Best Mechanical Fuel Pump for Type 1
Best Mechanical Fuel Pump Manufacturer for Alt. Type 1
Brosal
12%
 12%  [ 2 ]
Bocar
25%
 25%  [ 4 ]
Other, List Options.....
62%
 62%  [ 10 ]
Total Votes : 16
RailBoy
RailBoy is offline
PostPosted: Fri Nov 08, 2013 1:03 am    Post subject: Best Mechanical Fuel Pump for Type 1 Reply with quote
As the Poll states, who makes the best, most reliable Fuel Pump that is Mechanical for the Type 1 Case?
Ran into an issue, not 100% sold on who makes the best Mechanical Fuel Pump as of now, for the way it sounds, Quaility Control has lapsed with the Only 2 that I know of over the past few years...
So, now wondering why I have gone through 2 Bocars and Now 2 Brosals...
Tolerances seam fine dealing with the Push Rod, Correct Push Rod length, Plus Fuel Pump Block(Riser/Guide) is not warn causing unusual latteral play in Push Rod.
So what else could it be? Fuel Pressure is at about 2.7 PSI.......
So, who makes the best mechanical Fuel Pump for these Puppies to see if that can narrow it down to another culpret.. Had one pump die over night when the Bitch was sleeping,lol.... RB
[quote="slalombuggy"]
smitty24 wrote:
"HELP, I ported my own heads and now have fire coming out my ass" .
Shocked
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Nov 08, 2013 4:53 am    Post subject: Reply with quote
Bocar with C clips.
http://vwparts.aircooled.net/Mechanical-Fuel-Pump-Upright-Engine-w-Alternator-p/113-127-025g.htm
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
hsosa1
hsosa1 is offline
PostPosted: Sun Nov 24, 2013 1:40 pm    Post subject: Reply with quote
i got a,chinese crap lasted 2yrs need to go replace one now.
Just Cruzin Sur Califas VW Car Club est♤1998
View user's profile Send private message Visit poster's website Twitter Gallery Classifieds Feedback
vwracerdave
vwracerdave is offline
PostPosted: Sun Nov 24, 2013 2:06 pm    Post subject: Reply with quote
I only use electric fuel pumps.
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
Q-Dog
Q-Dog is offline
PostPosted: Sun Nov 24, 2013 3:12 pm    Post subject: Reply with quote
Rebuildable original VW pump.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
RailBoy
RailBoy is offline
PostPosted: Sun Nov 24, 2013 11:14 pm    Post subject: Reply with quote
Q-Dog, do you know the typical life span of the above rebuildable fuel pump, have one I have been saving and wonder how it holds up in comparison to the "new" production non-rebuildable ones by both Brosal and Bocar? Been going through them is all on a new build and all is correct with there set-ups... RB
Shocked
AlteWagen
Troll
AlteWagen is offline
PostPosted: Sun Nov 24, 2013 11:36 pm    Post subject: Reply with quote
what kits are being used for the VW pumps these days? I remember not so long ago the WW kits were having problems and didnt have everything you needed.
Official Dual Carb Thread
Boolean
Boolean is offline
Pierburg is quality stuff, the poll should have stock VW as an option.
I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379
RailBoy
RailBoy is offline
PostPosted: Sun Nov 24, 2013 11:48 pm    Post subject: Reply with quote
I am not that dated, who built them, OEM VW or like Bosch from the Day, or what became Bosch? Did not have isssues in the 80's with any VW's, have a "new" motor since '07ish w/ no issues, and now issues this year w/another build, and it checks out as fine or the same as past motors and what nots.....RB
Shocked
Q-Dog
Q-Dog is offline
PostPosted: Mon Nov 25, 2013 12:39 pm    Post subject: Reply with quote
Well, I had 299,000 miles on my convertible when I tore it down to start the restoration, and it still had the original fuel pump. I know that I personally rebuilt the pump on that engine twice.
I also run that pump on my buggy. Just rebuilt that one at the end of September because it started leaking and stopped pumping when the engine got warmed up.
I have a couple more in a box that I figure will last me for as long as I can find rebuild kits for them.
Brian
'69 Dune Buggy
'70 Beetle
gt1953
gt1953 is offline
PostPosted: Mon Nov 25, 2013 7:21 pm    Post subject: Reply with quote
I agree the stock pump is nice for sure. Built in screen filter.
68 type 1
72 type 1
73 type 1
72 Squareback
({59 Euro bug, 62, 63, 67, 69 type ones 68 & 69 type two, 68 Ghia all sold})
modok
modok is offline
PostPosted: Mon Nov 25, 2013 9:03 pm    Post subject: Reply with quote
It is true that eventually everything wears out, but of the several OE type pumps I had none of them ever did. I gave away the last one a few weeks ago.
If the carter rotary only costs 20 more than the rebuild kit......then I'll spend the 20$
You said you have one of the rebuildable fuel pumps...... does it work?? Maybe it's fine .....but it's so old your afraid to run it?? Laughing
RailBoy
RailBoy is offline
PostPosted: Tue Nov 26, 2013 12:00 am    Post subject: Reply with quote
Just gots to dig it out now and get a kit for it, get out the buffer and do it up.. Mean, like 20 years ago there was a rumor you could not keep one of the rebuldable ones together to save your life, guess things have changed, again... RB
Shocked
Tizio
Tizio is offline
PostPosted: Tue Nov 26, 2013 2:55 pm    Post subject: Best stock type 1 fuel pump Reply with quote
I have a VW Trike with a bocar 34 pict 3 and svda. The fuel pump came with a brazil fuel pump. Get a low pressure fuel gauge. I bought one at NAPA for $15.00 and check the pressure. Don't buy the kit just buy 2 feet of fuel hose , 6 clamps and a fuel filter and tee. The correct pressure is 1.5 to 3.5 and no more than 2.8 @3000 rpm. The same pressure at idle is where will be at 3000rpm if your pump is good. Observation was an increase in pressure of 1 psi after turning off engine. The heat from the engine causes a pressure rise of 1 to 2 psi depending on how hot the weather temps are. Flooding after warm up during restart with a fresh smell of gas. The Fix, Grind the top of the push rod to lower pressure to 1.5 psi. If you have 3.5 it will rise to 4.5 to 6psi after you turn off the engine. You will smell fresh gas and think your carb is leaking. Also it will run good cold but start stumbling after warm up. The engine requires less fuel when warm and pressure at 3.5 psi will surly flood your engine and damage your carb float needle and foul your plugs. Another tip off is stumbling right after going over bumps. The carb float will not hold back the needle and extra gas will spill over and surge past the needle causing all sorts of problems and eventually ruin the engine. The Brazilian pump I have has a nylon lever that the push rod moves up on. It will not break if the push rod is to long. After examining the lever in the pump I saw it was being smashed on pretty hard with mares on the lever. My fuel pump pressure was 4.6 psi and it was causing so many problems. I had to grind 3/16" off the top to drop the pressure to 1.5. When I turn off the engine the pressure rises to 2.75psi. Shoot for 1.5 psi the pump is more for vacuum to suck fuel from the tank after it reaches the pump 1.5 is plenty. All the problems above mentioned were corrected with the adjustment of the fuel pressure. I hope this helps
https://www.thesamba.com/vw/gallery/pix/1141128.jpg
