Can you ID these parts
fleff
fleff is offline
PostPosted: Sat Nov 16, 2013 2:51 pm    Post subject: Can you ID these parts Reply with quote
These are parts that were in a box that came with my 76 tin top. I assume they are Bus parts, but not sure. Thanks for the assist.
#1:
#2:
#3:
#4:
#5:
#6:
'76 VW Campmobile
'98 VW Passat
'69 Piper Comanche
rustbus
rustbus is offline
PostPosted: Sat Nov 16, 2013 2:52 pm    Post subject: Reply with quote
the first are bushings for the gear shift rod. need to remove the engine and transmission to get all of those in.
i've never seen the rest. last one is a coil bracket but not genuine VW
May of '72 Deluxe. Red Bay Bus 2.0L L-Jet CS & 091 trans conversion
my Bus thread
bowtiebug
bowtiebug is offline
PostPosted: Sat Nov 16, 2013 3:08 pm    Post subject: Reply with quote
#1 shift rod bushings - as stated above
#2 cant make out pic to blurry
#3 is part of a exhaust clamp - missing hoop with nuts
#4 appear to be drum brake springs
#5 no idea
#6 None OEM coil bracket - as stated above
http://www.etsy.com/shop/AlphaKnots
fleff
fleff is offline
PostPosted: Sat Nov 16, 2013 3:33 pm    Post subject: Reply with quote
Wow, that was fast. #2 is a Zirc fitting with a "syringe" on the inside. Not sure what that would be used for.
'76 VW Campmobile
'98 VW Passat
'69 Piper Comanche
my59
my59 is offline
PostPosted: Sat Nov 16, 2013 4:35 pm    Post subject: Reply with quote
For shoving grease into fittings with rubber cover- like ball joints.
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
SGKent Premium Member
SGKent is offline
PostPosted: Sat Nov 16, 2013 7:11 pm    Post subject: Reply with quote
It could be that but the photo is poor. Also looks a bit like the end of an adjustable throttle linkage.
The rubber thing looks like some kind of a trans buffer screwed onto some miscellaneous parts.
udidwht
udidwht is offline
PostPosted: Sat Nov 16, 2013 9:01 pm    Post subject: Reply with quote
Or CV joints as well (boot on installed).
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
airschooled
Air-Schooled
airschooled is offline
PostPosted: Sat Nov 16, 2013 9:35 pm    Post subject: Reply with quote
Bingo.
www.airschooled.com
Road trip reports and tech blog:
busdaddy
busdaddy is offline
PostPosted: Sat Nov 16, 2013 10:25 pm    Post subject: Reply with quote
Difficult to say without anything for scale in the pic but the springs look a little like the ones at the forward end of the parking brake handle.
Слава Україні!
sodbuster
sodbuster is offline
PostPosted: Sun Nov 17, 2013 2:44 pm    Post subject: Reply with quote
Only the two large "shuttlecock" shift bushings will work on your bus. The smallest bushing (i call it a "top hat" bushing.) fits early baywindow models. '68 up to I think '73. (feel free to correct me on the '73 if need be.) the midsize split bushing fits all bugs as well as buses 1967 and older. except for the very old old buses that required no front bushing at all.
