Which hightop version is the best? |
I like version 1 |
1% |
[ 2 ] |
I like version 2 |
13% |
[ 14 ] |
I like version 3 |
39% |
[ 40 ] |
I like version 4 |
24% |
[ 25 ] |
I like version 5 |
0% |
[ 1 ] |
I like version 6 |
18% |
[ 19 ] |
Total Votes : 101 |
3dig Samba Member
Joined: October 20, 2012 Posts: 142 Location: Bellingham, Wa
Posted: Sun Nov 03, 2013 3:45 pm Post subject: Aluminum High top design |
I figured it made sense to start different thread on this high top redesign discussion. There seems to be some serious interest in the idea of a custom aluminum high top and Id like to see where this goes.
Given all the great ideas proposed so far, it may be possible to design, dare I say, The Perfect High top.
My background is in the design and construction of aluminum boats in the PNW. I have access to alum, router cutting and welders. A small production run of these tops is a very viable option.
To start things off, Ive sketched up some initial ideas for your consideration:
[/img] |
bluebus86 Banned
Posted: Sun Nov 03, 2013 4:09 pm Post subject: |
2 and 8 would be nicest, as they appear to be more shorter and thus more aerodynamic, and look pleasing to the eye, 3 and 4 look a lot better than 5 and 1, 5 being sort of ugly, but I have been known to have bad tastes, so don't take it personal like.
How tall is the man you have in the drawings?
could you make the designs a bit wider for even more room? maybe a little wider at the base and less taper?
Will the roof of the van be removed, or will the vans opening to the high top be just part way like a sun roof? If opened all the way, that will offer more utility, but there may be steps needed to be taken to reinforce the van, as the stock roof does have beams that I think l\help re-enforce the tops of the sides of the van.
Aluminum would be a nice choice of material.
would the aluminum be smooth or have you considered a corregated wall/roof for strength? although that may take from the looks.
On number 6 the poptop version, maybe have soft side like canvass, of maybe consider folding aluminum side panels, using hinges??? or maybe rigid fiberglass rather than canvas??? that would be pretty unique, and really make this stand out form the Westy's and their soft canvas popup sides.
Nice ideas you have here |
pedrokrusher Samba Member
Joined: July 11, 2011 Posts: 654 Location: Montreal, Quebec, Canada
3dig Samba Member
Posted: Sun Nov 03, 2013 4:58 pm Post subject: |
"What happened to your original highroof with the nice round front aerodynamic design? With a little recess for the rest of the basket?"
number 7 down
number 7 up
This one? My original, and favorite as well. |
Gruppe B Samba Member
Posted: Sun Nov 03, 2013 5:00 pm Post subject: |
Why aluminium over composite? |
3dig Samba Member
Posted: Sun Nov 03, 2013 5:08 pm Post subject: |
bluebus86 wrote: |
no offence taken! keep the comments comming!
How tall is the man you have in the drawings? 72" tall
yes I was thinking the same thing.
This remains to be decided. A few of the versions use the stock opening in the westy, however, I can see this as a retrofit on a tin top. In that case, it would be owners choice as to cut what needs to be cut and reinforce as required.
I thinks so.
personally, Im not a fan of corregated. I like smooth, with nice radius bends, and dime welds.
The cross hatching is supposed to illustrate canvas, sorry for the confusion
Thanks for the input! |
3dig Samba Member
Posted: Sun Nov 03, 2013 5:13 pm Post subject: |
Gruppe B wrote: |
I have no direct experience with composite. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9940 Location: Orbiting San Diego
Posted: Sun Nov 03, 2013 5:16 pm Post subject: |
I have been planning to make my own fixed aluminum top. I don't want sleeping quarters up there so smaller is fine, even preferred. I want some standing room and upper storage inside to the front and to the rear. I'm willing to take inside height of only 70", enough to change clothes and use the kitchen. Opening side windows required.
Mark |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4098 Location: East Kootenay, British Columbia
Red Beard Samba Member
Joined: May 09, 2006 Posts: 463 Location: Seattle, WA
Posted: Sun Nov 03, 2013 5:21 pm Post subject: |
The reason I don't vote version 3 is because it is too similar to the top that North American High Tops sold/is going to sell again.
The faux joker, on the otherhand, is an awesome design that is not available to anyone stateside.
Version 4 baby! |
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Sun Nov 03, 2013 6:09 pm Post subject: high top |
X-2 The Reimo is another good example. This is the one I like! If I can't have that one then a AW top! Third choice # 4 _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
3dig Samba Member
Posted: Sun Nov 03, 2013 6:30 pm Post subject: |
Thanks for the tip, that Reimo is pretty much on the mark. Wonder how it would look in aluminum???? stay tuned |
3dig Samba Member
Posted: Sun Nov 03, 2013 6:31 pm Post subject: |
crazyvwvanman wrote: |
Mark |
Id be glad to help if your interested... |
MayorMcCheese Samba Member
Joined: October 07, 2009 Posts: 660 Location: Lancaster PA
Posted: Sun Nov 03, 2013 6:38 pm Post subject: |
#7 for sure _________________ wv2yb0252gg092706 |
Posted: Sun Nov 03, 2013 6:40 pm Post subject: |
Pardon my limited knowledge, but isn't aluminum quite expensive? Would you be looking at >$2-3k for a top? |
3dig Samba Member
Posted: Sun Nov 03, 2013 6:45 pm Post subject: |
Red Beard wrote: |
figure around 2.00/lb for raw plate. + .60/lb for cutting...I dont know what the composite top goes for, but the major benefit is I can do each top custom order...no expensive mold needed. Plus aluminum can be cut and mended easily...There are drawbacks of course. |
Posted: Sun Nov 03, 2013 8:49 pm Post subject: |
3dig wrote: |
It's gonna be pretty hard to get the nice flowing lines with welded aluminum.
Another construction method to consider vs the aluminum sheets or the work of building molds for fiberglass composite tops is wood strip building.
There are some beautiful kayaks and canoes that have been built this way.
You still need to build a frame and strong-back onto which the shell is built but this process is much simpler than a mold.
You can also make more than one top from the frame/strong-back.
After all the wood strips are laid up, the shell is reinforced with fiberglass and coated with gel or epoxy. It would end up looking really nice. _________________ Currently:
rsbones Samba Member
Joined: January 26, 2012 Posts: 35 Location: United States
Posted: Sun Nov 03, 2013 9:10 pm Post subject: |
What I need to be able to do is to slide long surfboards, say up to 10' long, into the top somehow. I dont think going through the side door will work so...Maybe a window/door like on the back of a typical truck shell. That'd be sweet! |
DAV!D Samba Member
Joined: September 10, 2013 Posts: 979 Location: EL CAMINO
Posted: Sun Nov 03, 2013 9:27 pm Post subject: |
The Reimo is by far the best looking hitop out of any I've seen. It's a shame they didn't sell them in the US |
