Trans --no 3-4
servingtwentytolife
servingtwentytolife is offline
PostPosted: Sun Oct 27, 2013 3:26 pm    Post subject: Trans --no 3-4 Reply with quote
So had a great cruise in the Van. no issues. No unsettling noises. Got back in van going through gears. Reverse, 1st and 2nd no problem. can't engage 3/4. no grinding or growling. Have van on brother-in law's rack. Checked linkage--not bad. disconnected linkage to transmission. It will operate reverse, one and two no problem. I can engage 3/4 it appears however isn't all the way to the one side. Question is: is 3/4 all the way outside or is it an alignment/gate issue. Can I align this myself--externally? not really sure about opening up a transmission. Vanagon is an 84, 200k on body/trans about 70 on engine.
bluebus86
Banned
bluebus86 is offline
PostPosted: Sun Oct 27, 2013 3:46 pm    Post subject: Reply with quote
Could be broken 3/4 slider, this failure is common on high mileage tranny's, do NOT drive it anymore, as bits of slider can totally break free and damage further parts costing you a whole lot more money for repair.
that is worst case, you need a rebuild.
Of course the linkage could be haywire, so check that first, if all is good there, then suspect 3/4 slipper has started to come apart.
again do not drive it like this.
look up on Samba 3/4 slider issues with search function, has been discussed a lot.
Link to posting with photos
http://www.thesamba.com/vw/forum/viewtopic.php?t=173239&highlight=slider
tschroeder0
tschroeder0 is offline
PostPosted: Sun Oct 27, 2013 3:51 pm    Post subject: Reply with quote
Yeah, sounds like the typical catastrophic failure, be very happy you are not in the middle of nowhere, sorry.
Ahwahnee
Ahwahnee is offline
PostPosted: Sun Oct 27, 2013 4:22 pm    Post subject: Reply with quote
The good news if you do need a rebuild is that you are (sorta) near a very good source for same: AA Transaxle
Mine went at 180K and Daryl set me up with a great rebuild.
hans j
hans j is offline
PostPosted: Sun Oct 27, 2013 4:25 pm    Post subject: Reply with quote
Welcome to the club! Mine broke a couple weeks ago and now on the list at AA transaxle to get a trans! Very Happy
1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181
servingtwentytolife
PostPosted: Sun Oct 27, 2013 5:17 pm    Post subject: Reply with quote
Thanks. Is this something to repair or buy a rebuilt? What I am getting to is There is no "additional noise" from the gearbox so could a competent transmission house repair the situation or should I just go to aa or german?
bluebus86
Banned
PostPosted: Sun Oct 27, 2013 6:15 pm    Post subject: Reply with quote
I'd select a well known Vanagon experienced shop for the build I'd trust them a lot more than Aamco or such. the vanagon tranny is a bit different than most trannies. Expertise in the vanagon tranny is a important. likely you will need other parts replaced from normal wear. certain things on these trannies require specialized tools and parts, that standard transmission shop may lack. the modified slider is one of them things, the modified ones don't fail like yours may have.
again don't driver her , if she must be moved before pulling tranny, get her flat bedded, or with rear wheels off ground. a lot more damage can happen if the pieces finally break loose, and that will cost you a lot more in busted parts.
To save money you can remove and install the tranny yourself. sounds like you have access to a lift so that is one option to save.
IdahoDoug
IdahoDoug is offline
PostPosted: Sun Oct 27, 2013 11:03 pm    Post subject: Reply with quote
When it happened to me, I experienced the same. No noise, just suddenly from one minute to the next I could not get 3/4. I tried once, then immediately remembered this issue I'd read about on Samba and pulled over. When I later opened the tranny the 3/4 slider was cracked into several pieces but none had fallen out of position yet. So it was a matter of a new 3/4 slider and I could have driven off. I took the chance to upgrade some bits while I was in there. Also, I would not have anyone do that besides AATransaxle. Experience with this trans is key, though every local shop you ask will tell you they can handle it. With AA doing it, you'll never open the trans again. With a local shop, you may get it back and it has a new noise, or it doesn't shift smoothly when cold, or they will just stuff a new main bearing in it without caring that the old one was shifting around and hogging out the bearing retainer, etc, etc ad nauseum.
DougM
servingtwentytolife
PostPosted: Mon Oct 28, 2013 8:29 am    Post subject: Reply with quote
Thanks again guys. On the phone this morning. I've had this vanagon for 24 years, thought I was the only one that had a soft spot for her. Find out my 24 year old son thinks of her as his baby!
Ahwahnee
Ahwahnee is offline
PostPosted: Mon Oct 28, 2013 9:12 am    Post subject: Reply with quote
bluebus86 wrote:
...I'd select a well known Vanagon experienced shop for the build I'd trust them a lot more than Aamco or such...
Just to be clear -- AA Transaxle is not the same thing as Aamco.
Daryl has vast experience with a great many Vanagon rebuilds -- I would expect many more than any other shop.
I did check with local VW shops of course, but all they would say is that they would open it up and 'it will cost whatever it costs'.
With Daryl you not only get a rebuild backed by a great reputation and guarantee but you also know the price right up front.
MarkWard
MarkWard is offline
PostPosted: Mon Oct 28, 2013 9:40 am    Post subject: Reply with quote
In answer to your question, with the shift linkage disconnected at the transmission, it should require no side movement to select 3rd and 4th. It should only require back and forth movement. The sidemovement is for 1st/2nd and reverse.
When driving, you have the sense when you shift to 3rd that you are moving the shift rod over, but that is really not the case. If you were in neutral, moving the shift lever towards the dash, would select 3rd. The cross movement comes from being in 1st/2nd. Sounds internal to me. Daryl at AA Transaxel did mine and I have the experience and some of the tools. Other option is a used transmission.
syncromike
syncromike is offline
PostPosted: Mon Oct 28, 2013 9:54 am    Post subject: Reply with quote
+1 for AA. He rebuilt my tranny, gave me details on what he found inside and what he did. Then, after local shop installed the tranny w/ new engine, Daryl was very helpful with me over email working through some linkage and shift boot issues.
_____________________
'91 Syncro w/ Country Homes PopTop
View user's profile Send private message Facebook Twitter Instagram Classifieds Feedback
