Love My Westy Samba Member
Posted: Tue Jun 21, 2011 12:40 pm Post subject: |
[email protected] wrote: |
i have a Travel Awn 2000 - (whats the difference with TRANS AWN ... ??)
im looking for gutter bracket for my 1973 westy and maybe later for the Eurovan 1996 (i guess the only way will be thule adapter)
here are some pic:
It looks exactly like my Trans Awn 2000 except for the clamps that hold it closed. No other difference that I can tell, just a different name for the Canadian Model. |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Tue Jun 21, 2011 12:57 pm Post subject: |
I have one and I don't use it... that came with the vanagon I purchased last year |
peasant Samba Member
kamzcab86 Samba Moderator
Posted: Sat Dec 31, 2011 7:47 pm Post subject: |
Someone PM'd me about pictures of the TA-2000 enclosure... many, many months ago. Finally got around to assembling it today, so for those who are interested here it is :
The screen is all one piece; the front slides into the accessory track on the roller and all three sides then zip onto the blue nylon "roof/rainfly" (which has a flap that goes over the awning case). The "flaps" on the ground have holes for staking it down. There is an access/door zipper down the center of the front panel.
The (freakin' heavy!!) vinyl screen covers attach via zippers along the top of the screen, along with Velcro at the bottom and sides. I didn't attach them all, just the right side and one front (which I rolled up).
There is a skirt that runs the length of the awning and attaches to the van. POs used Velcro and it's long since disintegrated, hence the clamps. There is also a cover for the wheel-well... obviously never used, so I attached it with magnets. The floor attaches to all four pieces with Velcro.
Great thing to have if parked in one place for awhile, but not something I'd take on a road trip where I'm always on the move. Since I haven't come across another one, this enclosure must be rarer than the awning itself! (And, no, it's not for sale )
And a few have wondered about this as well... here's a close-up of one of the two straps I use to hold the case cover up in order to open/close the slider door:
_________________ ~Kamz
2016 Golf GTI S
JeffRobenolt Samba Member
Joined: February 25, 2007 Posts: 1513 Location: Wisconsin
Posted: Sun Jan 01, 2012 4:03 am Post subject: |
I haven't read all the post on this thread which might have already answered this but, Why is the awning mounted upside down??
Does the screen room have a part# on it?
That is awesome!!!
Jeff _________________ --------------------------------------------------------
jfats808 wrote: |
Most, some, few is not all. You can always learn something from everyone , even the fool. |
chojinchef Samba Member
Joined: February 17, 2011 Posts: 1539 Location: Central Massachusetts
Posted: Sun Jan 01, 2012 7:20 am Post subject: |
Anyone ever rebuilt one of these?
I have had a couple rivets let go this year and want to re-do the entire thing. I have all of the original parts except for a single clasp that was gone prior to my ownership. And its in good condition, albeit dirty.
Thinking to drill out existing rivets and replace. Give the awning material a good scrub. Clean up the exterior aluminum, especially where a previously sagging mount left a 3 foot wear mark from the top of the slider on the outer case. And maybe paint the end caps.
I am sure a parts source is completly out of the question. _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
carterzest Samba Member
Joined: January 22, 2008 Posts: 3842 Location: Eagle, ID/Sun Valley, ID
Posted: Sun Jan 01, 2012 7:22 am Post subject: |
Mmmmmm, home for BBB
I am counting the minutes
That is quite the awesome unit you have there Kam. Glad I do not have to tote that
That looks HEAVY DUTY! _________________ Happiness=Portland, Oregon in the rearview mirror! |
Posted: Sun Jan 01, 2012 11:02 am Post subject: |
jrobewesty wrote: |
Why is the awning mounted upside down?? |
If you're referring to the case on the van, it's not actually upside down; that's the way all TA-2000 awnings mount (the awning is lifted up and out of the tray). A&E/Dometic obviously improved the design on the TA's replacement.
jrobewesty wrote: |
Does the screen room have a part# on it? |
Not a label anywhere. When I met the 2nd owners last spring, they gave me the instructions for an A&E enclosure. Those instructions have a name (Trim Line) and part number (9472XX.005) with a copyright date of 1997, but inside the instructions state the Trim Line Screen Room is for A&E Trim Line Awnings. The only sections of the instructions that apply to this enclosure is the skirting (illustration matches perfectly) and driving stakes into the ground flap grommets. And there is zero mention of the screen covers. So "Trim Line Sreen Room", I imagine, is not right.
Here's a pic I found of the Trim Line:
^That matches what the instructions have in them (except ^that one zips together at the corners; the instructions show/say it's one-piece like the TA-2000 version), and it's quite different, mounting-wise, from the TA-2000 screen room.
chojinchef wrote: |
Thinking to drill out existing rivets and replace. Give the awning material a good scrub. Clean up the exterior aluminum, especially where a previously sagging mount left a 3 foot wear mark from the top of the slider on the outer case. And maybe paint the end caps. |
"yardbug" and I exchanged our vinyls, which meant disassembling the awning. It's not a big deal... pull the vinyl out of the case (need to remove some screws first), drill out the rivets on the roller caps, pull the vinyl out and go to town. Remember that it's a spring-loaded torsion assembly, so you'll want to rewind, so-to-speak, the roller/spring before reinserting the vinyl. In fact, yesterday, I realized I riveted the end cap back on in the wrong place; no slit at the right end, so the screen room stops short by about an inch after sliding it into the accessory track.
As for new parts, you never know; Dometic might still have some available. If you need something, try contacting them.
carterzest wrote: |
I am counting the minutes |
And, 10 days to go!
carterzest wrote: |
That looks HEAVY DUTY! |
Emphasis on HEAVY! It all weighs a tad more than my inflatable kayak! Hence the reason it's been in a box in my garage the past 2 years. _________________ ~Kamz
2016 Golf GTI S
Posted: Sun Jan 01, 2012 12:50 pm Post subject: |
It looks identical to my Catalina except how the case opens.
I wonder wait it would take to flip the case?? _________________ --------------------------------------------------------
jfats808 wrote: |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9808 Location: Mt Lemmon, AZ
Posted: Sun Jan 01, 2012 1:02 pm Post subject: |
Kam -- Does Phoenix require a building permit to put that thing up? |
Posted: Sun Jan 01, 2012 6:03 pm Post subject: |
jrobewesty wrote: |
I wonder wait it would take to flip the case?? |
More than just flipping the case; the rafter arms would need to be re-worked as well. Do-able, but would take some work.
Ahwahnee wrote: |
Probably... that's why I live in Glendale. _________________ ~Kamz
2016 Golf GTI S
Lavabo Samba Member
Joined: October 28, 2000 Posts: 133 Location: Shawinigan, PQ
Posted: Sun Feb 05, 2012 1:31 pm Post subject: |
im willing to sell my Trans Awn 2000, since i want to go with something lighter . work better on a vanagon than an eurovan or baywindows i think!!
Since its heavy i guess the sale will be more local!!
if interested PM me for a price! _________________ westfalia 1973 / SOLD 2020 |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Sun Apr 07, 2013 10:23 am Post subject: Trans-Awn 2000 installation instructions |
Hey,
I was lucky enough to pickup a Trans-Awn 2000 off CL last summer. It came with 3 A&E Universal Van Adapter Kit mounting brackets and the Econo Room enclosure. I haven't been able to install them yet. I plan to paint them first.
It also came with the original installation and operation manuals. These docs include part numbers, installation and operation instructions and exploded part views.
I've scanned them to PDF but need help figuring out how to store and link to them on Samba. Any advice? |
singletrackflow Samba Member
Posted: Wed Jul 03, 2013 3:41 pm Post subject: Trans-Awn 2000 installation instructions |
I was also lucky enough to pick up a A&E Trans-Awn 2000 (2.5m) this spring in decent condition, and for $20. Mine needed to have a rafter swivel replaced, and I realized pretty quickly that Dometic didn't have parts available anymore.
BUT, the Trans-Awn 2000 design is still being produced by Eezi-Awn as their 2000 model http://www.eezi-awn.co.za/eeziawn/series2000.html and a quick web search led me to a US distributor that can source parts. I used Equipt Expedition Outfitters http://www.equipt1.com/companies/eezi-awn/ to get new roof rack mounting brackets and a new rafter swivel. Paul and Kristen were great to deal with. |
rmcd Samba Member
Posted: Fri Jul 19, 2013 3:26 pm Post subject: Re: Trans-Awn2000 manual |
Thanks for that. And I was all excited about the enclosure/side tent portion, only to read the details about the Econo Room; definitely not what I have. Mystery continues... _________________ ~Kamz
2016 Golf GTI S
rcook52459 Samba Member
Joined: August 24, 2011 Posts: 492 Location: PORTLAND ORE
Posted: Fri Jul 19, 2013 7:08 pm Post subject: |
still have using mine _________________ 85 westy tiico conversion.auto trans triumph TR250 1980 Suzuki GS1000l |
torbot Samba Member
Joined: September 09, 2010 Posts: 121 Location: Michigan
Posted: Sat Jul 20, 2013 7:41 am Post subject: |
Just picked up our new Westy about three weeks ago and had planned to do a DIY awning until we could afford a proper one. As we were leaving, the PO said "Oh... do you want this too? I think it's an awning", and handed us a dirty but perfectly useable TransAwn. were were floored.
One problem: The mounts were still in place, but when the awning is open, the sliding door rubs on the cover. Anyone know how much space there should be between the sliding door and the open cover? _________________ '82 Westy w/2012 Subaru EJ25 (AKA "Dave"). |
debbiej Samba Member
Joined: December 14, 2008 Posts: 1556 Location: las cruces, nm
Posted: Sat Jul 20, 2013 8:30 am Post subject: |
I know of a A&E catilina 2500 by dometic that is on a truck, and is for sale. It is missing a leg, but I've thought of getting it for parts. I ordered the mounting kit, use three brackets. Recently ordered what they called hardware kit, it replaced the brittle broken pieces used to mount the feet of the upright poles to the body of the van. |
Thirstytank Samba Gaucho
Joined: August 05, 2005 Posts: 667 Location: Lake Geneva WI
Posted: Mon Aug 12, 2013 7:29 pm Post subject: |
Any Trans-Awn owners out there using the Vanagon GoWesty brackets?...I see some folks in this thread talking about it, but curious if anyone has had success with them on the Trans-Awn 2000.
Thanks,
Ryan |
