I made some 40 stainless retaining plate shims. Have a look.
Page: 1, 2, 3  Next
ChipWrecked
ChipWrecked is offline
PostPosted: Fri Aug 23, 2013 7:10 pm    Post subject: I made some 40 stainless retaining plate shims. Have a look. Reply with quote
I know right... good golly another shim thread. This is my second thread so take it easy man.
Yes, the retaining plate shims are necessary.
Yes, they are ridiculously expensive ($10-20 each range) - as they are not easily found in abundance. And yes, over the years, they often end up missing on many vehicles.
While I struggled to source a quad set myself (eventually found two at BD), I looked for options. Aftermarket options did not seem to exist - so I decided to have some machined out of 316L stainless steel. More on that later.
In the meantime; while installing remanufactured ATE calipers, I found the pistons were not properly set to 20 degrees in relation to the rotor. So I made a copy of the ATE caliper tool that I'd like to share here.
I made the following drawing. It can be enlarged to scale, printed, and traced onto heavy card stock and cut out. I made a crude one out of 24g steel.
Where exactly do I position the calipers? Well if you have old retaining plates you have a guide. Those that don't have plates may choose to use the following drawing.
And using the 20 degree caliper tool:
Now back to the shims:
As stated earlier, I was able to get two shims from BD. I used these as templates in creating a CAD drawing to have some professionally manufactured.
And here's the end product:
I installed my shims today, and glad to report they fit great, ensuring a correct piston position.
Hope this thread helps.
SGKent Premium Member
SGKent is offline
PostPosted: Fri Aug 23, 2013 7:41 pm    Post subject: Reply with quote
First - excellent work. That said I am the kinda guy who probably would have waited for the originals, new or used, but the work you did should be fine and just as functional as the originals. Thank you for sharing the diagrams. There may come a day when your way is the only way to get shims that work right.
busdaddy
busdaddy is online now
PostPosted: Fri Aug 23, 2013 7:50 pm    Post subject: Reply with quote
Knowing personally how much of a Biotch SS is to work with that's very impressive, nice work! Were laaaazzzzers involved?
Wasted youth
Wasted youth is offline
PostPosted: Fri Aug 23, 2013 7:53 pm    Post subject: Reply with quote
Nice! I really like the tool. Hadn't thought of that.
Will you be selling the retaining plates?
1968 Double Cab truck, 1973 Auto trans bus, 1978 Auto trans Sunroof bus with A/C and a 1987 Auto trans Westfalia.
ChipWrecked
PostPosted: Fri Aug 23, 2013 8:08 pm    Post subject: Reply with quote
Laaaaaaazzzzzzers too easy...
I used a light saber and a stead hand.
Desertbusman
Desertbusman is offline
PostPosted: Fri Aug 23, 2013 8:47 pm    Post subject: Reply with quote
That's cool. And they arn't going to rust.
It solves 1/2 of the overall problem. Now if you can change the minds of all the folks that think they arn't needed that would be the other major gain.
71 Superbug
71 Westy
ChipWrecked
PostPosted: Sat Aug 24, 2013 8:37 am    Post subject: Reply with quote
Thank you, and yes, I will be selling my my extra ones - I'll list it in the classifieds today. I'm thinkin' $45 for a complete set shipped.
raygreenwood
raygreenwood is offline
PostPosted: Sat Aug 24, 2013 12:17 pm    Post subject: Reply with quote
Very nice! If they would fit my calipers on my 412...i would buy a set!
ChipWrecked
PostPosted: Sat Aug 24, 2013 6:10 pm    Post subject: Reply with quote
I really don't know what other applications these may be used on. If you have an original plate to compare dimensions, my shims, and my type 2 original ones are:
Base is 3"
Height 2 3/4" (to top of alignment holes)
aerosurfer
aerosurfer is offline
PostPosted: Fri Aug 30, 2013 2:36 pm    Post subject: Reply with quote
I bought a set and just got them installed today... just wanted to share some thoughts and observations! I've never seen the originals before as my bus came to me without them, so I have nothing to compare to. My brakes have only about 500 miles on them, so I did nothing but pull the pads and set the shims and put it all back together
Shipping was very quick!
They look just as the pics, no burrs or rough edges. 2 of them were not completely flat when layed on flat surface, but not kinked or badly warped. Could have been manufacturing or even US mail.
The indents did line up very well to the pistons and the plates fit nice and snug. He had marked at least 2 of the pistons with the orientation in marker which had largely rubbed off, but nothing a Bentley and common sense couldn't fix
The holes for the pins are a little smaller than those for the brake pads. Made the first pin a little difficult to make sure it was totally lined up, but the next 3 were expected as such and went together snug.
After a test drive, there was no vibration or unusual steering and my small persistent squeal is gone for now.
All in all a great purchase and happy to have good re-production parts from a local source.
Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone)
ChipWrecked
PostPosted: Sat Aug 31, 2013 11:56 am    Post subject: Reply with quote
Thanks for the feedback on the shims.
On two earlier sets that went out, I marked each shim either: FI, FO and RI, RO thinking this might save time in placing them. But alas it seem to have led to more confusion to the two that received them. So I acetoned the markings off of my remaining stock.
Maybe I should just make a diagram for peeps to save time. Your thoughts?
And yes, I purposely designed the guide holes to be snug to theoretically limit the potential of harmonic vibrations.
Wow, the second half of that sentence sounded like early Pink Floyd lyrics.
Anyway - glad to hear you're squeak free, that they fit well, and are functioning as designed!
Chip
ChipWrecked
PostPosted: Tue May 20, 2014 5:42 pm    Post subject: Reply with quote
Just to update those that have been inquiring, I no longer have any remaining stainless plates. Sorry! Confused
I might get another batch made, but no plans at present.
Keith
Keith is offline
PostPosted: Tue May 20, 2014 7:10 pm    Post subject: Reply with quote
Shit, I totally forgot about these !!! Please make some more and let us know when you do.
If you have no intention of making more ever again can you post the CAD file so one of us can make another run ?
Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind
white74westy
white74westy is offline
PostPosted: Wed Jul 23, 2014 9:55 am    Post subject: Reply with quote
Bump!!!
blackivory69
blackivory69 is offline
PostPosted: Thu Jul 24, 2014 10:01 pm    Post subject: Reply with quote
I probably got the last set. Smile Sorry, I forgot to thank you. They work/fit great! Thanks again.
1970 Double Cab. Stock engine (1600 SP)
1977 Mexican Combi (1600 DP Type 1)
1971 Small Pop Top Riviera (1776 DP, EMPI 38 Egas)
ChipWrecked
PostPosted: Sun Mar 15, 2015 5:04 pm    Post subject: Reply with quote
Well, as luck would have it, I bought another bus (72' Westy) last fall. Sure enough, when doing the front disc brakes, the OEM shims were brittle, rusted, and unusable. Did I have the foresight to keep at least one full set of my stainless shims for personal use? Short answer - no.
So, since I was happy with the shims I've been using in my 71', and need them for my 72', I've decided to make another run.
I'll can have some extras made if anyone is interested. It'll be about 6 weeks.
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Sun Mar 15, 2015 5:06 pm    Post subject: Reply with quote
Haha sometimes we all have to be a little too selfless Smile
Let me know how much you'll sell a set for, I'll probably be in for one.
Summer (and fall, and winter practically,) Tour is wrapping up. Now booking Fall/Winter lessons in Southern California!
www.airschooled.com/learn-to-fix-your-volkswagen
TomWesty
TomWesty is offline
PostPosted: Sun Mar 15, 2015 5:25 pm    Post subject: Reply with quote
What year busses do they fit? Asiab3, does Buddy have disc brakes?
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Sun Mar 15, 2015 5:33 pm    Post subject: Reply with quote
No, but I'm always working on something else for fun, and hoarding specialty parts is a small hobby of mine.
SGKent is offline
PostPosted: Sun Mar 15, 2015 6:15 pm    Post subject: Reply with quote
have you considered making the tool also. Sell a tool, and 2 pair of shims.
I'd buy.
Godspeed to all who undertake a journey in a VW Bus.
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing those right.
It isn't our fault you bought a 50-year old toy you can't afford. None of us can afford it really. Even Steve Jobs had to sell his bus to make his financial life work.
1971 (sold)
1977
Page: 1, 2, 3  Next
