Manx Lee Samba Member
Posted: Thu Sep 19, 2013 12:38 pm Post subject: Manx build |
I am still working on the body when work allows... it is a lot of sanding filling Repeat ! I beefed up the headlight area as mentioned by Surfnc. I then went to the back to fill various holes including the license plate area and taillights I will be using the original type 1s that I have. |
Posted: Thu Sep 19, 2013 4:49 pm Post subject: |
as mentioned I still have a ways to go I got some more items for the buggy after sleeping on it for a while I decided to stay VW.to be exact
manxdavid Samba Member
Joined: November 24, 2003 Posts: 1841 Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
Posted: Fri Sep 20, 2013 6:41 am Post subject: |
A Waserboxer? Odd choice for a Buggy, where are you going to mount the radiator?
What does your id plate read? Does it end -1? That mix of Manx 1 body and Manx 2 hood is rare but not unique. |
Posted: Fri Sep 20, 2013 8:01 am Post subject: MANX 1 |
manxdavid wrote: |
The radiator will mount to the firewall the number is M3379c020E-2
march 70 It is a manx 1 |
Kreelak Samba Member
Joined: September 19, 2011 Posts: 122 Location: Ridgefield Washington
Posted: Fri Sep 20, 2013 8:56 pm Post subject: |
heres some pictures of a buggy off of manxmaniacs web sight in the Uk with the Rad in the front and a Wasserboxer out Back
owner goes buy the name AgentOrange
http://www.manxmaniac.co.uk/index.php
Posted: Fri Sep 20, 2013 11:44 pm Post subject: |
A lot of work for questionable gain IMHO. |
Posted: Sat Sep 21, 2013 6:08 am Post subject: |
Kreelak thanks for that link
David, 60-80 hp over the 40 hp it had does not seem questionable to me.
Lee |
Posted: Sat Sep 21, 2013 8:52 am Post subject: |
Duguda Duguda wrote: |
Lee |
Sure, a good enough engine when new but they suffer from serious internal corrosion issues if not meticulously serviced. I'd choose a Type 4 motor over it any day plus no radiator and plumbing required, but that's just me. |
Posted: Tue Sep 24, 2013 12:38 am Post subject: |
manxdavid wrote: |
Lee |
This is true for any engine.. I am fine with my selection thanks |
martinprice2004 Samba Member
Joined: April 23, 2013 Posts: 37 Location: United Kingdom
Posted: Tue Sep 24, 2013 5:20 am Post subject: |
I'm not really familiar with these water cooled flat fours, but, I do attend a lot of shows in the UK and Its always nice to see something different. If you are worried about corrosion in your engine, there is a perfect solution for you
http://www.evanscoolants.co.uk/
The fluid is waterless, has a really high boiling point and doesn't need changing. Its ideal for a new build as there is no need to flush out the residue.
It also has the added bonus in that you can still say your buggy isn't water cooled! _________________ My website www.HeliumFrog.com |
frizzardking Samba Member
Joined: May 09, 2011 Posts: 575 Location: BUFFALO N.Y
Posted: Tue Sep 24, 2013 6:25 am Post subject: manx 2 |
Duguda Build how ever the Heck you want to build its your Buggy , everybody has two cent But its yours and build it to your specks that will make you loveit and enjoy it ! Its a Dune Buggy everyone is a little Different!, You can always change it down the road! |
mstevens Samba Member
Joined: January 16, 2008 Posts: 225 Location: Boise, Idaho
Posted: Tue Sep 24, 2013 7:44 am Post subject: |
Looks like you are doing some great work. I am glad to see the Manx is coming back alive! |
Posted: Tue Sep 24, 2013 7:55 am Post subject: |
Martin, yeah we have that in the states a lot of diesel guys use it thanks!
Frizzard, exactly its nothing that cannot be undone..
Mike , yeah I am getting there thanks again! |
Joe VW Samba Member
Joined: January 02, 2005 Posts: 134 Location: Vermont , Okemo
Posted: Mon Sep 30, 2013 2:43 pm Post subject: |
manxdavid wrote: |
Lee |
The irony of your statement: type4 was replaced in the Vanagon with the waterboxer due to a very short lifespan unless babied it's whole life.
I have owned both air and water cooled and the watercooled is a far better engine. Most often the bad rap comes from someone buying a used high mile vanagon with leaking heads only to find themselves spending another 2,000 dollars to fix it. buyer beware. On the other hand most every type4 vanagon has dropped valve seats under 100,000miles and some much sooner also costing close to the same to fix correctly.
That "serious corrosion" is tied to the heads on high mileage vanagons.
Much of the corrosion is due to zero coolant service and often with hard water and wrong coolant. Coolants and sealants are much better today than when the waterboxer was designed.
The waterboxer block is far more sturdy than a type1 and better designed than the type4 . Align boring is rarer than even the type4 even with a harder life.
As soon as a waterboxer is put in a lighter car even more reliability is enjoyed especially when the cooling system is simplified.
At this point its cheaper to build a 2.1 waterboxer than a 2110 type1 using a new case. most of the waterboxer can be reused and rebuilt, cylinders still look new with 200k, type 1 performance cams can be used with or without modifications. |
Posted: Tue Oct 01, 2013 4:28 am Post subject: |
Sure, good engines when introduced but I wouldn't touch one with a bargepole these days unless I knew its full life/service history, and 'today's improved coolants and sealants' have come out far too late for most of these units.
All purely my opinions though you understand.
My principal problems are that:
a) I just love the compact 'stand-alone' simplicity of the air cooled unit and
b) A Waserboxer would be 'period incorrect' for a classic Meyers Manx. |
Posted: Tue Oct 01, 2013 6:53 pm Post subject: |
David that is your prerogative.. I believe That Bruce Meyers built the Manx the way he did was so that everyone could add their own personal touch to it. |
Posted: Tue Oct 01, 2013 10:32 pm Post subject: |
I guess I am a bit on an old 'stick-in-the -mud'... |
Posted: Thu Oct 17, 2013 4:16 pm Post subject: |
ok got the body lift off. and removed the seat mounts . I had some reinforcements welded in place which makes the floor much stiffer.
Runs the length of the frame/pan
Posted: Thu Oct 17, 2013 4:21 pm Post subject: |
sitting back to normal
Rear
Floor cleaned up and seat mounts that were welded to the tunnel removed
Rathbone Samba Member
Joined: February 25, 2006 Posts: 235 Location: Palm Coast, Florida
Posted: Thu Oct 17, 2013 4:55 pm Post subject: |
Your supports look like a pretty good idea to me. I like it. _________________ (o\_i_/o) what you've just said ... is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul - Mr. Oblaski, Principal |
