Broke Okrasa 82mm Stroker Crank
risk
risk is offline
PostPosted: Thu Sep 05, 2013 7:26 am    Post subject: Broke Okrasa 82mm Stroker Crank Reply with quote
My new canoe anchor...
fivelugshortaxle
fivelugshortaxle is offline
PostPosted: Thu Sep 05, 2013 8:06 am    Post subject: Reply with quote
Nice! Shocked
You've actually got two canoe anchors now! Cool
Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc
jfats808
jfats808 is offline
PostPosted: Thu Sep 05, 2013 10:07 am    Post subject: Reply with quote
Before u toss it , see if Dpr or demello can repair it. Other than tge the obvious, any takes on what caused it? Something fall in the chamber or hydro lock, etc? Oil starvation.
After more looking at it isee multiple cracks on the journals. May not be worth the cost repair if it even can be.
2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
risk
risk is offline
PostPosted: Thu Sep 05, 2013 10:54 am    Post subject: Reply with quote
A little history on this crank..
I bought it from a guy that raced vintage midget circle track cars. It was turned .010 & .010 and the case it was in had some battle scars from losing a rod or piston etc.
I put it all together with new bearings etc, and it ran great for about a year or so... then I put the turbo on and it ran even better.
Earlier this year I overboosted/detonated and cracked two cylinders... I replaced the cylinders and rings and ever since it had oil pressure issues, and would lose prime.
I think it had a hard life on the dirt track... but I probably put the last nail in the coffin when I popped those cylinders.
risk
risk is offline
PostPosted: Thu Sep 05, 2013 10:55 am    Post subject: Reply with quote
fivelugshortaxle wrote:
Nice! Shocked
Big end for the canoe, little end for the kayak haha
fivelugshortaxle
PostPosted: Thu Sep 05, 2013 11:02 am    Post subject: Reply with quote
Nice! Shocked
hahahaha
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
Quokka42
Quokka42 is offline
PostPosted: Thu Sep 05, 2013 1:41 pm    Post subject: Reply with quote
I think it's a bit mean to be making jokes.
There has only ever been one man who was perfect, and they nailed Him to a cross.
HRVW
HRVW is offline
PostPosted: Thu Sep 05, 2013 1:45 pm    Post subject: Reply with quote
Smile Those mains look like a oil starving problem.
Get a case of JB Weld and make it into a lamp and smile every time the lamp light up.
Quokka42
Quokka42 is offline
PostPosted: Thu Sep 05, 2013 1:56 pm    Post subject: Reply with quote
Oh, I think the OP got it a heavily overboosted engine can have one cylinder firing on the upstroke while the next is firing on the down...
jfats808
jfats808 is offline
PostPosted: Thu Sep 05, 2013 2:05 pm    Post subject: Reply with quote
You should reread my post dude.
Quokka42
Quokka42 is offline
PostPosted: Thu Sep 05, 2013 2:24 pm    Post subject: Reply with quote
Oh, lighten up. I was being facetious.
I do actually feel sorry for the guy, in fact I almost shed a tear myself at the death of an Okrasa.
Boolean
Boolean is offline
PostPosted: Thu Sep 05, 2013 2:29 pm    Post subject: Reply with quote
Fatigue. The beachmarks center around the oil hole.
I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379
RLFD213
RLFD213 is offline
PostPosted: Thu Sep 05, 2013 3:13 pm    Post subject: Reply with quote
That's not broken. It's a 2 piece racing crank.
ralf
ralf is offline
PostPosted: Thu Sep 05, 2013 3:39 pm    Post subject: Reply with quote
3r/last pic of the OP's post
notice the non broken side of the journal's shoulder
crack evident.... gues if it didnt crack where it did now
it would have cracked on the other side of the same journal
Flow Through a Curved Conduit
porting my SP head for my brother's project
https://youtu.be/OS_mVjQuqgk
esde
esde is offline
PostPosted: Thu Sep 05, 2013 6:13 pm    Post subject: Reply with quote
Was the center main beat into the case very badly?
Did you have the crank magnafluxed before running it? Did you align bore the case before running it?
Bubba & Waynes Drag C
Bubba & Waynes Drag C is offline
PostPosted: Thu Sep 05, 2013 7:01 pm    Post subject: Reply with quote
that will buff right out
fastone
fastone is offline
PostPosted: Thu Sep 05, 2013 9:20 pm    Post subject: Reply with quote
That's not uncommon to see with Midget cranks constant RPM's in those cars is 5000 to 8500.
I worked for Auto-Craft in the 80's and have seen many come in with cracks in the center main.
There is a reason people say you need a type 4 center main Wink
drumbum68
drumbum68 is offline
PostPosted: Fri Sep 06, 2013 8:24 am    Post subject: Reply with quote
Okrasa's had aluminum plugs?
tattooed_pariah
tattooed_pariah is offline
PostPosted: Fri Sep 06, 2013 8:37 am    Post subject: Reply with quote
meh, some JB Weld will fix that right up.. Cool Wink
-pariah (just a novice from "that other VW site")
'72 Volksrod "Effigy"
"Never worry about stepping on people's toes. People who get their toes stepped on are either sitting down, or standing still on the job."
-Admiral Arleigh Burke, USN(ret.)
