WandS Samba Member
Joined: January 05, 2007 Posts: 228 Location: Miami, Florida
Posted: Thu Aug 22, 2013 12:41 pm Post subject: Should i be able to move the axle between CV Joints? |
Have about 15K on my German Lobro CV joints. After a suspension change and tires last week before a trip, i came back with a weird sound occasionally when going slowly over a curb. Sounds like a clunk from the right rear. About to remove wheel and start checking, but our of curiosity, i grabbed the axle on the driver side of the tranny and tried to move it back and forth. No movement. I then grabbed the axle on the passenger side of the tranny and was able to move it back in forth to each side.
How are the CV joint supposed to feel? I have no torn boots or leaks, all bolts are tight etc.
Cant really get under the car until tomorrow.
No other noises at speed or even higher speed turns.
Thanks everyone. _________________ 85 Westy Weekender with a Bostig Conversion. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Thu Aug 22, 2013 12:47 pm Post subject: |
Yes they will move in and out. Normal. The axles seem to find their own spot to ride. Move them in and out a few times and drive the van again. Sometimes moving them will distribute the grease around. _________________ ☮️ |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Aug 22, 2013 4:03 pm Post subject: |
Yes.
This is why I leave new CV boots loose for the first few hundred miles.
After the axles find their center, I add the clamp or zip-tie.
Otherwise I tended to get the clunking as you describe.
_________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Thu Aug 22, 2013 4:31 pm Post subject: |
dhaavers wrote: |
This is why I leave new CV boots loose for the first few hundred miles. After the axles find their center, I add the clamp or zip-tie. |
I do not zip tie them at the small end -- just leave then free to move. Doesn't seem to be a problem and I have never had a boot failure. |
zeohsix Samba Member
Joined: August 31, 2012 Posts: 501 Location: United States
Posted: Thu Aug 22, 2013 8:10 pm Post subject: |
Ahwahnee wrote: |
dhaavers wrote: |
That may be great for a street van never driven in the rain but if your planning on going off road or through rainy conditions I would definitely seal both ends of the CV boot. |
Vango Conversions Samba Member
Joined: October 04, 2010 Posts: 1054 Location: Seattle, WA
Posted: Thu Aug 22, 2013 9:17 pm Post subject: |
The fact that you can't move the drivers side axle back and forth a bit is concerning. I'd pull it and make sure both cvs are put together right.
Make sure the transmission mount is olted up right, I think you can blt them off to one side.
Otherwise, you can inject grease into the joint with a needle on your grease gun. as long as the boot is in good shape that's the way to go, but since you have no movement, I'd take it apart and check it out. I think if you put the cv together wrong, it won't slide. |
