a 1904
Miniman's-Turbo/EFI on a Budget
Wheelie Pete -86x86 Build Thread
Steven G.-My Okrasa 1300 Build Thread
If you know of a build, link it, whether its a performance build in the performance forum, or a stock build in another forum; the basis of an engine build is the same and you can learn as much from a stock build as from a performance build. _________________ My 1975 Beetle Build Updated 8-21-12
My engine build
Clatter Samba Member
Joined: September 24, 2003 Posts: 7846 Location: Santa Cruz
Danwvw Samba Member
Joined: July 31, 2012 Posts: 8895 Location: Oregon Coast
vince1 Samba Member
Joined: December 14, 2003 Posts: 841 Location: Burgundy, France
s1fter Samba Member
Joined: February 29, 2004 Posts: 11 Location: New Zealand
Posted: Sat Aug 01, 2015 12:32 am Post subject: |
Our shop has made this App, and may help VW engine builders with Combo's and posting combo's.... and it's free!
https://itunes.apple.com/nz/app/id1017572487 _________________ s1fter
"If at first you don't succeed, then skydiving isn't for you" |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3999 Location: Antioch, California, a block from the hood
s1fter Samba Member
Posted: Sun May 29, 2016 12:51 pm Post subject: Re: Engine Build topics |
Yes _________________ s1fter
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2377 Location: Mount Airy, Maryland
71beetleconvertable Samba Member
Posted: Tue Nov 27, 2018 9:22 pm Post subject: Re: Engine Build topics parts sourcing |
I am rebuilding a 1600 dual port engine. Does anyone have any advice to ensure that the parts that I purchase are made from quality materials and are of high quality specifications. I appreciate that quite often you get what you pay for but also on occasion a premium price doesn’t always provide quality. As I am not a machinist or mechanic by trade I am a little bit in the dark here. Guidance would be greatly appreciated.
Thank you for your consideration |
Ron G Samba Member
Joined: September 05, 2013 Posts: 228 Location: Albuquerque, NM
Posted: Tue Feb 05, 2019 6:22 pm Post subject: Re: Engine Build topics |
I just finished my 2332 build and running A-1’s exhaust
1 5/8” , the head opening is 1 1/2”.
What is the best exhaust gaskets for this, I got some but were to small.
Thanks. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11515 Location: Oregon
Posted: Wed Feb 06, 2019 6:29 pm Post subject: Re: Engine Build topics |
| Ron G wrote: |
Thanks. |
There you go!
http://vwparts.aircooled.net/Copper-Exhaust-Flange...askets.htm
When it comes time to remove the exhaust. Just heat the gaskets red hot with a Mapp Gas torch and let um cool. Then reuse the gaskets.
I have them on the same setup that you have described. They work great.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Ron G Samba Member
Posted: Wed Feb 06, 2019 6:46 pm Post subject: Re: Engine Build topics |
| Ok those look great, thank you very much. |
69gunguy Samba Member
Posted: Tue Apr 30, 2019 6:09 am Post subject: Re: Engine Build topics |
| Ok guys, need some expert advice. I am on the fence as to what engine to build for my baja. I have been leaning towards a 1904 or a 2007. I would like to know what you guys and gals think for best economy and power for a daily driver. If there is another combination, please advise and why. Thanks again for all of your knowledge. Oh, l most forgot. I live in North Central Arkansas with a lot of hill driving. |
Ron G Samba Member
Onceler Samba Member
Posted: Sun Jan 26, 2020 7:10 pm Post subject: Re: Engine Build topics |
Any good stroker builds where the images are hosted on the samba? _________________ 1972 Karmann Ghia |
scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1050 Location: gigharbor W.A
Joined: May 17, 2003 Posts: 4875 Location: Harmony, PA
Posted: Wed Jan 29, 2020 7:28 pm Post subject: Re: Engine Build topics |
can’t believe I never saw these. Excellent builds! Thanks _________________ 1972 Karmann Ghia |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80381 Location: Sneaking up behind you
Posted: Wed Jan 29, 2020 7:37 pm Post subject: Re: Engine Build topics |
I'll add my 2180.
Glenn's 2180 Build pictures
More pics
Berg 5 rebuild pictures
Engine Specs: Type 1, 2180cc, horizontally-opposed 4 cyl, balanced
Compression Ratio - 9.31:1 (92x82, 56cc head, .057" deck)
Case - Volkswagen, AS41 (German), dual relief, 8mm studs, case saver inserts, deep #3 studs, tapped for full flow oil system, stress relieved, deburred, blue printed
Crankshaft - 4340 Forged Chromoly, 82mm, forged, counterweighted, balanced, nitrided, 8 dowel (11/32"), stress relieved, shot peened, wedge mated, Buick journals
Connecting Rods - CB Performance H Beam, 5.4", ARP 2000 bolts, magnafluxed, balanced
Pistons/Cylinders - AA, 92mm, Thick Wall, forged pistons, balanced
Camshaft - Engle FK-8, 298° duration / .382" lift (.535" with rockers)
Heads - Steve Tims, Stage 2, 42x37.5, ported, polished, 56cc chambers
Valves - Stainless steel, 42mm intake, 37.5mm exhaust, tapered guides
Rocker Arms - CB Performance 1.4 ratio, forged, needle bearings, heavy duty studs
Valve Train - Manton dual springs, Manton 3/8" chromoly push rods, Chromoly retainers, Wizemann lifters
Induction - 2 Weber 48 IDA dual throat carbs with Uni filters, 155 main, 65 idle, F11 emulsion tubes
Carb Linkage - Gene Berg GB-453, fan mount linkage
Intake Manifold - Generic (tall), match ported, polished
Exhaust System - Gene Berg GB-933S 1-5/8" merged, GB-971A-2M dual muffler, Jet-Hot ceramic coated
Lubrication - Gene Berg GB-233A oil pump (26mm gears), Gene Berg full flow oil kit, Canton Mecca remote filter, Berg 1.5 quart deep sump, Type 1 cooler, steel braid Teflon hose, Shell Rotella T 15W-40 oil
Cooling - Volkswagen, 1973 Type 181 dog house fan housing (no fresh air), Berg fan (welded + balanced), all OEM tin including the "Hoover Bit", flaps and thermostat.
Clutch / Disc - KEP, 200mm Stage I (1700 lb.) pressure plate (balanced), ACE "Copperhead" disc
Flywheel - VW, forged, 8 dowel (11/32"), 12.5 lb., forged gland nut, balanced, wedge mated
Pulley - Gene Berg GB-439 "Equalizer" billet steel pulley, 3.5 lb., balanced
Alternator - Bosch AL78X, heavy duty (custom wound to 85 amps)
Starter - IMI High Torque (534 ft-lbs.), Bosch relay directly wired to the battery
Ignition - Bosch 010 distributor, Bosch Blue coil, Beru Silicone Copper Core wires and NGK BPC6ES plugs
Misc. - GB-207 breather box, Stainless Steel pushrod tubes, steel braid mechanical oil pressure line, battery quick disconnect
Transaxle Specs: Type 1, Gene Berg 5 Speed Manual, IRS
Builder - Gary Berg
Case - Volkswagen "Rhino" case, heavy duty side covers
Mounts - Gene Berg GB-642P heavy-duty rear mounts and Gene Berg GB-643F front crossmember
Gear Ratios - Close ratio 1st, 2nd, 3rd, 4th and 5th, steel shift forks, hardened keys
1st - 3.78:1 (heavy duty, late model)
2nd - 2.06:1 (stock, late model)
3rd - 1.58:1 (welded hub)
4th - 1.21:1 (welded hub)
5th - 0.82:1 (welded hub)
Rev - 3.61:1 (stock, late model)
Differential - ZF, Limited Slip (LSD) with 4 spyder gears (11 tooth)
Ring / Pinion - Gene Berg GB-660K-3875 (Klinkenberg), 3.875:1 ratio, 8 bolt
Shifter - Gene berg GB-5710, 5-speed shifter, new shift rod bushing
Axles - Type 181 Stub Axles and C/V Joints with Sway-A-Way Axles
Lubrication - Valvoline Gear Lube, 80-90W API Service GL-5 and MT-1 rated
Misc. - Heavy duty cross shaft (welded), GBE Super Duty Pinion Bearing Retainer, Welded Clutch tube _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
