allsierra123 Samba Member
Joined: August 19, 2006 Posts: 1462 Location: Tecate, Baja California MX
Posted: Thu Apr 23, 2009 5:57 pm Post subject: Silicone hoses |
Just curious as to the difference in the types. I am looking for some hose to use on my coolant lines. But I dont see any differences in them is it all the same or is there special type of hose you use for collant system applications. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold |
Posted: Fri Apr 24, 2009 5:36 am Post subject: |
anyone _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
Raynor Shine Samba Member
Posted: Fri Apr 24, 2009 7:35 am Post subject: |
On my SS connection, the blue hose Terry Kay supplied, has to be the best hose I have worked with. from my engine block, i used reinforced high pressure marine hose. and for the heater hoses just the good year rubber hose. kock wood, no leaks.... |
jimeg Samba Member
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10239 Location: N. Idaho
Posted: Sun Oct 06, 2013 11:32 pm Post subject: |
I've kind of shied away from silicone hose due to its tendancy to leak when cold. I'd heard this but used some anyhow and it would seep overnight. Something about it not having as strong a "memory" to grip a given nipple when compared to quality rubber hose. Rubber also seems to stick on after a while and you have to break it loose, where silicone comes right off just like the day you put it on with no apparent sticking. So, you have to use a special "constant tension" clamp with it. I got some of those and still got the odd drip over the year I used it.
At the end of the day, between the hose cost and the pricey clamps it was quite expensive and did not seem to ever seal well. So I dropped its use.
Somewhere I have a package of sweet clamps, and even another thing I was going to try to stop the leak - clamps you heat shrink into place.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3425 Location: Dartmouth, Mass.
jimeg Samba Member
Posted: Mon Oct 07, 2013 7:42 am Post subject: |
Good read. There is another post here where a van owner was losing coolant and couldn't find a leak anywhere. Something to research and consider a little more. The lifetime warranty on the silicone is what makes them attractive to me. _________________ 1986 Root Beer Syncro Tin Top....so many plans.
Here: http://www.thesamba.com/vw/forum/viewtopic.php?t=578490 |
Posted: Mon Oct 07, 2013 7:54 am Post subject: |
This has been brought up before. Watch the video in the other thread. It shows that silicone hoses permeate water at "10 or more times" that of a rubber hose, but not coolant since the ethylene Glycol molecules are larger than water molecules.
http://www.thesamba.com/vw/forum/viewtopic.php?t=502976&highlight=coolant _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
jimeg Samba Member
Posted: Mon Oct 07, 2013 7:57 am Post subject: |
Yes. This was the thread I was thinking of, and that is right - he was losing water not coolant.
Did you end up running silicone or rubber? _________________ 1986 Root Beer Syncro Tin Top....so many plans.
Posted: Mon Oct 07, 2013 7:59 am Post subject: |
jimeg wrote: |
Did you end up running silicone or rubber? |
Rubber! _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
jimeg Samba Member
Posted: Mon Oct 07, 2013 8:01 am Post subject: |
Christopher Schimke wrote: |
jimeg wrote: |
Rubber! |
Where do you find new rubber hoses for your I4 conversion(same for diesel, correct?). _________________ 1986 Root Beer Syncro Tin Top....so many plans.
insyncro Banned
Posted: Mon Oct 07, 2013 8:04 am Post subject: |
I have using silicone hoses on various vehicles including Vanagons for over 10 years without issue.
Not all hoses are created equally.
The GeeBee hoses I have had in service for over 2 years have been awesome. |
Posted: Mon Oct 07, 2013 8:33 am Post subject: |
jimeg wrote: |
jimeg wrote: |
Rubber! |
Where do you find new rubber hoses for your I4 conversion(same for diesel, correct?). |
Everything that I did at the rear was custom. The only stock VW hoses left in the system are the two at the front coming from/going to the radiator.
insyncro wrote: |
Yeah, I'm not knocking the silicone hoses at all. It just seems that some amount of care needs to be taken to ensure that the hoses stay tight on the fittings/tubes and monitor any water permeation. I chose rubber because it was much cheaper and much more convenient given the custom nature of what I was doing. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Mon Oct 07, 2013 8:51 am Post subject: |
I have been contemplating upgrading to silicone and this writeup has helped me make the decision to stick with rubber. I do enough weeping over the van, I don't need silicone hoses that weep as well. For some reason I though silicone would "last longer" but hell my 30 year old hoses are still fine. There is obviously more to this than my small brain can contemplate.
Neil2 |
insyncro Banned
Posted: Mon Oct 07, 2013 10:36 am Post subject: |
A rubber vs silicone hose debate should produce as much of a stalemate as the stainless vs aluminum pipe debate.
Go with what you resonate with. |
insyncro Banned
Posted: Mon Oct 07, 2013 10:37 am Post subject: |
