VW Cylinder Head Quick Reference Sheet
bvilletom
bvilletom is offline
PostPosted: Thu Oct 24, 2013 4:43 pm    Post subject: Response to Altwagen flow results Reply with quote
I think I have the 1500/1600 SP & DP stock flow results here somewhere.
I have never flowed the 40 SP.
Bvilletom (Tom Bruch)
bvilletom
36hp Challenge record holder New Age 126.236mph
1970 Porsche 914/6 – 2 liter LSR record holder
1992 Metro Sedan – 1 liter LSR records
1987 Chevy Turbo Sprint – under construction
58 Plastic Tub
58 Plastic Tub is offline
PostPosted: Mon Oct 28, 2013 3:12 pm    Post subject: Reply with quote
FWIW, I called CB this afternoon and got flow information on Los Panchitos heads:
.100 lift: 56 CFM
.200 lift: 97 CFM
.300 lift: 130 CFM
.400 lift: 154 CFM
.500 lift: 168 CFM
.600 lift: 174 CFM
Intake port volume: 66 cc
Chamber: 59 cc
Stan Galat
"Everybody is entitled to their own opinions, but not their own facts."
AlteWagen
Troll
AlteWagen is offline
PostPosted: Mon Oct 28, 2013 3:22 pm    Post subject: Reply with quote
Thanks, much appreciated.
Looks like when they run out of 043 castings the 044 Ultra mag will be the next best thing.
Official Dual Carb Thread
58 Plastic Tub
PostPosted: Mon Oct 28, 2013 4:42 pm    Post subject: Reply with quote
In another post, I believe Pat Downs said they'd have a replacement when they ran out of 043 castings.
Question for all you frustrated engineers out there. Is the proper formula to convert 28" flow figures to 25" (for the purpose of comparing apples to apples) as follows:
CFM @ 28" * (√ (25/28 ))= CFM @ 25"
which is the same as:
CFM @ 28" * 0.944911181- CFM @ 25" ?
If it's not, please let me know and I'll delete or edit this post so as not to confuse future searchers. I extrapolated this from information gleaned from a web-search. I ran some conversion numbers from 28" to 25", and they seem close (SWAG method), but I'd like some confirmation of the math. It's been a long time since high-school algebra.
Stan Galat
AlteWagen
Troll
PostPosted: Mon Oct 28, 2013 4:50 pm    Post subject: Reply with quote
Yes CB is supposed to have a new head by the end of 2014, I would love to see what the prototypes look like.
I used the second formula to convert the DRD data to 25", let me know if there is a more accurate way for the conversion.
AlteWagen
Troll
PostPosted: Fri Jan 10, 2014 3:33 pm    Post subject: Reply with quote
Combustion chamber volume is ACTUAL chamber cc not including step volume if present. Step height is measurement is in the adjacent column with total advertised combustion volume listed under the miscellaneous column.
Retail listing is for TWO cylinder heads at current market prices as of Jan 2014
If product manufacturers/distributors have more accurate/updated data please let me know and I will update the listing immediately. Any new products will also be gladly added as they become available.
MrpeteSWE
MrpeteSWE is offline
PostPosted: Mon Jan 27, 2014 12:45 am    Post subject: Reply with quote
I have a question about the CB 044.. I've bought a pair, 42/37,5mm valves magnum plus.. are that the ones marked "as cast"
Just wondering.. because it seemes like poor numbers.. Sad
Going to give them some porting and it would be interesting to have some numbers to compare with, without accually having to flowtest them..
My ride, vw type 1 -64
http://www.garaget.org/?car=308300
AlteWagen
Troll
PostPosted: Mon Jan 27, 2014 9:58 am    Post subject: Reply with quote
the flow numbers listed for the as cast 044 were the ones with the 40x35 valves.
The ones you got have the same ports but with the larger valves and dual springs. Id bet the flow numbers would be very close to the smaller valve heads.
If I was going to do some port work and had the option of having them flowed I would do before and after numbers.
What you have to remember is that these are "advertised" numbers that are given out by the vendor and may not be what you find if you do the testing yourself.
DerrickfromNC1
DerrickfromNC1 is offline
PostPosted: Tue Mar 04, 2014 4:23 pm    Post subject: Reply with quote
Any flow info on the Bugpack Wedgeports? From the pics on their website the ports look massive....maybe too much for a street car running in the 3500-6000rpm range.
AlteWagen
Troll
PostPosted: Tue Mar 04, 2014 4:31 pm    Post subject: Reply with quote
Only whats listed in their ad in HVWs. The ad says to go to the website for a full list of flow numbers but I cant find any.
mark tucker
mark tucker is offline
PostPosted: Wed Mar 05, 2014 12:05 pm    Post subject: Reply with quote
if you port them you still have nothing to compare them with,they would need to be flow tested to compare them with something else. those heads dont flow for squat as cast. but they can be ported to almost any size engine and application with out welding or worry or being too thin,or intake flange too small&gadget sealing issues.they are a great platform for building off of.
as far as the drd heads go they all list china.....but I seem to remember drd list them usa...??? is that like cast somewhere over the pond&assembled in cali?
and what about cast hear and valves made hear,retainers&keepers made there,studs made by whoo flung wong thong. It would be nice to know where all the parts come from.
AlteWagen
Troll
PostPosted: Wed Mar 05, 2014 12:17 pm    Post subject: Reply with quote
The DRD made in the USA heads never came to market, he ended up using RM instead.
mark tucker
PostPosted: Wed Mar 05, 2014 1:13 pm    Post subject: Reply with quote
wasent longago i saw that add, today infact . creative addvertizing.there seems to be a lot of that...... "built in the usa"
DerrickfromNC1
PostPosted: Sat Mar 08, 2014 9:57 am    Post subject: Reply with quote
Suggestion:
Why not everyone who is in the process of purchasing "high performance" heads post multiple pics of those heads on this thread for everyone to view and compare. Also maybe a brief discription of the engine/application they are going on.
I would encourage manufacturers and retailers to do the same. Not just what's already on their websites but what ever else they can provide. A one stop place to see all rather than back and forth into multiply websites trying to compare products.
Who has a set of the new Bugpack wedgeports.....I think you should start this off!
Just a thought.
AlteWagen
Troll
PostPosted: Sat Mar 08, 2014 10:14 am    Post subject: Reply with quote
Built yes, just not cast in the USA. CB basically does the same thing but uses castings from an OE foundry in Brazil
t7d5
t7d5 is offline
PostPosted: Sun May 25, 2014 6:10 am    Post subject: Reply with quote
If you want built in the USA get MOFOCO heads they do theirs in house.
modok
modok is offline
PostPosted: Mon Dec 15, 2014 3:08 am    Post subject: Reply with quote
The port CC numbers are off, as you know, so I'll help a little.
I have cc's the intake runners of a dozen stock 1600 castings from the pile. I did clean the carbon out of the ports mostly, and used a water/glycol mix and a clear plate so as to be somewhat scientific. All were tested with a bugpack ss 35.5 valve.
The smallest were newish mexico 043 and OLD german 311, at about 50-52cc. Ports in these clearly needed some cleanup and matching!
the actual 113 heads were in the middle at 52-53 or so
The largest was 55cc! found in both a virgin 040 and a german 043 -A, and in these the ports looked really clean and sharp.
AlteWagen
Troll
PostPosted: Mon Dec 15, 2014 10:20 am    Post subject: Reply with quote
Thanks a bunch Glen!! Ill update as soon as I move all the files from my old computer to the new one.
Thanks again for taking the time.
FRNKNSTNGHIA
FRNKNSTNGHIA is offline
PostPosted: Fri May 08, 2015 8:51 am    Post subject: Reply with quote
I am about to order AA Performance Single Port heads and they state that they have STD Combustion Chamber. What would be that chamber size? Would it be the 45cc as the stock SP heads listed at top of chart?
mudbucket
mudbucket is offline
PostPosted: Thu Jun 04, 2015 10:42 pm    Post subject: Reply with quote
Long time lurker but had to register to post cause I think Im going crazy.
Earlier I was reading this thread because I am putting together parts to build an engine and saw a post by modoc(?) explain that stock 043 heads have different port sizes depending on suffix code
I want to use some rebuilt stock 043 heads for my build but don't want to use the small port versions if possible.
Is there any reason the post has disappeared? I was planning on writing down the codes later but now they are gone.
Thanks for any info, GREAT SITE!
Page 2 of 6
