Fuel tank filler hose FAQ
Bala
Bala is offline
PostPosted: Wed May 08, 2013 8:33 am    Post subject: Reply with quote
webwalker wrote:
I am to pick up the part on Saturday, so I'll post then how well it fits. It SHOULD fit, and if so, we've managed to find an alternative to our shrinking supply of OEM or repop parts.
So you picked it up directly from a Dodge dealership correct?
Do you mind if I ask how much? Looks like it's about $20 shipped online.
1976 Westy
1966 Beetle
webwalker Premium Member
webwalker is offline
PostPosted: Wed May 08, 2013 2:04 pm    Post subject: Reply with quote
That's about right. I paid $14 at a dealership, and they had to fetch it from the warehouse, so an overnight delay.
Regardless, it is thrilling to have this in place. I've been corresponding with the Bus nut who brought it here, and HE found it in a German Bulli forum back in 2007/2008. So this has been out there for a long time, just not much awareness.
I wonder how many other parts are out there that are excellent replacements and we don't even know about them?
M
"Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image
Bala
Bala is offline
PostPosted: Wed May 08, 2013 2:27 pm    Post subject: Reply with quote
Nice, thanks!
1976 Westy
1966 Beetle
vw76westy
vw76westy is offline
PostPosted: Fri Oct 04, 2013 12:53 pm    Post subject: Reply with quote
just thought id share some info
on a metal filler hose that has the bend in it
eliminating the need to make it at a exhaust shop
the way i originally did 6 years ago at the begining of this thread...
dont remember what year this tube came from
but maybe some of you cant post what year you have
and style tube you have so others willknow what to expect
the short metal tube is what is origanally on my 76
the long tube is what i found on many other buses
if you have the short metal tube in your bus
the best thing you can do is find the long tube that has the bend in it
at the next car show or in the classifieds
which would eliminate 1 whole step in
fixing the fuel filler tube
order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
quote from bay window bus buyers guide........
The Type 4 engine is considered by many to be VW's finest air-cooled motor,
Wildthings
Wildthings is offline
PostPosted: Fri Oct 04, 2013 2:22 pm    Post subject: Reply with quote
I think the longer tube showed up during the '76 model year, or at least during the '76 calendar year. Certainly the way to go if you can find one.
Desertbusman
Desertbusman is offline
PostPosted: Fri Oct 04, 2013 3:26 pm    Post subject: Reply with quote
Recognizing the fact you guys are particularly discussing the more complicated late bay system which gets talked about frequently.
But little talk about early bays in searches. My '71 takes a 2-1/4" dia. x 7" long straight hose connector which is a NLA VW part. Scott in Canada has them listed and another option is whacking off a piece of the $40 available hoses with bends.
Yesterday I got the good hose at NAPA. Fuel filler hose P/No NBH 1055 which you buy by the inch.
71 Superbug
71 Westy
busdaddy
busdaddy is offline
PostPosted: Fri Oct 04, 2013 5:31 pm    Post subject: Reply with quote
I think you are correct, I've seen the long tube on 77's.
Слава Україні!
knightsofni
knightsofni is offline
PostPosted: Sat Oct 05, 2013 4:46 am    Post subject: Reply with quote
A new Bus owner here
That long pipe is in my 78 also
I also ordered the Dodge Sprinter fuel filler part
It fit great, it has to be easier than wrestling a straight piece in.
Regards
Knights
AudioFanatix
AudioFanatix is offline
PostPosted: Mon Oct 07, 2013 7:52 pm    Post subject: Reply with quote
Here's my fix just to get a little more info out there. Went with replacing the short rubber tube with a metal tube. Went to my local muffler shop (Collins Muffler) with the OG rubber tubing, told them I wanted this replicated with a muffler pipe, had them shorten each side by about 3/4ths inch to allow for me to get a straight rubber hose that I got from NAPA for 25 bucks (Steep priced, but worth it) Hose claps can be had from NAPA for about 75 cents each as well. Anyway... Here it is.
In the above picture, I used some silicone around all the end of the rubber tubes just in case, not that I think gas will ever get there, but it's a fail safe if nothing else.
Wildthings
PostPosted: Mon Oct 07, 2013 8:04 pm    Post subject: Reply with quote
Regular RTV silicone doesn't handle gas all the well, hope using it doesn't cause you any problems down the road. Crying or Very sad Certainly let it dry very well before filling the tank.
AudioFanatix
PostPosted: Mon Oct 07, 2013 8:39 pm    Post subject: Reply with quote
I saw that before I did it, but I figured it's only a preventative measure anyway, so I figured it couldn't worsen things by any means. We will see. I'm sure by tomorrow I'll re-think it and pick up something a little better. Gas won't be in the tank for probably at least a month anyhow.
Desertbusman
PostPosted: Mon Oct 07, 2013 9:28 pm    Post subject: Reply with quote
With the NAPA 1055 hose I bought the other day there was a very small scratch on the inside that looked like it might be a leak path. So I started back to NAPA today to see if the other end of their bulk hose also had that scratch. But I didn't get to NAPA because of seeing other shallow grooves in the tube that would also be a concern. Even with just the small scratch I had been thinking about using a sealant on just that one location. The concern was which, if any, sealant would work. I know Permatex 3H Aviation dissolves in gas. But the other concern is that once it's together it would be impossible to pull it apart again. I'm now kind of thinking about using sandpaper to round out the flaws. And then maybe a silicone sealant if there is one that is gas proof. The hose is too substantial to hope the clamp will do much to squish out the flaws.
Do you know of a sealant to use WT's?
71 Superbug
71 Westy
AudioFanatix
PostPosted: Mon Oct 07, 2013 9:55 pm    Post subject: Reply with quote
Thats the thing, is that there aren't many good options as far as being "Gas Safe" goes. By doing some research, it looks like something called Hylotyte Red may do the job, but then you are back to the whole "I won't be able to get this apart" thing. IMHO, what would you need to take it back off for though? If it doesn't work, you will probably end up starting from scratch anyway.
EDIT: Looks like Hylotyte is actually only semi setting, so it may work as far as being able to take it back off goes as well.
Wildthings
PostPosted: Mon Oct 07, 2013 10:00 pm    Post subject: Reply with quote
On the recommendation of the guys at my local independent autoparts I bought some PermaShield gasket sealant. It claims it has a high resistancee to gasoline and all other automotive fuels and that it is none hardening and will allow for repeated disassembly and reassembly in some applications.
Haven't given it a try yet though so can't comment on how it works and whether it would work well on fuel filler hoses.
jtauxe Premium Member
jtauxe is offline
PostPosted: Wed Jun 11, 2014 1:08 pm    Post subject: Reply with quote
Wow, my local NAPA wanted $25/ft plus tax for that 1055 hose.
And here is the Sprinter fuel hose for under $9 plus shipping. I got two.
http://www.tascaparts.com/oe-mopar/5119668aa
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Krautski
Krautski is offline
PostPosted: Wed Jun 11, 2014 1:57 pm    Post subject: Reply with quote
Worth springing for the higher quality Norma worm drive clamps. They handle a higher clamping torque and don't eat into the hose.
BUS FOR SALE
I stopped reading after volksaru and busaru
Tcash
Tcash is offline
PostPosted: Wed Jun 11, 2014 4:47 pm    Post subject: Reply with quote
"Hose Clamps, Constant Torque Series Clamp"
curtis4085
curtis4085 is offline
PostPosted: Thu Jun 12, 2014 6:31 am    Post subject: Reply with quote
This link on my iPhone just goes to NApa home page?
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
poptop tom
poptop tom is offline
PostPosted: Thu Jun 12, 2014 6:41 am    Post subject: Reply with quote
The link worked fine for me on my computer. Went right to the clamp. Smart phones do that sometimes.
'76 Deluxe Campmobile
wacarone
wacarone is offline
PostPosted: Fri Jul 22, 2016 11:50 am    Post subject: Re: Fuel tank filler hose Reply with quote
I know this is an older post, but after finally replacing my front suspension I went to put fresh gas in to the Leaking Lizard and the attendant shoved the nozzle in hard enough to separate the rubber filler tube from the metal filler pipe. Without dropping the engine AGAIN, is it possible to access the filler opening through the round, black panel in the engine compartment? I need to slide the rubber boot over the metal pipe.
Page 4 of 6
