busmania Samba Member
Posted: Thu Feb 21, 2008 11:29 am Post subject: Who here has replaced a dogleg? (front wheel arch) |
I am looking to replace my drivers side dog leg. Here is the catch. I realize the replacement doglegs are easy to find. However, this one was hit slightly so the floor buckled (about an inch in to where the dog leg meets the floor). So, I need more metal than what comes with the replacements. Should I A) cut out the old dog leg (leg only) and just bend the floor back into shape and use a replacement (new) dogleg? B) cut out a dogleg, plus the floor section, from a donor bus and just do it all as one? I am familiar with welding and have done some body work. I will put up a pic tomorrow of the damaged area.
p.s. yes I searched the threads and found some great info. |
namwv Samba Member
Joined: November 18, 2004 Posts: 80 Location: Indiana
Posted: Thu Feb 21, 2008 12:38 pm Post subject: Dogleg |
Take out the dogleg as planned, leave floor if it isn't rusted and then take a 2x6 and lay flat on two hyd. bottle jacks and jack up to the floor and then use a large flat head mallet to beat back in place. Bus Depot dogleg was great fit, geniune VW. If you know body work it will be a piece of cake. _________________ 79 Sunroof Bus named Olde Leroy
2.0 FI |
cr@M Samba Member
Joined: September 04, 2007 Posts: 1199 Location: Moscow, ID
Posted: Thu Feb 21, 2008 12:42 pm Post subject: |
My neighbor has this crazy pair of pliers designed for flattening out metal. You just cover the whole area with the huge surface area and crush it flat. Might find something like that at Harbor Freight.
I say replace the dog leg like normal, and just flatten the floor back to the original spot. _________________ 1972 Deluxe named Lucidity
1973 Transporter
"He who fights with monsters must see to it that he himself does not become a monster...
when you gaze long into the abyss, the abyss also gazes into you."
-Friedrich Nietzsche
_________________ |
Posted: Thu Feb 21, 2008 12:58 pm Post subject: |
There is a slight section, right where the floor meets the seet base and it curves up, where it is rusted through and crunched beyond repair. Right on the lower left of this part http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211801051KX I think though I can just use a 1"x2" piece of metal and fix that section. Other than that, its mostly just the dogleg and this part that I will be replacing http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211809501CX
Do I even need the last part (the lower dog leg corner) or is it part of the first link with the entire dogleg? I was planning on buying from busdepot. Good choice? Thanks. |
2VWs1BMW Samba Member
Posted: Thu Feb 21, 2008 3:47 pm Post subject: |
Check out Geno's thread. I'm pretty sure he replaced his. _________________ - Brian -
'17 Alltrack
'99 ///M Coupe w/48k mi - Bimmerforums
'77 Westy w/156k mi |
nebe Samba Member
Joined: October 08, 2007 Posts: 450 Location: Rhode Island
Posted: Thu Feb 21, 2008 9:03 pm Post subject: |
I just did both front doglegs and rear wheel arches- its not that hard.
without seeing any pictures, Id say remove your door, cut out the old dog leg and grind away all traces of it.. then put the door back on and tack on the new dog leg so it aligns nicely with the door. Remove door again and weld the dogleg in completely. Then replace the floor section using the new dog leg as a guide to weld in the replacement metal.
If you check out my gallery, there are some pictures of some of what I did. I got a little lazy with the camera and didn't document everything.. |
fourfignewtons Samba Member
Joined: June 25, 2010 Posts: 148 Location: Wilmington, NC
Posted: Tue Jun 18, 2013 11:00 pm Post subject: |
I also need to replace both my front dog legs (front wheel archs). I realize this thread is old but does anyone have pictures of their replacement work?
I'd really be grateful.
Thanks. _________________ 78 Westy "Oscar"
76 Westy "Sam" |
bgoble Samba Member
Joined: February 26, 2011 Posts: 34 Location: North AL
Posted: Wed Jun 19, 2013 5:32 am Post subject: |
fourfignewtons wrote: |
Thanks. |
Ask this guy there are pictures in this thread and he is a very helpful guy.
http://www.thesamba.com/vw/forum/viewtopic.php?t=543445 |
spinster Samba Member
Bntbrl Samba Member
Joined: September 04, 2012 Posts: 436 Location: Seattle, Wa
Posted: Wed Jun 19, 2013 12:22 pm Post subject: |
Post a pic and lets see what it looks like. Im a bodyman so I may be able to give some advice or angles to try. _________________ 1984 Vanagon Westfalia 1.9 wbx
www.DIYSeattle.com |
bugger101 Samba Member
Joined: September 04, 2010 Posts: 1559 Location: orlando
1967250s Samba Member
Posted: Fri Jun 21, 2013 7:35 pm Post subject: |
Find wrstpn 's posts. He just did one. |
Thrasher22 Samba Member
Joined: October 05, 2010 Posts: 858 Location: Calgary, Canada
Posted: Sat Jun 22, 2013 9:27 am Post subject: |
Its all one big solid piece, don't stress! If its a late bay make sure you buy a NOS part (bus depot usually has them), or klassicfab if its an early bay. Once you have the part in hand it'll be obvious what to remove!
On klokkerholm ones that you see everywhere, the curve is incorrect and you won't be able to shut your door (trust me on this). In the wrstpn thread he used one, but cut it into pieces to make it fit. Its worth spending the extra $100.
Drilling all the spot welds out is the hardest part, I just cut mine out and butt/seam-welded my new one in. It will be hidden by the rubber mat anyways. |
