regis101 Samba Member
Joined: July 28, 2005 Posts: 2078 Location: Livermore, Ca
Posted: Sun Oct 13, 2013 7:38 pm Post subject: Bump stops |
Greetings. I did a search and looked in the classifieds.
Front bump stops. Are there any differences from 80-91? I recently aquired and installed a complete spring swap from a Carat onto our '85. The bump stops were the same size between the two.
I am under the impression that they may have had more or less rings depending on application. This is due to reading that some rings may have to be cut off when using lowering springs and/or going from factory Westy to Carat.
This is from the '85 and is the same length as what I got as removed from the Carat.
_________________ Peace, Regis |
Brickwerks Samba Member
Joined: April 11, 2010 Posts: 214 Location: West Yorkshire - UK
Posted: Mon Oct 14, 2013 2:46 pm Post subject: |
In Europe we got commercial models, transporters, so panel vans, single cab and double cab pick ups.
These commercial models had a 5 rib bumpstop.
If you lower one of these you'll need to remove 2 ribs or so to match what you lot got over there, 3 rib bumbstops [as pictured above]
So, so long as you don't go daft then the standard bumpstops will be fine. _________________
whynotvw wrote: |
I see you wanna start some shit. whats your fuckin probelm? your selling your measly shitty products. bloody brit |
Posted: Mon Oct 14, 2013 4:19 pm Post subject: |
Thanks for the reply.
I'm just using the Carat springs. The Carat bump stops are the same as the ones I took out of the '85. The Vanagon sits 63.5mm lower in front and 25.4mm lower in the rear making it level. The fender lip to center of hub measurement is 406.4mm all around. I'm happy.
My self inflicted confusion came due to me thinking that with the taller '85 springs , there was going to be more ribs.
No worries. Thanks again. _________________ Peace, Regis |
