How Many Still Have the A&E TransAwn 2000 Awning?
Boesen
Boesen is offline
PostPosted: Sun Aug 25, 2013 1:56 pm    Post subject: Reply with quote
Finally got around to installing my Transawn on my Bay Window. Bought brackets from the above mentioned Eezi Awn dealer. Plan to fab a third mount for center myself, after seeing them in person. Mine doesn't interfere with slider operation and is a breeze to open, set-up, etc. Love it.,,
1979 Westfalia Deluxe http://www.thesamba.com/vw/forum/viewtopic.php?t=474334&highlight=iowa
jrunberg
jrunberg is offline
PostPosted: Mon Sep 09, 2013 5:39 pm    Post subject: Rubbing Reply with quote
Our case rubs on the slider if I have the unit slanted down a good deal (to shed rain). The front door seal will rub just a hair, too. It all comes down to how you mount it to the brackets... A little attention on my part solves the problem so I haven't been motivated to fix it.
Oh, and I spent $50 on mine (pulled out of a barn in the middle of nowhere) and feel like I overpaid compared to some of you. Canvas was worn but has taken 10 more yrs of use without a worry.
Now to just find a replacement rivet/pin for the foot...
Boesen
Boesen is offline
PostPosted: Sun Sep 22, 2013 2:13 pm    Post subject: Reply with quote
I have no problems with the case rubbing the slider on my Bay at all. I have heard from a few other Vanagon owners of the problem though. As you mentioned must be how some mount them.
As far as the pin/rivet on foot. Can you find anything locally to you at say a hardware store?
kamzcab86
kamzcab86 is offline
PostPosted: Sat Dec 07, 2013 8:58 pm    Post subject: Reply with quote
Finally got around to installing the Bus Depot awning enclosure panels:
I didn't like the way the sides attached to the front, so I added zippers at the two corners. I also added welting along the top of the front panel to slide into the accessory track. The sides are bit long for the 8' awning, but it's not a big deal (sides are simply clipped onto the awning fabric). Still need to work on making a side skirt for the van, but overall this will be a good lightweight enclosure for warm-weather trips (as opposed to the bulky, heavy-ass, great-for-winter enclosure that came with the van).
Anyway, if any other TA2000 owners are wanting a screen enclosure, the Bus Depot EZY-Awning panels are an option. Cool
~Kamz Anxious
2016 Golf GTI S
metropoj
metropoj is offline
PostPosted: Thu Dec 12, 2013 6:30 am    Post subject: Pole Brackets. Reply with quote
My Transawn was probably opened and used only a few times in its life and in good shape with all instructions. I notice the rivets on the closing clasps like to rub on the awning material so I have to do something to protect those buggers from cutting into my awning !
I am curious if anyone has or made any of the vehicle brackets for the extension poles to clip in to, rather than stake them into the ground.
Or even better, if you don't use yours or want them or know where I can source some, I would entertain a purchase for them.
I'd rather the poles attach to the van than staked in the the ground for certain circumstances.
vw4life
vw4life is offline
PostPosted: Wed Jul 23, 2014 6:26 pm    Post subject: Reply with quote
Anybody using the gowesty brackets on a trans awning? I found these but at double gowestys
http://www.adventurerv.net/adapter-kit-van-mounting-p-20187.html
vw4life
vw4life is offline
PostPosted: Mon Aug 04, 2014 2:04 pm    Post subject: Reply with quote
Went with the factory dometic brackets. No holes!
tilstad
tilstad is offline
PostPosted: Tue Aug 05, 2014 6:57 pm    Post subject: Reply with quote
Perhaps this has been mentioned already, but I believe Transawn became Dometic at some point. I have bought parts for mine from dometic.
My van is pretty trashed looking on the outside, even the outside of the awning housing, but the awning itself is in perfect shape! Razz
kamzcab86
PostPosted: Tue Aug 05, 2014 7:36 pm    Post subject: Reply with quote
Trans-Awn 2000 is the name of the awning. A&E is the brand, a division of the Dometic Corporation... at least, in 1989 that's the way it was:
Wink
FWIW, I no longer use the cam straps when deployed to keep the tray off the doors (straps are getting worn and not holding well):
I had chain left over from another project, so made one of these for each end (2nd owners had conveniently drilled small holes at each end of the case tray for me to use):
They work splendidly. Cool
~Kamz Anxious
2016 Golf GTI S
Jake de Villiers
Jake de Villiers is offline
PostPosted: Tue Aug 05, 2014 9:30 pm    Post subject: Reply with quote
[strap pic]
[chain pic]
Hunh. My awning doesn't interfere with the slider at all.
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
rcook52459
rcook52459 is offline
PostPosted: Wed Aug 06, 2014 3:52 am    Post subject: Reply with quote
great idea.mine just barely touches the door
85 westy tiico conversion.auto trans triumph TR250 1980 Suzuki GS1000l
Jake de Villiers
PostPosted: Wed Aug 06, 2014 9:45 am    Post subject: Reply with quote
If you have the OEM TransAwn mounts, a couple of washers between the faces in the front raises the gutter quite a bit.
www.thebassspa.com
rcook52459
PostPosted: Wed Aug 06, 2014 10:15 am    Post subject: Reply with quote
I do have oem mounts.such a simple idea it just never occurred to me. going to go fix it right now. thank you.
kamzcab86
PostPosted: Wed Aug 06, 2014 11:27 am    Post subject: Reply with quote
There's a handful of TA's that will rub the door, for whatever reason (I've been contacted by a few owners with the same issue). Mine was installed with the 45° brackets rather than the 90° brackets; even shimmed with thick felt pads to tilt the case back a bit doesn't help. Second owners, way back in 2001, drilled the holes for their own "hold-up" method. The new chains install in seconds as the case is opened so it's not that big of a deal; in fact, they're faster than the straps.
~Kamz Anxious
2016 Golf GTI S
Jake de Villiers
PostPosted: Wed Aug 06, 2014 1:07 pm    Post subject: Reply with quote
That would do it!
www.thebassspa.com
vw4life
vw4life is offline
PostPosted: Sun Dec 14, 2014 12:11 pm    Post subject: Reply with quote
These polish up pretty nice
Jake de Villiers
PostPosted: Mon Dec 15, 2014 12:47 am    Post subject: Reply with quote
[pix]
Oh, I like that! Smile
www.thebassspa.com
mwilliamshs
mwilliamshs is offline
PostPosted: Fri Feb 12, 2016 1:42 pm    Post subject: Re: Pole Brackets. Reply with quote
metropoj wrote:
...I am curious if anyone has or made any of the vehicle brackets for the extension poles to clip in to, rather than stake them into the ground.
Ditto! Anyone? Just heard back from Dometic and the bracket in question, Part 830106, has been obsolete since 12/2/97. Sad
I get a hold of this though...https://www.scamptrailers.com/images/pdfs/Dometic_Catalina_2500_PartsList.pdf
and this https://vanagonwestfaliaparts.com/wp-content/uploads/2012/10/dometicsubstitutions.pdf
kamzcab86
PostPosted: Fri Feb 12, 2016 2:19 pm    Post subject: Re: Pole Brackets. Reply with quote
mwilliamshs wrote:
Ditto! Anyone?
I have them on my van. I'll post of photos of them later. AFAIK, those little brackets aren't available anywhere, so they'll have to be reproduced. Or, it's possible the Fiamma version might work:
Think
~Kamz Anxious
2016 Golf GTI S
mwilliamshs
PostPosted: Mon Feb 15, 2016 12:47 pm    Post subject: Re: How Many Still Have the A&E TransAwn 2000 Awning? Reply with quote
does this look right?
Page 4 of 5
