frizzardking Samba Member
Joined: May 09, 2011 Posts: 575 Location: BUFFALO N.Y
Posted: Fri Oct 04, 2013 12:33 pm Post subject: Meyers hard top fastening Procedure |
Ok here is my problem , last year i had just picked up my Manx after having some minor adjustments and my top assembled , I am on my way home its windy and the top flys backwards will I am driving ,put to stress cracks in the top about an inch long .
It does not fit into the groves of the windshield ,some people drill 2 screws one on each side to keep it in place. I am one that does not like the screws in the windshield frame.
It is held with tension spring that are bolted to the top and bolted to the roll bar.
Not sure if my angle of my windshield is off a bit and that's why.
Any ideas
How have you attached your hard top?
thanks Marc
nightmanx11 Samba Member
Joined: November 15, 2007 Posts: 549 Location: Downstate Illinois
Posted: Fri Oct 04, 2013 1:39 pm Post subject: |
Marc,
On a good day the fit of a hardtop is a bit on the chancy side. It is very unusual for them to blow off.
I have seen them mounted to wooden blocks on the inside, mounted with screws to the windshield surround. You name it and someone has done it. One of the cleanest mounts I have seen is to use a couple mirror clamps on the windshield surround. Dan’s performance has the clips.
If you can wait for MOTB, then you will be able to see several buggys that use these clamps.
Joe |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Fri Oct 04, 2013 1:40 pm Post subject: |
Presuming that your rollbar & windshield frame are parallel & on same centerline left/right, you may find that front of hard top is not 'square' with windshield frame & lacking in proper engagement with windshield frame lip. At this point, you punt...
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
DomManx Samba Member
Posted: Sat Oct 05, 2013 1:30 am Post subject: |
The best way don't move end good fixing
Posted: Sat Oct 05, 2013 9:27 am Post subject: Manx hartop |
Thanks we don't have a Dan's , I ordered some from Appletree Auto.
That Picture from France looks Like a Good Idea , need a better Picture of the brackets |
73SpeedBuggy Samba Member
Joined: July 11, 2006 Posts: 874 Location: Warminster, PA
Posted: Sat Oct 05, 2013 10:11 am Post subject: Re: Manx hartop |
frizzardking wrote: |
I don't think anyone has a Dan's.. as far as I know they are online only.
http://www.dansperformanceparts.com/ _________________ Manxter #39 on a 1971 Pan
Turbo-charged Subaru EJ25D (DOHC)
http://www.cardomain.com/ride/3923620/1971-volkswagen-beetle#
-Adam |
parmaynu Samba Member
Joined: March 29, 2004 Posts: 182 Location: Kent, England
manxfwin Samba Member
Posted: Sun Oct 06, 2013 7:55 am Post subject: |
For what it's worth dept, this method worked for me and at least one other buggy owner. This works best if you hinge the top for entry/exit but would also work using a solid mount. You have to make the aluminum brackets but the windshield clamps are available from several sources. This is stable at 65-70 mph all day.
Hope this helps.[/img] |
Bub Samba Member
Joined: June 10, 2004 Posts: 1155 Location: Central Washington
Posted: Mon Oct 07, 2013 5:51 pm Post subject: |
I used a couple 'suitcase latches' at the front, pretty much like this:
Tiny tiny bracket mounted on the underside of the windshield frame, latch mounted on the inside/ roof obviously.
You can get those a million places for a couple bucks, I may have bought them at Summit Racing.
And the thumbscrew at each corner in the rear- with a threaded anchor mounted underneath through a hole in the body. But I have almost a full hardtop, not just a roof, that I wanted to have the option of removing in a minute or two if I ever wanted to. _________________
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
Mike_CNYBuggy Samba Member
Joined: November 29, 2010 Posts: 628 Location: Syracuse, NY
Kevinwterry Samba Member
Joined: December 31, 2010 Posts: 102 Location: Bellingham wa
Posted: Thu Oct 10, 2013 10:19 am Post subject: |
what are those brackets called? the ones that hold the top down to the windshield frame? i cant seem to find them on dansperformance
parts.com. |
Posted: Thu Oct 10, 2013 12:13 pm Post subject: Brackets |
They are mirror mount brackets for a Manx windshield. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Oct 10, 2013 12:23 pm Post subject: |
This would also be my solution if I were doing this...
Windshield brackets at one time were available at "Bugshields by Dino"....
http://bugshieldsbydino.com/
Meco Samba Member
Joined: January 09, 2009 Posts: 148 Location: Chula Vista, CA
Posted: Thu Oct 10, 2013 2:12 pm Post subject: |
Frizzard man, in your first picture it looks like the hard top's front lip is not sitting within the channel of the windshield frame like it should be. It looks like it is overlapping the entire frame. I'm working on installing my hard top, and really like the solution offered from England that DomManx posted. Real clean looking. |
Posted: Thu Oct 10, 2013 2:44 pm Post subject: Hardtop |
Yes that what we have concluded , the rake of my windshield is my problem , the slant , i had a Custom shop Build this Buggy and they would not read the instructions ,which i told the many times over , because of little tricks and so and , this is what happens.
I am going to order two from England, I have another full hardtop for another Buggy, , as of now i will figure something out for a simple solution while I am in Manx on The Banx. |
