babysnakes Samba Member
Posted: Tue Oct 15, 2013 4:32 pm Post subject: Viton Type 1 pushrod tube seals |
After searching and calling a number of vendors, it seems like these are not made. Is this true? If not, where might I find them? |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Tue Oct 15, 2013 4:56 pm Post subject: |
Naw man, the guy is just pulling your leg, or confused silicone with viton.
You want the SILICONE pushrod tube seals; those are the good ones, but remember nothing sticks to silicone.... except maybe silicone.... so don't put any goop on em. |
tattooed_pariah Samba Member
Joined: April 24, 2006 Posts: 2047 Location: El Cajon, CA
Posted: Tue Oct 15, 2013 5:02 pm Post subject: |
I hae whatever white rubbery POS's that come in the basic rebuild kit these days.. They fit the tubes snugly, but once i torqued the heads down, almost all of them bulged out.. Do i need to pull my heads and fix them, how do you hold em in place? Last time i had the reddish ones and they didn't have thise problem.. :/ _________________ -pariah (just a novice from "that other VW site")
'72 Volksrod "Effigy"
"Never worry about stepping on people's toes. People who get their toes stepped on are either sitting down, or standing still on the job."
-Admiral Arleigh Burke, USN(ret.) |
modok Samba Member
Posted: Tue Oct 15, 2013 5:31 pm Post subject: |
I haven't bought a gasket set in ten years. Almost nothing useable in them things. From what I remember the red ones crack and the white ones turn into chewing gum
CB sells the silicone pushrod tube seals and nice flywheel o-ring too.
THe empi silicone pushrod seals are good too from what I've heard |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2152 Location: Behind the wheel
Posted: Tue Oct 15, 2013 6:10 pm Post subject: |
The white ones that come in the Elring sets work fine. The silicone ones from Empi are too soft. _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
Posted: Tue Oct 15, 2013 7:07 pm Post subject: |
we carry the Elring sets, they work great.
However, another problem we have seen is where the push rod tubes are too long, and they bottom out before the head is fully torqued down. This squishes even the best seals out. This is not a common problem, but we have seen it often enough to be aware of it.
Push rod tubes do come in different lengths, and sometimes it DOES matter. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Tue Oct 15, 2013 7:19 pm Post subject: EMPI pushrod tube seals |
modok wrote: |
Yes, believe it or not, the EMPI silicone "white translucent" seals are very good. I've had them in my current 2332 cc for several years and they have stayed supple and do not leak at all:
_________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Posted: Wed Oct 16, 2013 2:40 am Post subject: |
tattooed_pariah wrote: |
I hae whatever white rubbery POS's that come in the basic rebuild kit these days.. They fit the tubes snugly, but once i torqued the heads down, almost all of them bulged out.. Do i need to pull my heads and fix them, how do you hold em in place? |
This is my problem, I also used the "high quality silicon" seals on the half of the engine I put adjustable pushrod tubes on with the same result. I have pulled my heads to repair this properly.
[email protected] wrote:
"However, another problem we have seen is where the push rod tubes are too long, and they bottom out before the head is fully torqued down. This squishes even the best seals out. "
I had considered this until the adjustable tubes squished them out just the same. |
Posted: Wed Oct 16, 2013 10:26 am Post subject: |
babysnakes wrote: |
so I guess I have a head pull in my future.. luckily the engine is still spinning on my stand, so it won't be too difficult, just a PITA..
how did you get yours to stay and not squeeze out? _________________ -pariah (just a novice from "that other VW site")
Posted: Wed Oct 16, 2013 10:29 am Post subject: |
First, put a tube in without seals and make sure it's not too long. The 1300, 1500, and 1600cc tubes DO vary in length, depending on the mfg. If all are too long use a 40hp tube and stretch it out, it will compress to the proper length after the head is torqued without squishing the seals out. Squished seals happen if the seals are too soft, or if the tube can't compress any more.
It's common for "higher compression" engines to need 40hp tubes, because the heads have been flycut for compression, making the engine narrower and needing short tubes.
With the spring loaded tubes, the spring is too stiff for the softest seals, the Elring ones work great. Silicone but are firm, not squishy. _________________ It's just advice, do whatever you want with it!
Posted: Wed Oct 16, 2013 1:41 pm Post subject: |
Thanks John. |
Posted: Wed Oct 16, 2013 6:24 pm Post subject: |
much appreciated John! These tubes are old(used for less than 1000 miles, but the engine has sat for 5+ years..) but still in great shape, but the heads are new, so maybe they are just fly cut.. _________________ -pariah (just a novice from "that other VW site")
modok Samba Member
Posted: Thu Oct 17, 2013 6:21 pm Post subject: |
I just figured out the riddle. Type-4 engines can use viton o-rings! aha! |
