Rear cam plug
yammi450
yammi450 is offline
PostPosted: Tue Oct 29, 2013 8:38 pm    Post subject: Rear cam plug Reply with quote
I have a recently built engine and after complete assembly I noticed the cam plug (o-ring plug in a new aluminum case) twisted when I buttoned up the case. After a small cuss session I applied some black RTV to seal it up. I haven't started it yet but after a couple of weeks to think about iron wondering if I should disassemble and split the case to redo the cam plug. I'm wondering what the chances of it leaking.
chrisflstf
chrisflstf is offline
PostPosted: Tue Oct 29, 2013 8:55 pm    Post subject: Reply with quote
No way to tell until you test it
HRVW
HRVW is offline
PostPosted: Tue Oct 29, 2013 9:09 pm    Post subject: Reply with quote
Confused Which is cheaper.....your Labor or replacing damaged parts from lack of lubrication.
yammi450
yammi450 is offline
PostPosted: Tue Oct 29, 2013 10:32 pm    Post subject: Reply with quote
Which parts? Just kidding, I didn't think lack of lubrication would be a problem if it leaked. Seeing how the plug just keeps it from leaking out of the case. Now if all the oil leaked out so the pic up tube couldn't pick up any I see how that could be a problem.
But there shouldn't be enough pressure behind the plug to pop it out with the groove for drainage being there. Should there?
OLD VW NUT
OLD VW NUT is offline
PostPosted: Tue Oct 29, 2013 11:03 pm    Post subject: Reply with quote
Much depends on how large a hole might have opened up with the cocked 'front' cam plug. RTV is a great general engine sealer but it won't hold up long under very much pressure. Taking apart your motor one more time isn't that tough of a job - but its even tougher when its coated with oil. And you've had to remove the motor to take it apart.
Its your motor - make the call. Let us know what you do.
71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI
Ellis' Bug
Ellis' Bug is offline
PostPosted: Wed Oct 30, 2013 6:27 am    Post subject: Reply with quote
I think my cam plug may be leaking in a recently build..... 2332. It runs great but we're getting a drip from the flywheel side of the engine. It's either the flywheel seal or the cam plug.
Is there no way to replace the cam plug without splitting the case? Any kind of sealant to put over the cam plug to patch it up?
74 Super drag car
63 Bus, work in progress
65 Bug project
63/64 Ragtop
2006 Beck 356
stault
stault is offline
PostPosted: Wed Oct 30, 2013 4:05 pm    Post subject: Reply with quote
Hondabond High-Temp Silicone Liquid Gasket, I had the cam plug leak on mine and this is what I used, that was 2 years ago , took care of my oil leak
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Oct 30, 2013 4:25 pm    Post subject: Reply with quote
You can remove the old plug and install a new Mexican rubber plug without splitting the case.
Glenn
Member #1009
#BlueSquare
Ellis' Bug
PostPosted: Fri Nov 01, 2013 4:47 am    Post subject: Reply with quote
Glen, is it state of New Mexico or a "new" Mexican rubber plug? Also, who carries them?
74 Super drag car
65 Bug project
63/64 Ragtop
2006 Beck 356
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Nov 01, 2013 5:15 am    Post subject: Reply with quote
aircooled.net has them
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
slalombuggy
slalombuggy is offline
PostPosted: Fri Nov 01, 2013 6:45 am    Post subject: Reply with quote
Usually if the factory plug is leaking it's because the drain is partially or totally plugged and oil builds up in the space at the end of the cam and starts getting pushed out. If you pop the plug out to replace with an o-ring style take a piece of stiff wire and make sure the drain is free of debris or sealant.
brad
Ellis' Bug
PostPosted: Fri Nov 01, 2013 7:43 am    Post subject: Reply with quote
Great advice, thanks. I thought the cam plug was questionable when I put it in. Live and learn.
74 Super drag car
65 Bug project
63/64 Ragtop
2006 Beck 356
mark tucker
mark tucker is offline
PostPosted: Fri Nov 01, 2013 8:10 am    Post subject: Reply with quote
if it's questionable,dont use it untill all questions have been answered satisfactory .cheep to right,pain in the ass to do again....and usualy expensive.
yammi450
yammi450 is offline
PostPosted: Fri Nov 01, 2013 8:37 am    Post subject: Reply with quote
If the one from aircooled.net can be replace without splitting the case, How do you get the old one out?
Mr. 010
Glenn is offline
PostPosted: Fri Nov 01, 2013 8:47 am    Post subject: Reply with quote
Drill a small hole and use a screw puller.
Or center punch it and try to grab the edge.
Glenn
Member #1009
#BlueSquare
yammi450
yammi450 is offline
PostPosted: Fri Nov 01, 2013 10:50 am    Post subject: Reply with quote
Cool. I'm breaking it in on a stand. If it leaks then I'll replace it before installing the motor. The car has a removable apron so if it starts leaking later it won't be to much of a hassle to pull the motor.
