hrsr Samba Member
Joined: June 21, 2010 Posts: 57 Location: Aldershot, Hampshire, UK
Posted: Wed May 29, 2013 3:24 pm Post subject: A few more onboard laps...Who needs more than 1300cc? |
rlmartinez Samba Member
Joined: December 09, 2005 Posts: 233 Location: Whittier, CA
Posted: Wed May 29, 2013 3:39 pm Post subject: |
Great Video,
How about posting some pics of the car? _________________ 54 Bug
56 convertible |
hrsr Samba Member
Posted: Wed May 29, 2013 10:15 pm Post subject: |
rlmartinez wrote: |
Great Video,
How about posting some pics of the car? |
No probs!
[/img] |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Wed May 29, 2013 11:59 pm Post subject: |
tatersgravy Samba Member
Posted: Thu May 30, 2013 9:56 am Post subject: |
"Top Shelf" is it possible to tell a bit more about the engine build?
Thanks! |
hrsr Samba Member
Posted: Thu May 30, 2013 12:03 pm Post subject: |
Here's the basic spec:
Car Spec: 1965 swing axle Beetle, CSP disc brakes all round, 1285cc, 44 Webers, Engle FK10 cam, reworked stock heads with stock sized valves, cooling by 12 inch electric fan and ram air pipes, approx 120-125bhp@ 8000rpm. Bears close ratio gearbox with a Quaife ATB diff, Dunlop historic crossply tyres, weight around 740kg with driver. Front suspension: Stock beam, springs and rubber bushes, adjustable Formula Vee anti-roll bar, 2.5" dropped spindles, Quantum double adjustable motorsport dampers. Rear suspension: Stock springs and rubber bushes, lowered 2 splines, custom made heavy duty adjustable Z-bar, Quantum double adjustable motorsport dampers. |
64vdub Samba Member
Joined: August 05, 2008 Posts: 614 Location: Sunny So. Cal
Posted: Thu May 30, 2013 12:43 pm Post subject: |
Very Nice! That's what it looks like when I go to work _________________ 64' Pearl White beetle, type 113 sedan. Purchased in Hamburg Germany, driven for a year via vw tourist program, shipped to CA in 1965.
Founding member of Derkaferklub, Southern Cal. since 2008
Q: Would you consider a trade? What do you collect?
A: I collect money
GO SF GIANTS! |
Posted: Sat Jun 01, 2013 11:47 am Post subject: |
hrsr wrote: |
Thanks!
Those are very solid numbers for a 1285cc engine! |
SparksLP Samba Member
Posted: Thu Mar 15, 2018 7:45 pm Post subject: Re: A few more onboard laps...Who needs more than 1300cc? |
What size tires are you running? I am assuming some version of a 165r15 or 155r15? _________________ Tom
1966 VW Beetle Sunroof Sedan |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Fri Mar 16, 2018 10:36 am Post subject: Re: A few more onboard laps...Who needs more than 1300cc? |
what are the gear box specs? Seems very well sorted for a swingaxle car! Little loose in the real tight corners. _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
JeeWee Samba Member
Joined: February 05, 2011 Posts: 120 Location: Garijp, the Netherlands
Posted: Sun Mar 18, 2018 1:49 pm Post subject: |
64vdub wrote: |
Very Nice! That's what it looks like when I go to work |
It is more what it looks like when I am driving home from work
Very respectable numbers for a 1285! What compression ratio are you running? Which venturi size are you running on those mighty 44's? _________________ 1192CC WW okrasa
48,2 DIN PS (58SAE HP)@4430rpm - 83Nm@3610rpm |
boxkiteflyer Samba Member
Joined: May 22, 2008 Posts: 261 Location: Taylorsville, KY
Posted: Wed Mar 28, 2018 6:13 pm Post subject: Re: A few more onboard laps...Who needs more than 1300cc? |
The Cortina seemed to have the upper hand in the straight sections but you definitely had the cornering and acceleration in command! Very cool! Thanks for posting and look fwd to more! |
Posted: Thu Mar 29, 2018 5:49 pm Post subject: Re: A few more onboard laps...Who needs more than 1300cc? |
Do you have any pics of the electric fan/ ram air pipes, please, or is that proprietary? I love watching this vid! It's pretty funny but I find myself leaning into the turns! |
