Official GoWesty Engine Feedback Thread
Page: 1, 2, 3, 4, 5  Next
16CVs Premium Member
16CVs is offline
PostPosted: Tue Apr 23, 2013 7:43 pm    Post subject: Official GoWesty Engine Feedback Thread Reply with quote
Moderator note: This is the official feedback topic for all GoWesty-built waterboxer engines, including the new 2.7.
I am interested in comments regarding Go Westy's bigger Engines . I am interested to hear ,total miles ,oil leakage and consumption . Reliability and drive-ability issues . As well as cruise ability ,like going over Donner or Grapevine in California .
Have you re geared or changed your Wheel / tire size up or down to make up for increase displacement .
Warranty issues and if you installed it and maintain it your self . I am not interested in Comments about , Subarus ,bostigs and Tdi's ,Volvo or other non Waterboxer VW engines .
I am buying a 2.5 with 50K on the clock and it burns about a quart in 500 miles . Not a deal breaker ,Still runs strong. I just need to get a course of action to get it repaired . The previous owner said the pistons always had piston slap . I talked to Taylor at GW and he said that is normal because of the dis similar metals . Once warmed up it goes away .
I realize that anything other that with anything other than stock there
are always trade offs .
So if you have a GW 2.3/2.4 / 2.5 . Lets talk about them here . Good bad or indifferent .
Save your negative comments for some else's thread . I know a guy who is pulling a TDi and putting a WBX back in so anything is possible .
Samba member # 14980
Vango Conversions
Vango Conversions is offline
PostPosted: Tue Apr 23, 2013 7:56 pm    Post subject: Reply with quote
There are a few threads about the larger go westy motors. The search engine on here sucks but you should be able to find it.
16CVs is offline
PostPosted: Tue Apr 23, 2013 8:25 pm    Post subject: Reply with quote
I tried , it was painful trying to find enough to read . You have to dig through every post to find anything .
Find me a thread that is direct and I would appreciate it .
Stacy
wildenbeast
wildenbeast is offline
PostPosted: Tue Apr 23, 2013 8:42 pm    Post subject: Reply with quote
Here's some...
http://www.thesamba.com/vw/forum/viewtopic.php?p=6553593
http://www.thesamba.com/vw/forum/viewtopic.php?p=6535766
http://www.thesamba.com/vw/forum/viewtopic.php?t=422689
Instead of using the samba search feature, I typed "site:thesamba.com go westy 2.3" into google to get the links above. Good luck with your research.
Bill
- Bill, '93 Eurovan Syncro Weekender (2.5 manual ACU)
joseph928
joseph928 is offline
PostPosted: Tue Apr 23, 2013 8:52 pm    Post subject: GW motor 2.3 Reply with quote
Blue Bay Bus Love my 2.3, talk about it in one of the other posts. But yes bigger tires 215-75-15 and new gears in 3rd and 4th and new RP -617's and locker. Go Westy did the trans. to, 50,000 miles later all is well! Very Happy
1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug.
Syncronoid
Syncronoid is offline
PostPosted: Tue Apr 23, 2013 8:56 pm    Post subject: Reply with quote
GW2.5 with 13k miles. One year old. Runs like a champ; no problems here. 16" BFG AT wheels. Stock gearing. Usually do 45mph (with a full load) up over Grapevine, Donner, Santiam and Siskiyou Summit. Usually cruise I-5 at 65mph; could do 70mph or more no problem, but what's the hurry.
'90 Syncro Westy w/2.5L GW
Vango Conversions
PostPosted: Tue Apr 23, 2013 9:11 pm    Post subject: Reply with quote
Syncronoid, would you care to share your tire size for the original poster? The rim size doesn't affect the rpm but the overall tire size does, I'm sure this would be helpful to her deciding if different gearing or tire sizes would be beneficial. There are lots of tire sizes that fit 16" rims, some are smaller but most are larger than the stock 185r14.
syncrodoka
syncrodoka is offline
PostPosted: Tue Apr 23, 2013 9:16 pm    Post subject: Reply with quote
The OP is a he. Wink
Good point on tire size being important not rim size, with tire size the overall diameter can be figured out.
Syncronoid
PostPosted: Tue Apr 23, 2013 9:48 pm    Post subject: Reply with quote
Sorry, 215/70-16.
Jedi
Jedi is offline
love my GW 2.2L... Cool
1961 Westfalia SO34 T/BW
1961 Westfalia SO34 SWR
1964 Westfalia SO33 pearl white
1965 Westfalia SO42 Velvet green
1986 Syncro Wolfram grey with black int GL
1986 Syncro Doka
1987 Syncro Sevana beige Adventurewagen
1987 syncro Sevana beige GL
1973 Pumpkin orange Thing
2 1963 Rag top bug's
1965 Manx
1970 Single cab
1971 combi
1990 Vanagon GL
2007 Audi A4 3.2L quattro
shorepig
shorepig is offline
PostPosted: Tue Apr 23, 2013 10:10 pm    Post subject: Reply with quote
Here is my GW engine experience. It's a 2.3L
http://www.thesamba.com/vw/forum/viewtopic.php?t=358928
85 Westy
92 Mitsubishi Mighty Max 4x4 V6
74 Honda CB500T cafe racer
2013 ktm 690r
Sector nine pintail
16CVs is offline
PostPosted: Wed Apr 24, 2013 12:01 am    Post subject: Reply with quote
So what has happened to the present day ? is the van still running ,have you fixed the problem or have you just parked the van ? 2 years is along to have no comments on such a major problem .
Stacy
AtlasShrugged
AtlasShrugged is offline
PostPosted: Wed Apr 24, 2013 8:16 am    Post subject: Reply with quote
The oil consumption is pretty high and should require some investigation. Do it so your trip is more pleasant.
insyncro
Banned
insyncro is offline
PostPosted: Wed Apr 24, 2013 8:27 am    Post subject: Reply with quote
2.2, 2.3....maybe 2.4 Laughing
2.5, an oil drinker and now 50k on it....rebuild pending, IMHO.
gbrandt
gbrandt is offline
PostPosted: Wed Apr 24, 2013 2:10 pm    Post subject: Reply with quote
2.3 with about 25,000 km on it. Runs great, lots of power.
One cylinder has wet sparkplug and blue smoke on startup. GoWesty will honour warranty as soon as I get pictures to them of the heat tabs
Gregor
'Lucky' our 1987 Red Westy, ASV 1.9 TDI, Peloquin differential (had a GW 2.3 that we loved, but it died, we drove it hard!)
We've driven in 49 countries and 5 continents to date
Canada to Argentina and back, January 2015 to April 2017.
Canada to Europe and back (including Turkey, Morocco and Iceland), October 2017 to January 2020
Currently back home.
https://www.instagram.com/live.travel.play/
http://livetravelplay.ca
Vango Conversions
PostPosted: Wed Apr 24, 2013 2:54 pm    Post subject: Reply with quote
Strange that the larger GW engines seem to have oil consumption problems. I bet the previous owner knew what they were doing but if they didn't...
Running a wbx motor with the oil at the max level will cause the oil level to drop down to the 1/2 way point between the full and low marks rather quickly where the consumption usually stops. If they kept the oil topped off that could explain the consumption. If they waited until it gets to the low mark and then they add 1/2 quart and it's still burning a quart every 500 miles, that's a problem.
16CVs is offline
PostPosted: Thu Apr 25, 2013 10:27 pm    Post subject: Reply with quote
So has anyone had theirs apart and done any work on it . Like a valve job or rings or even head gaskets .
These things seem to be so great that no one has had to work on them ,or their warranty is still in place .
I will be tearing into mine in the months to come ,I do not imagine it will be any different then any other WBX .
Hopefully I will just have to source rings and some gaskets sets .
Stacy
slo356
slo356 is offline
PostPosted: Fri Apr 26, 2013 7:59 am    Post subject: Reply with quote
Contact Syncro Safari. I believe he just installed a GW 2.5 approximately within the last 5K miles.
Btw, any engine that has piston slap may be OK, but is a sign of poor tolerancing. It has little to nothing to do with dissimilar metals...think the better manufacturers tolerate it? No way!
'65 T1 Sedan
'87 T3 Syncro Multi-Purpose Vehicle
inkysocks
inkysocks is offline
PostPosted: Mon Jul 15, 2013 1:33 pm    Post subject: GW Basher? Try this: Three bad GW Engines in a row. Reply with quote
For anyone considering a GoWesty engine, consider this: I had three of their engines go bad on me after an average 13,500 miles. I'm diligent with maintenance and have the repair record (and $20k+ in bills) to prove it.
First 2.5L lasted 500 miles. Threw a rod. GW blamed a new guy at the engine builder who blocked a lubrication hole in the crankcase. Replaced at GW's expense.
Second 2.5L threw a rod at about 30k miles. Pro-rated warranty coverage applied to purchase of a 2.4L at a 35% discount.
Third 2.4L showed low oil pressure at 10k miles. Teardown revealed a burnt piston from an overheat (a mechanic screwed up a coolant change in Phoenix, AZ), but also: a warped case, cracked crank, and shot bearings. Karmakanix's head mechanic said those engine-totaling problems were likely because it was sold with a warped case to me initially (the way crank saddles were rehoned provided the clue), but the overheat voided the warranty so I was out of luck, even though overheats don't cause these problems.
Lucas, GoWesty's head, had no explanation of how an overheat caused a warped case, shot bearings and a cracked crank. He offered 50% off another engine if I replaced the entire coolant system, but I was done dropping $10,000 every two years with GoWesty by then. You can imagine why.
If GoWesty's claimed crank failure rate of 1% is to be believed, I'm a 1-in-a-million case. They haven't sold anywhere near that many engines yet, so I don't believe it. I think crank failures are an order of magnitude or two more common than what they let on. Class action lawsuit territory to me.
Be warned. Besides, even their strongest engine only get you 125HP. I'd advise *anyone* to look elsewhere.
markz2004
markz2004 is offline
PostPosted: Mon Jul 15, 2013 1:40 pm    Post subject: Re: Three bad GW Engines in a row Reply with quote
inkysocks wrote:
For anyone considering a GoWesty engine, consider this.
Inky ~ when did these engine failures occur / when did you buy the GW engines? 5 years ago or more recently?
87 Westy, 250k GW 2.4 - 2.0 Wink, 16" wheels
Page 1 of 5
