mcdonaldneal Samba Member
Joined: June 13, 2013 Posts: 2648 Location: Gullane, Scotland
Posted: Fri Aug 23, 2013 5:56 am Post subject: 1978 Type 4 engine. Oil from crankcase in paper aircleaner. |
I can't find specific advice on this, so...
For over a year I have had a fair bit of oil in the air cleaner housing, from the hose from the crankcase breather. Not enough to make the paper filthy. Both carbs are black inside and the butterfly's are sticky, slightly improved by aerosol carb cleaner, I always assumed this was unrelated. Engine burns a bit of oil, maybe a quart every thousand miles or so.
Engine is a type 4, automatic, (cj code), 70,000 miles, totally stock, regular servicing from new, but had a bad spell a couple of years ago when it did over 1000 miles on 3 cylinders, overheating badly across Europe and the Alps in Summer, cracked HT lead. Compression test, all just over 100 a year ago.
My plan is to take out the carbs (PDSIT 34 2-3) and send them to a specialist for refurb, but my worry is that if there is an underlying problem they might oil up again (that maybe shows my hazy mechanical knowledge)? I can take it through a service myself but have never tried any job bigger.
QUESTIONS:
1. Is it likely the piston rings are worn?
2. If the engine needs to come out (it will need to go into a garage) is it worth just going ahead and getting them to fit new pistons/ cylinders and exhaust valves?
3. Anything else worth doing if the engine does come out? I've had the van 13 years and am likely to be camping in it for many years yet, so keen on preventative measures!
Thanks for any sensible advice! I'm away on holiday at the moment, otherwise I would attach pictures, but I'm trying to plan my winter maintenance schedule! _________________ 1978 marino yellow Bay Dormobile camper
1969 signal orange Karmann Ghia convertible
1976 martini olive Bay Dormobile camper
Stop dead photo links! Post photos to The Samba Gallery! |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Fri Aug 23, 2013 7:01 am Post subject: |
Sounds to me like it is due for a top end. New p/c's and heads. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
SGKent Samba Member
Posted: Fri Aug 23, 2013 8:13 am Post subject: |
That is called blowby and it is normal especially if you don't have some kind of pre-filter between the engine and air cleaner.
You can add a catch can full of brass wool etc to the firewall and come out of the catch can to the air cleaners. That will cut some of the oil but not all.
Here is a good article on the issue http://www.hamincgroup.com/type4-test.php |
Posted: Sat Aug 24, 2013 4:38 am Post subject: |
The carbs being black could be from backfiring. Oil passing through your crankcase ventilation system will actually lube your choke for you, but this doesn't sound like what is happening.
Are you running a factory air cleaner set up? I am not familiar with the European system, so does the blowby enter before or after the the paper aircleaner element? |
Posted: Sat Aug 24, 2013 5:26 am Post subject: |
Wildthings wrote: |
Thanks. I'll post a pic of the carbs when I get home in a week or two, seems like black carbon to me, hasn't been obviously backfiring other than the odd occasion. The engine was pretty badly out of tune for a year or two thanks to the unreliable mechanic i used to go to before i realised i could service it myself! The paper air filter is between the crankcase breather hose and the carb. _________________ 1978 marino yellow Bay Dormobile camper
Posted: Sat Aug 24, 2013 10:38 am Post subject: |
You can buy PVC fitlers that sit inside the air cleaner. They have a mesh filter that catches at least some of the oil and a tray that gathers the oil and drains it back down into the ventilation hose. The system requires gravity to work so the hose needs a downward slope. Have no idea if you have sufficient room in your air cleaner to add something like this or not. Easy to retrofit if you do.
A filter is just shown in its box in this ad, but here is a listing for one.
http://mx.fram.framautogroup.com/enmx/node/228
In the bottom right of this picture you can barely see one install on my air filter, it is the orange piece.
