djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32634 Location: Reading Pennsylvania
Posted: Thu Sep 19, 2013 6:33 am Post subject: In Dash A/C |
Ok, I know that there are threads on retrofitting AC into a Vanagon dash.
I want to go on to a differ vein here.
I've got "factory" air in my van. takes up the entire rear area above the rear bed. I'd like to utilize that storage space and i, told it doesnt work very well. it freezes out the back seat while the front passengers roast! I've no rear passengers to worry about but I want to be cool up front, just like i am in my modern sedans I drive. Cold air blowing on my face and sweat free!
I want to Keep things stock. Utilize Same heating system, using the same controls......... just add AC with as few modifications as is possible leaving the dash when finished as factory as it looks now.
What I've discovered on my Internet search.........
Behr at one point offered a aftermarket kit, but I've never seen one or pictures of one.
small car.com offers an installed retrofit inside the dash.
http://www.smallcar.com/index.php?dispatch=pages.view&page_id=62
This sets one back just shy of $4000! It also relocates the radio and kind of "messes" up the stock dash but not badly.
https://sites.google.com/site/blakeheinlein2/vanagon-airconditioning ........ Installed an entire Heating/Cooling assembly from Vintage Air replacing the stock air handling unit. The issue with this is how badly the dash was modified with a repurposed instrument cluster to hold the radio! Not at all attractive.....SORRY!
I did snag a few photos of his installation to help me illustrate what I want to do.......... Thank you! See all his photos at this link.......
http://picasaweb.google.com/blakeheinlein/VanagonAirConditioningInstall#
Ok, I'm looking at Vintage Air......
http://www.vintageair.com/2012catalog/2012%20Vintage%20Air%20Complete%20Catalog%20web.pdf.
And I'm looking at the Special Applications section, specifically the 05000-VUX-A.
I removed my glove box and doing some measuring I can get this unit in there above the reinforcement rail if I trim the top of the mating flange off. Not the flange, just the extra metal above it...........
The only issue is that the unit is 16" long. It fits...... But without a lot of wiggle room.
I will also need to lengthen and reroute the passenger side vent hose.... Easy, no biggie.
The unit is also tall but I called the company and that top plenum is just plastic, plastic I do not need. So if I cut off all of the individual outlet ports that will leave me with one large square outlet port.
Depth is fine, I'll need to trim the glove box losing a good portion of it but that is minor loss! I can creat a new drawer glove box utilizing that space under the front seats! ................
I've located another unit that doesn't have the heater core in it and is just AC. The unit is the same height and depth but is only 13" long...........
It is from Old Air Products and just the Evaporator IP2000-T is $575, well above Vintage Airs unit at $375!
Excuse the picture, best that is available but it looks very similar to the Vintage Air unit.........
Ok, WHERE IS THE COLD AIR GOING TO GO???
Well, here's what I'm thinking........
The heater assembly is mounted mid dash behind the radio, above the crash reinforcement and against the front of the car.
There are two triangle holes that let in the fresh air for the heater.......AND THE MICE!!!!...........
Unit removed showing holes.........
Here is a close up of the Passenger side of the unit, see the round hole? That feeds the passenger door vent. Inside that hole is a flap to open and close the fresh air intake. The is a large triangular space where the unit mounts to the dash holes, this space is where the mice build nests. ...............
On this photo that triangle is in the area of the red circle saying "screw". The pin above the round hole is the hinge for the air flap.........
I plan on cutting out that triangle plastic and making an input duct from the Evaporator to this new hole, I will do both sides if needed.
A disassembled air box to help visualize what I intend to do......
Not having a way to shut off and turn on the fresh air and to prevent the hot outside air from diluting my expensive cold air, I will simply close up those holes that provide fresh air making a system that only recirculates cabin air.
I imagine you could create a new flap system to control this but honestly, I almost always recycle interior air in both the Winter and the Summer. I would lose out on the cool fresh air in those times when you don't want heat or AC, but that's a small price to pay for good AC.
Similar to these photos ............
(In process, just didn't want to lose this)
Ghia
Vanagon
Beetle
Summers420us Samba Member
Joined: June 14, 2010 Posts: 759 Location: Amissville, Virginia
Posted: Thu Sep 19, 2013 6:47 am Post subject: |
Neat idea. All the front AC options I have seen are pretty pricey. Is cost point a factor for you? Watching with interest. _________________ 1997 EVC
1988 2WD Westfalia with OE 2.1 (R.I.P.) |
DLJ Samba Member
Joined: August 05, 2008 Posts: 555 Location: North California
Posted: Thu Sep 19, 2013 9:07 am Post subject: air |
I understand that the Behr Air conditioner is pretty good. There are a few people I know that are installing them now and I anxiously await their results.
I have a complete Behr that I was going to install in my syncro,but have decided not at this time. Lots of work.
Behr can be purchased when available for $200.00 to over $400.00. Check Samba want ads. |
costal_cat Samba Member
Posted: Thu Sep 19, 2013 10:12 am Post subject: |
Is the need for the AC system up front simply that the AC isn't working well that exists or you do not have one?
In my 87 westy the AC is damn cold my wife and daughters are always asking to turn it down.
One thing I did do was take the vent in the back closest to the closet and made a plastic cover. I took out the vent and took a piece of rubber hosing and inserted that well into the AC enclosure. From there I ran the hose along side the little storage rail above the stove and drop it down right above the driver seat. The cold Air is then dumped right into the front of the Van. I added a 12v Fan right there attached to that same storage rail that helps move it around.
The air flows out strong on 4 and 3 and as expected is a little weaker on 2 or 1 with the AC fan. I should note that in the summer I also block off the fresh air from the outside.. Even on the hottest NC summer days I run very cool so much so that I would never look at the cost of an AC up front unless it was a super easy $200 thing.
Pretty simple set up took maybe 15 mins to do.... _________________ 87 Syncro Westy
TDI Overland Parts engine conversion |
Posted: Thu Sep 19, 2013 10:16 am Post subject: |
costal_cat wrote: |
Pretty simple set up took be 15 mins to do.... |
Pictures?
My unit is old and rotten needing an upgrade anyway. When I am finished I will have a new 2013 AC system in my Van. New Compressor, pipes, hoses, rec/dryer, condenser, evaporator and controls...... All designed for 134a.
Early number crunching has me at well less than $1500!
Plus...... I will gain significant storage space.
Ghia
Vanagon
Beetle
Posted: Thu Sep 19, 2013 10:24 am Post subject: |
djkeev wrote: |
costal_cat wrote: |
Pictures?
Dave |
Sure. I'm at work but when i get a sec i will run down to the parking lot and snap a few..... _________________ 87 Syncro Westy
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Thu Sep 19, 2013 1:06 pm Post subject: |
Here's my DIY front AC system. Since you already have the compressor and condenser, it should be easier for you than for me since my Westy did not have AC to begin with.
I have actually been curious as to how much interest there would be if I made a kit for this install. I would have to get a plastics shop to make an injection mold or make a fibreglass mold to replicate the tight fit needed for the evaporator box.
I would do two different kits, perhaps three. The "A" kit would be for installing front AC in a vanagon with factory AC. The "B" kit would also be for a factory AC Vanagon, but allow the user to retain the rear AC and add the front AC unit. The "C" kit would be for front AC on a non-AC van.
The idea would be to provide a complete kit for any such install together with proper instructions. Anyone wanting to replicate my design in my thread (see here: http://www.thesamba.com/vw/forum/viewtopic.php?t=535444&highlight=diy+front+air+conditioning ) is welcome to do so, (if you are as frugal as me), but I think there might be some interest in a plug-and-play solution for the Vanagon. This would not be a charity for me, but I would price competitively.
Anyone installing a front AC system has to take into account the tremendous importance of re-sealing the factory heater/air distribution box to prevent ambient air ingress and installing a proper heater control valve to keep all hot coolant out of the front heater core.
This unit has unbelievable cooling power as I have installed it, but I used an aftermarket high-efficiency condenser and also used RedTek as a refrigerant. _________________ '86 Syncro Westy SVX |
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1649 Location: Between Here and There
Posted: Thu Sep 19, 2013 1:12 pm Post subject: |
I'm very interested in the C kit, competitively priced. I have a non-AC '84 westy.
Would that include the stereo housing pictured so the driver could still reach the controls?
Would that do away with the front heater source then?
Plug and play is nice... _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
Posted: Thu Sep 19, 2013 1:37 pm Post subject: |
My system (and any kit I would make), is configured as follows:
1. The factory heater and heater box is retained.
2. The outlets from the heater box to the far right and far left vents are not used and instead, those vents are used for AC air.
3. The AC flows out of 4 vents being the two existing ones plus two added at the centre;
4. I could replicate the Audi part that my radio sits in. I got it at an Audi "pick-n-pull". I have never seen another one before nor since. This requires a fairly large opening to be cut into the dash, but looks fairly "factory".
5. I now know how to make my install work with a completely stock Vanagon heater/air box. I modified mine for clearance, but later determined I did not need to.
6. I specifically decided not to go with electronic flap controls because I like the Vanagon factory system that allows you to blend floor heat flow, defrost flow, and heater temp. Electronic mode controls are usually on/off, not blending.
7. My AC system is not at all connected to the Vanagon heater box and runs as a stand-alone, but is a great de-humidifier to use on foggy/rainy days along with the running the factory windshield defroster at the same time.
8. I used switches in VW or Audi bezels to look "factory". I covered a hole in the dash face (from the old cig lighter location) with an escutcheon and 12V outlet from a '90's Audi.
If I made a kit, I would want to simplify and integrate a bunch of parts that I made by hand. _________________ '86 Syncro Westy SVX |
Posted: Thu Sep 19, 2013 2:10 pm Post subject: |
Like it! AC will make our van livable for the rest of the family. _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
NorCalbuggy Samba Member
Joined: March 06, 2006 Posts: 126 Location: Tracy, California
Posted: Thu Sep 19, 2013 6:35 pm Post subject: |
I would definitely be interested in the "B" kit - that is, once I'm done repairing the rear A/C.
No such thing as too much cool air! _________________ "Steam seems to have killed all gratitude in the hearts of sailors"
1987 Westfalia Vanagon - "Clifford" |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1890 Location: Montreal
Posted: Thu Sep 19, 2013 7:00 pm Post subject: |
Can you describe what variation B would entail |
scubabrian Samba Member
Joined: June 11, 2008 Posts: 117 Location: San Diego, CA
Posted: Thu Sep 19, 2013 8:11 pm Post subject: |
The Vintage Air Gen II will fit in place of the stock heater core/box and will provide heat and AC. Some have said that you must relocate your radio with this installation, however I found that not to be the case and that there is sufficient room for the radio installed in the stock location. You do need to install a duct in place of the ash tray with this set up. Works pretty well for me. _________________ Brian
85 Westfalia with 2.2L Subaru
brian-mchugh-uwphoto.com |
Crankey Samba Member
Posted: Thu Sep 19, 2013 9:26 pm Post subject: |
Howesight I could be interested in your kit.
I have a non AC rig and a good AC compressor from a subie install. I also just had my heater box rebuilt so that's all good. I was considering a Vintage Air heat/ac unit for some later time.
also was considering how I might make my instrument cowl wider so the radio would fit inside it. or one of those full with dash toppers with the flip out desk thing to add room for venting.
also you might consider vaccufoming a pair of shells for the air box like the heat box. seems like less work then laminating fiberglass or injection.
Red Beard Samba Member
Joined: May 09, 2006 Posts: 463 Location: Seattle, WA
Posted: Fri Sep 20, 2013 11:12 am Post subject: |
I think it would be AWESOME to move the stock rear AC to the front, thus freeing up the overhead storage space in the back. I would spend up to $350 on a kit to do this. |
rumitcu Samba Member
Joined: February 12, 2008 Posts: 97 Location: Boulder, CO
Posted: Fri Sep 20, 2013 11:37 am Post subject: |
I'm interested in option "A". _________________ 85 Westy with Bostig V2.0 & private beta turbo
Boulder, CO |
Posted: Fri Sep 20, 2013 11:45 am Post subject: |
Red Beard wrote: |
Hi Redbeard:
There is no way I could meet that price point with an actual plug and play kit. Part of the reason is the front AC install does involve long hose runs and fittings I would supply and the barrier hose is not cheap. I would also want people to have a reliable, long-lasting system, meaning a focus on eliminating possible failure points. I think the aftermarket units are a good stop-gap, but the ducting is inadequate for really high air flow out of the vents, which is why I put a lot of effort into large, smooth ducting and a large evaporator fan on my prototype.
For those wanting to have both the factory rear AC and front AC, the layout would involve using a solenoid valve in the liquid line to control refrigerant flow to the existing rear evaporator, enabling it to be left switched off and/or set at a lower temperature setting when desired. The suction line would also have to be extended all the way to the front evaporator. The receiver/drier would be re-located near the condenser, and the front evaporator would use a CCOT system and an accumulator.
There would be two separate thermostats.The solenoid valve would be connected electrically to the factory thermostat for the rear evaporator instead of having the rear AC thermostat control the compressor function. Compressor on/off cycling would be controlled by the front evaporator thermostat. You could not run the rear evaporator unless the front AC evaporator was being used. This is the way most dual zone front/rear systems are set up, since there is always a driver in front, but not always rear passengers.
In testing on our trip to the Bay area in August, we encountered 95 degree ambient in a few spots with a bright sun adding to the mid-day heat load. By aiming the centre ducts rearward and having the front evaporator blower fan on highest speed (an admittedly loud setting), our ornery teenager in the back bench seat was comfortably cool. By this I intend to dissuade all who do not live in exceedingly hot areas to add rear AC unless they are really certain they need it.
Anyway, before we all get too carried away, I need to do a few calculations before getting even a rough sense of price IF I decided to create and offer such a kit.
Anyone with a non-AC or non-Syncro vanagon would also find that they have the smaller, weaker, rad fan and should upgrade to the larger version. _________________ '86 Syncro Westy SVX |
woggs1 Samba Member
Joined: February 22, 2007 Posts: 531 Location: South Pacifica California
Posted: Fri Sep 20, 2013 11:54 am Post subject: |
I would be very interested in the A kit, very. _________________ 4 speed 88 Westy |
shizzon Samba Member
Joined: July 25, 2006 Posts: 596 Location: Boulder, CO
Posted: Fri Sep 20, 2013 12:09 pm Post subject: |
scubabrian wrote: |
The Vintage Air Gen II will fit in place of the stock heater core/box and will provide heat and AC. Some have said that you must relocate your radio with this installation, however I found that not to be the case and that there is sufficient room for the radio installed in the stock location. You do need to install a duct in place of the ash tray with this set up. Works pretty well for me. |
Could you share some pictures of this!
I would be in category C of howesights setup. But have also had thoughts about either the GenII or Gen IV from nostalgic air. One big hesitation has been relocation of the radio location.
Howesight, does your system still allow fresh air intake? _________________ 1989 Bostig Syncro Westy |
Posted: Fri Sep 20, 2013 12:15 pm Post subject: |
"Howesight, does your system still allow fresh air intake?"
Yes, but not through the evaporator - - through the factory air box. _________________ '86 Syncro Westy SVX |
