Winston the Westy and the Router Hollows...
Page: Previous  1, 2
msinabottle
msinabottle is offline
PostPosted: Tue Oct 15, 2013 7:17 pm    Post subject: A Bit More Clarification Reply with quote
A person doing the same drill (or is that, 'route?') asked for some more details, thought I'd share them.
What we did was to cut a length of wood, about an inch in width, to a bit more than the diameter of the front (I have an '84) axle end cups, and round that on the ends, keeping the length correct. I bought a carbide downthrust router bit, wore a face shield and a shop apron, and just kept going around and around the central hole. I put the rim on a trash can to catch the shavings.
As I got more and more material out, I used the gauge to see if I was there yet, didn't stop until I could turn it around the hole. I did all four rims so I wouldn't have to worry about which went were. One mistake I hope you can avoid is that I didn't 'taper' the hole. The axle end cap tapers, so your hole can do the same, I made mine uniform to the end of the bore and in spots on two of the hubs went through the outer molding. I patched that successfully, but there was no need to do so.
Rims and my repairs are holding up beautifully.
Best!
'Winston,' '84 1.9 WBX Westy
many ways, but never, never, never in silence."
dobryan
dobryan is offline
PostPosted: Tue Oct 15, 2013 7:19 pm    Post subject: Reply with quote
Dang Rob... That's 6 years between posts in this thread. Shocked Wink
Dave O
The Western Syncro build
msinabottle
PostPosted: Tue Oct 15, 2013 7:37 pm    Post subject: Embarassment! Reply with quote
Okay, I TRIED to do the right thing, so when it looked like I'd double-posted, I deleted what I thought was the 2nd post of the July 2008 post and it was the ONLY post and so I went back and reposted the clipboard and I am so very EMBARRASSED. BUT...
Just to make this post more useful than this oopsie, people in similar situations might have a look at this offering from the Chinese House of Cheap Tools:
http://www.harborfreight.com/12-in-professional-air-impact-wrench-68424.html
It's pneumatic, though, and with a coupon you can knock it down to $69. It's actually gotten some good reviews, and is capable of 700 ft./lbs. If it were electric, I'd probably buy it.
But that may come in handy to those with castle-nut issues.
Best!
shadetreetim
shadetreetim is offline
PostPosted: Tue Oct 15, 2013 9:12 pm    Post subject: Reply with quote
And here I thought this thread was about adding WiFi to Winston. Laughing
Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5
Page: Previous  1, 2
Page 2 of 2
