Cables near CV joints
Page: Previous  1, 2
Ron Domeck
Ron Domeck is offline
PostPosted: Wed Sep 18, 2013 4:51 pm    Post subject: Reply with quote
I think you guys are making this way to hard. Any Beetle cable will work, just cut to size and bend a hook on the end. If you have one with two cables like a long Beetle cut one side off.
safariboy
safariboy is offline
PostPosted: Thu Sep 19, 2013 9:51 pm    Post subject: Reply with quote
OK Semper Dude
Here are some pics
Not much left here to connect to. How do they attach to the box?
SB
tallman206
tallman206 is offline
PostPosted: Fri Sep 20, 2013 3:38 am    Post subject: Reply with quote
Someone has cut off the tails of your cables and bent back the stub ends to keep the rubber weather seal from falling off. Best option is to replace the entire cable set, which is item 5 in the previous parts diagram. I have seen some creative work where persons have extended the stub ends with mechanic's wire, if the remaining ends are long enough. However, it appears that these cables are the least of your problems, as it appears your engine doesn't even have heater boxes on it for the cables to attach to!
Jerry Henning
Southern Classic Works
St.Petersburg, Florida
1973 VW Type 181 with 616/33-6 powerplant
1962 356B-T6 Cabriolet Rustbucket
citroen
citroen is offline
PostPosted: Fri Sep 20, 2013 5:31 am    Post subject: Reply with quote
you also need cy joint boot replacement. Also if this a picture of a thing it looks like you have a bus transmission not a thing transmission I think it is a 68 bus transmission from the picture.
Semper_Dad
Semper_Dad is offline
PostPosted: Fri Sep 20, 2013 7:23 am    Post subject: Reply with quote
Doesn't appear you have heater boxes any longer. There's nothing there to connect those cables to.
Heater boxs (exchangers) look like this
You can see the lever the cable gets attached to on the upper left of this one.
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
safariboy
PostPosted: Fri Sep 20, 2013 2:00 pm    Post subject: Reply with quote
Semper
Ugh! Yes I don't have heater boxes. I purchased this one in Long Beach CA where I don't believe they needed them.
Citroen or Semper
The comment that I may have a 68' Bus tranny is interesting. Is the a specific charteristic/tranny code that would be able to let you guys know what type/year tranny I have?
citroen
citroen is offline
PostPosted: Fri Sep 20, 2013 3:25 pm    Post subject: Reply with quote
just give us a picture of the transmission
Page: Previous  1, 2
Page 2 of 2
