DiggerD Samba Member
Joined: August 11, 2006 Posts: 278 Location: North Georgia
Posted: Thu May 16, 2013 7:23 pm Post subject: |
grifspop wrote: |
Looks good- did you shorten the lug bolts yet? I need to shorten 8 of mine on the Oval |
Yeah, I trimmed them to size with a cutoff wheel. They are flush with the inside of the drum when tightened down. Went over to Two Bros and got the tires mounted the other day. _________________ 63 Beetle
66 Deluxe Bus |
grifspop Samba Member
Joined: May 16, 2007 Posts: 144 Location: Someplace you wouldn't think to look
Posted: Fri May 17, 2013 10:11 am Post subject: |
JonnyCakes wrote: |
grifspop wrote: |
Yeah, I trimmed them to size with a cutoff wheel. They are flush with the inside of the drum when tightened down. Went over to Two Bros and got the tires mounted the other day. |
Great- those guys know how to mount a tire without damaging the wheel _________________ Experience is a hard teacher because she gives the test first, the lesson afterwards.~Vernon Law
1957 Beetle "the Mistress"
1958 Speedster Replica "Thor"
To put your finger on the pulse of the Southern Volkswagen movement, click on http://forum.georgiadubs.com/ |
Posted: Wed May 22, 2013 7:32 pm Post subject: Tina |
Did your rear plates come in yet? _________________ Experience is a hard teacher because she gives the test first, the lesson afterwards.~Vernon Law
Posted: Tue Jun 18, 2013 10:04 am Post subject: Tina's resurrection |
Video of the engine starting after 27 years
roonster Samba Member
Posted: Wed Jun 19, 2013 5:23 pm Post subject: |
Awesome find ! |
Joined: June 14, 2002 Posts: 1663 Location: Palominas AZ
Posted: Sat Jul 06, 2013 7:41 am Post subject: |
Very cool! _________________ Ryan
1963 Beetle
Posted: Tue Jul 09, 2013 6:05 pm Post subject: |
Started working on the engine compartment this week.
The original tarboards are in pretty good shape so I'm going to heat them up and see if I can flatten them back out.
66 Deluxe Bus |
Posted: Thu Jul 11, 2013 7:27 pm Post subject: |
Some pics of recent progress....
Got the tarboards straightened up by heating with a paint stripper gun and sandwiching them between some plywood with weights on top. Painted with satin finish black and re-installed:
All the stainless trim is installed:
Finished up with the tailight,turnsignal, and taglight seals:
66 Deluxe Bus |
62ItalianRagtop Samba Member
Posted: Tue Jul 30, 2013 1:53 am Post subject: |
Damn it is so cool _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/ |
potato_salad1 Samba Member
Joined: May 11, 2010 Posts: 20 Location: Fort Oglethorpe, GA
Posted: Tue Jul 30, 2013 6:48 am Post subject: |
love the bug. Where in North Georgia are you located? |
Posted: Tue Jul 30, 2013 8:23 pm Post subject: |
potato_salad1 wrote: |
Thanks! I am between Lawrenceville and Athens. _________________ 63 Beetle
66 Deluxe Bus |
gostros Mr. Obvious
Posted: Tue Jul 30, 2013 9:40 pm Post subject: |
Fantastic car. I'll be checking on this thread. |
Posted: Wed Jul 31, 2013 4:43 pm Post subject: |
Got her up on stands tonight to get started on the rear. The plan is to pull the backing plates to get powder coated, install all new brake components and hoses, drain tranny, replace axle boots. Might replace rear wheel bearings and seals while I'm in there as well. Then install drop plates and new bushings and shocks.
Got out the BF Torque Wrench to remove the axle nuts.......... no problem!!
Makes even the most stubborn axle nuts a breeze, these were not bad, I could almost break them free with one hand!
Rear brakes as found:
66 Deluxe Bus |
Posted: Thu Aug 01, 2013 6:49 pm Post subject: |
Stripped off all the tin from the engine to send over to the powdercoater along with the muffler, heaterboxes, pulleys, valve covers and intake manifold.
66 Deluxe Bus |
Posted: Thu Sep 05, 2013 6:18 pm Post subject: |
Haven't added to this thread in a while since most of the stuff I have been doing were mundane, boring little things. So here are a few updates. Last weekend at Volkstock with the help of a few aircooled friends, the valve springs were replaced with new and the carb was cleaned and rebuilt.
I sent the tins and some other bits and pieces to get powder coated. Picked them up this afternoon:
Started reassembly of the fan shroud:
and the generator:
I even went as far as duplicating the little dab of white paint that originally sealed the regulator screw.
The stale air muffler is now ceramic coated:
Next up will be this............
66 Deluxe Bus |
Posted: Thu Sep 05, 2013 6:20 pm Post subject: |
Got the stale air heater boxes reassembled:
and started to test fit the tin until the new cheesehead screws come in:
66 Deluxe Bus |
Posted: Sun Sep 08, 2013 1:49 pm Post subject: |
Wow- the engine case cleaned up real nice, too _________________ Experience is a hard teacher because she gives the test first, the lesson afterwards.~Vernon Law
Stephan Schmidt Samba Member
Joined: March 26, 2002 Posts: 213 Location: Vancouver, BC, Canada
Posted: Wed Feb 05, 2014 11:55 am Post subject: |
WOW! This is a fantastic thread! Keep up the good work! |
Daniel G Crazy Amish Guy
Joined: April 23, 2004 Posts: 828 Location: Central Alabama Amish Country
Rich's 50 Samba Member
Joined: February 18, 2004 Posts: 10781 Location: San Diego, CA
Posted: Thu Feb 06, 2014 2:37 pm Post subject: |
It's getting there. |
