Which Big Brake kit. Van Cafe or Smallcar.
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
qbini
qbini is offline
PostPosted: Tue Jun 14, 2011 10:36 am    Post subject: Reply with quote
kevinm wrote:
qbini, did you have any fitment problems with the Rheins on the G60s? I've heard some light grinding may be required. Did you have to do this?
- Kevin
My rheins did rub on the G60s a bit. I choose to use a T3 Tech 5mm spacer to offset rather then grind - i really didn't like the idea of grinding brake components. The hub-centric spacers are fantastic... they just slip on and the rub went away. The rheins have an offset of ET30, so the 5mm spacer brings them to an offset of 25 - still within original tolerances to not mess up your steering geometry. I did need to buy longer lug bolts to compensate for the additional thickness.
pyite20v
pyite20v is offline
PostPosted: Tue Jul 19, 2011 6:04 pm    Post subject: does the VC / Eurospec kit for the 2wd come with syncro hubs Reply with quote
It looks like it comes with a different hub set up, is this the case? I am asking because I am trying to find wheels that will fit the VC kit, an I found a set of syncro wheels, wondering if once I have the kit installed if I only have to clearance my wheel to syncro specs or if I still have to bore out the fronts for 2wd?
Thanks
Ryan Keating
Ryan Keating is offline
PostPosted: Wed Jul 20, 2011 6:30 am    Post subject: Reply with quote
I went with a set of 16in mercedes wheels. Check out the ultimate wheel post. Then www.t3technique.com will get you all the lugs and studs to set it up. Plus powerflex bushings.
pyite20v
pyite20v is offline
PostPosted: Wed Jul 20, 2011 7:50 am    Post subject: Reply with quote
Getting the right size wheels, I am wondering if offset changes, an if my hub center / dust cap changes so I dont have to clearance the centerbore on my 17" audi rims as much
Jake de Villiers
Jake de Villiers is offline
PostPosted: Wed Jul 20, 2011 10:58 am    Post subject: Reply with quote
My Mercedes C240 16 x 7 wheels clear the Van Cafe brakes just fine. I have a spacer up front to keep the 225/55-16 tires off the upper control arm though.
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
Christopher Schimke
PostPosted: Wed Jul 20, 2011 11:36 am    Post subject: Reply with quote
The Van Cafe/Eurospec kit makes the wheel mounting surface sit 1.5mm further inboard compared to the stock brakes.
To the best of my knowledge, the Small Car kit makes the wheels sit 7.2mm further outboard compared to the stock brakes.
In other words, with the VC/Eurospec kit, you don't have much to be concerned with unless you are already running really tight clearances. The Small Car kit would be the same as running a 7.2mm spacer on top of the stock brakes, so that would have to be taken into account when figuring wheel offsets.
Jake de Villiers
PostPosted: Wed Jul 20, 2011 1:35 pm    Post subject: Reply with quote
Hey Chris, are talking about the SA brakes from Van Cafe or the Audi brakes?
www.thebassspa.com
Christopher Schimke
PostPosted: Wed Jul 20, 2011 2:05 pm    Post subject: Reply with quote
The Audi-based, Eurospec sourced kit, not the OE VW SA kit. I have never seen one of the OE VW SA kits in person, so I don't know if there any offset change or not.
Jake de Villiers
PostPosted: Wed Jul 20, 2011 3:25 pm    Post subject: Reply with quote
I just wanted to be clear - thanks! Wink
www.thebassspa.com
Christopher Schimke
PostPosted: Wed Jul 20, 2011 4:23 pm    Post subject: Reply with quote
And I appreciate that! Sometimes it's easy to get in a rush and forget some details.
Jon_slider
Jon_slider is offline
PostPosted: Wed Jul 20, 2011 6:16 pm    Post subject: Reply with quote
I have VC front brakes, from over 4 years ago.
I've used Mefro 16x6 ET 30, Rhein 15x6.5 ET 30, and CLK 16x7 ET 37, they all fit without any front big brake interference on my syncro, with no spacer.
My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco
photogdave
photogdave is offline
PostPosted: Wed Jul 20, 2011 6:26 pm    Post subject: Reply with quote
Can I ask a real simple question here? If there was already a straight answer to this I missed it.
I have the Van Cafe 15" steel wheels. Can I use the Small Car big brake kit or not?
Thanks!
89 Syncro GL Westfalia 2.1 WBX/WBXaustSS
My Westy Movies:
photogdave On Vimeo
photogdave On YouTube
stclair411
stclair411 is offline
PostPosted: Wed Jul 20, 2011 6:47 pm    Post subject: Reply with quote
Thanks!
I asked SmallCar, and they said no. I went with the VC kit, and also have 15" Mefro wheels. Anyone out there running this combo? Pictures? Thanks!
1987 Syncro Westy "June"
photogdave
PostPosted: Wed Jul 20, 2011 7:41 pm    Post subject: Reply with quote
Thanks!
Thanks! I was going to get the VC brakes when I was down there but I ran out of $$, so I was hoping the SC kit would work.
Guess it will have to wait awhile.
My Westy Movies:
photogdave On Vimeo
stclair411
PostPosted: Tue Jul 26, 2011 7:37 pm    Post subject: Reply with quote
Having a real hard time getting the VC kit to work with my 15x6 Mefros. Going back to stock for now so I can get back on the road. Can anyone recommend a kit that works well with these wheels with no modifications? Thanks!
NorthbyNorthWesty
NorthbyNorthWesty is offline
PostPosted: Tue Jul 09, 2013 6:42 pm    Post subject: Brakes for 17" tires Reply with quote
We have a syncro with 17" tires and want bigger brakes. Anything we need to consider when comparing?
Jake de Villiers
PostPosted: Tue Jul 09, 2013 8:14 pm    Post subject: Reply with quote
Are you working with the later Audi-based kit or the South African brakes? According to Van cafe, the Audi brakes fit the Mefro wheels fine.
I know they fit inside 15" Mercedes wheels, my 15" spare clears just fine.
www.thebassspa.com
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Sun Aug 04, 2013 3:39 pm    Post subject: Reply with quote
Hi everyone who has VC Big Brakes.
What did you do about the hose support where the flex line meets the hard line at the caliper?
Currently:
insyncro
Banned
insyncro is offline
PostPosted: Sun Aug 04, 2013 4:13 pm    Post subject: Reply with quote
I fabricate a mount.
GW uses zip ties.
MsTaboo is offline
PostPosted: Sun Aug 04, 2013 4:28 pm    Post subject: Reply with quote
GW uses zip ties.
Yep, kinda what I figured. Zip ties just don't seem good enough.
I've got the knowhow, but not the equipment, to fab up something nice looking. Guess I'll have to do what I can with a bench vise, pliers, and a drill.
Insyncro- any photos of your mounts for inspiration?
Currently:
Page 6 of 7
