bajorek Samba Member
Posted: Wed Jul 09, 2003 1:47 pm Post subject: please explain hydraulic valve adjustment |
Could someone please explain the adjustment of hydraulic lifters to me so I know what my mechanic is talking about?
Please specify the clearance and the 3/4 turn thing too.
Thanks |
Posted: Wed Jul 09, 2003 2:14 pm Post subject: please explain hydraulic valve adjustment |
You'd probably be best off just looking in at the valves and rockers. It's pretty apparent once you see what is going on in there. Just take a valve cover off when the engine is cool. It is easier than changing the bag on my vacuum cleaner...but a little messier sometimes. Many people recommend putting in a new gasket every time you open up your valve covers. Mine tend to leak with new gaskets and stop leaking once they are bloken in so, I reuse my gaskets until they are shot.
Hans |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Wed Jul 09, 2003 4:10 pm Post subject: please explain hydraulic valve adjustment |
There is no clearance with hydraulic lifters. You start with piston #1 in TDC position then without any slop in the push rod, turn the adjustment screw until it makes contact with the tip of the valve stem then turn the screw 2 more revolutions, then tighten the nut. Turn the engine 180 degrees counter-clockwise and do #2, then #3 then #4. It's really simple to do. |
Posted: Wed Jul 09, 2003 5:18 pm Post subject: please explain hydraulic valve adjustment |
Ahhh 2 full turns after contact- got it. I read something on type2.com that talked about 3/4 turn.
Thanks |
westy78 Samba Member
Joined: August 20, 2002 Posts: 2005 Location: Portland OR
Posted: Wed Jul 09, 2003 5:42 pm Post subject: please explain hydraulic valve adjustment |
Two full turns may be a somewhat outdated way of thinking on the hydro lifters. Personaly I turn mine 1/2-3/4 of a turn past contact.Take a look at Boston Bob's write up on hydros. http://www.bostonengine.com/articles/hydraulicll.htm |
Posted: Wed Jul 09, 2003 8:34 pm Post subject: please explain hydraulic valve adjustment |
I won't dispute Boston Bob but according to the Type2 archives the piston construction within the lifter allows for 4mm of travel. Since the idea is to center the piston using an adjusting screw with a 1mm thread pitch you need to go 2 turns:
http://www.type2.com/archive/type2/021817.html |
