Welding sections of cross member/rear quarter
virtanen
virtanen is online now
PostPosted: Sat Sep 28, 2013 9:29 am    Post subject: Welding sections of cross member/rear quarter Reply with quote
Here some pictures of welding of my sections to a '51 split.
Temporary screw fixed here.
First welds made and zinc primer sprayed over.
Rear end closing lip spot welded.
Gas welded here as original.
This is a special section with high rear area.
The correct height 43 mm here.
Basic straightening after welding made.
A final piece put here.
Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects
Matthew Tolbert
Matthew Tolbert is offline
PostPosted: Sat Sep 28, 2013 11:16 am    Post subject: Re: Welding sections of cross member/rear quarter Reply with quote
[quote="virtanen"]Here some pictures of welding of my sections to a '51 split.
Mika,
Do you make and sell this piece? I have a set of complete channels but I hate to cut them for just this section. Seems like a waste to me but I will if necessary.
Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S
virtanen
PostPosted: Sat Sep 28, 2013 12:43 pm    Post subject: Reply with quote
The heater channel section only for right side available so far, this was it's initial placement.
Mika
New projects
VEE DUB BOYS
VEE DUB BOYS is offline
PostPosted: Sat Sep 28, 2013 7:06 pm    Post subject: Reply with quote
I enjoy looking at your work. You are a true craftsman.
Matthew Tolbert
PostPosted: Sun Sep 29, 2013 2:36 am    Post subject: Reply with quote
Mika that just happens to be the side I need at the moment. If you would pm me a price if you don't mind. I need the quarter panel piece for that side also so I will probably get them at the same time.
Thanks
Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S
