Geezer Samba Member
Joined: January 01, 2003 Posts: 117 Location: Upland, California
Posted: Sun Jan 19, 2014 4:53 pm Post subject: Rebuilt Engine with No End Play? |
New engine rebuild. With the Scat crank pulley installed I have .03" end play at the crankshaft fly wheel end. I install the flywheel without any shims "0" end play. I have a dial indicator mounted to the case.
I remove the crankshaft pulley and have .03" end play both ends.
I thought the distributor drive gear was maybe loading the crank, but no it isn't. I was hoping for .003 to .006 end play with the 3 shims. This is not happening. I have .01" shims.
I have a lightened flywheel. Counter weighted crankshaft. 8 dowels.
I think maybe the mounting area depth in the flywheel is to deep? I will mic it against a stock flywheel and see if there is a difference.
Never had a no end play problem before. I know the flywheel is bottoming out against the front bearing. I will contact the fellows I got the flywheel from. I think it could be machined down, but is that a correct fix?
bluebus86 Banned
Posted: Sun Jan 19, 2014 5:55 pm Post subject: |
make sure the flywheel is really wrongly made before you alter it. as you say, check against a stock flywheel, or simply bolt a stock flywheel to the motor and see what kind of clearance there is.
there could be lots of reason why the crank is not moving, other than a bad flywheel, poorly installed bearings, dirt, broken parts, out of tolerance parts, etc....
So don't alter the flywheel unless you know it is the problem, else you could be hiding the real fault, which could result in motor destruction.
If worse case, you will need to split the case and check the guts for problems.
you say the problem goes away with the crank pulley removed. could it be the crank pulley is interfering with something?
get a stock pulley and see if that improves the situation.
as I recall, (I might be wrong, but I am pretty sure I am right) the pulley does not effect the endplay normally. The pulley does NOT have a thrust surface. sure you can measure endplay at the pulley end, but the pulley should not be altering endplay.
At this point I'd suspect the aftermarket pulley is hitting something it shouldn't
I one time had a noisy motor, drove home about 20 miles, found the pulley had lots of endplay, thought my flywheel came loose, pulled the motor, and found that when I yanked on the flywheel it moved in and out a whole bunch, but the pulley didn't move with the flywheel. I had a two piece crank, broken in a bearing journal, it was a jagged break, so the broken crank pieces meshed together, enough to get me home. Different situation, but it does show you never know what you may find.
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
vwsteve Samba Member
Joined: March 18, 2004 Posts: 1047 Location: Virginia
Posted: Sun Jan 19, 2014 6:48 pm Post subject: |
If you can set the end play correctly with no pulley installed, the problem is not on the flywheel end. Try a different pulley. I am not sure, but you may get this problem if the oil slinger was installed backwards on the crankshaft. |
Geezer Samba Member
Posted: Sun Jan 19, 2014 7:58 pm Post subject: No End Play reply |
I guess I didn't explain everything. The pulley is a Scat full size. I have used them before. There is a steel spacer that goes in between the oil slinger and the pulley. The oil slinger is tapered toward the pulley. I have always installed them in that direction according to the book. Otherwise the oil would come out the shaft hole.
Next I thought possibly the distributor drive gear and the brass crankshaft gear were preloading the crank. Not. The distributor drive moves with the end play with the flywheel off and the pulley off. It also moves with the pulley installed.
If the mounting area depth in the flywheel is correct I am leaning toward one of the counterweights connecting the bearing support inside the case. I have not used this brand of crankshaft before. If the flywheel is correct it means disassembly of the engine to located the problem. I am retired so time is not important and I figure it as the school of hard knocks.
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sun Jan 19, 2014 8:35 pm Post subject: |
Just add the tin or paper gasket to the crank shaft and start over. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Sun Jan 19, 2014 8:37 pm Post subject: |
It's not really a "hard knock." Most of the time, engine assembly is done two or even three times to make sure all is well, especially if there has been machining or non-stock parts installed. Consider it part of the normal process toward a 100% correct and reliable build. |
Geezer Samba Member
Posted: Sun Jan 19, 2014 9:09 pm Post subject: Over the Years |
This is not my first engine build. It is the first for this problem. I am using a 8 dowel crank and flywheel. The paper and tin stock shim is only 4 dowels. I figure it will have to come apart unless there is a problem with the flywheel.
First engine build was a 36 horse in 1969 on my 57' Oval. There have been a few since then. Biggest was a 2165 44 IDF engine. That said I am still learning new tricks.
In my manual the cut away view shows a stack of three shims against the front main bearing. I must assume if the crank counterweights are not rubbing the bearing supports the depth of the flywheel must be to deep. I am gong to the machine shop and checkout other flywheels. I will post what I find. I was a machinist for 45 years so I can measure things. |
Posted: Mon Jan 20, 2014 6:52 am Post subject: |
You might have some case issues with the balanced crank. I've also run into the "no O ring " flywheels that have been forced on causing clearance issues.
3 shims are the rule, but have taken apart long milers with 2 thick shims.
Love the retired aspect of engine building- no pressure and time to "blueprint" everything. AND nobody looking over your shoulder "are we there yet" _________________ some days I get up and just sit and think. Some days I just sit.
Geezer Samba Member
Posted: Mon Jan 20, 2014 1:49 pm Post subject: Problem Discovered |
There seems to be a slight difference in the end of the crankshafts where the O ring seal in the flywheel goes around the end of the crankshaft.
I tried a bored out flywheel with no O ring and I have end play. I measured a few flywheels and the depth of the counter bore that mates to the end of the crankshaft seems to be a standard .375" deep.
The fix will be to open up the counter bore on the flywheel maybe .010" and retain the O ring seal, not really important as if you use a large diameter washer with sealer it won't leak. With .030" shims my end play is .005" when torqued to 225 foot pounds. I don't use lock tight, it's not a race car.
If this had not appeared it would be disassemble time to see if the counter weights were rubbing the bearing supports. |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Mon Jan 20, 2014 4:51 pm Post subject: Re: Over the Years |
Geezer wrote: |
I am using a 8 dowel crank and flywheel. The paper and tin stock shim is only 4 dowels. |
Get the correct paper and tin shim for an 8 dowell set up and you may find your problem goes away.
You have a non-stock crank, non-stock flywheel and a non-stock pully and you're worried about a stock gasket and shim. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Mon Jan 20, 2014 5:54 pm Post subject: |
Something doesn't make sense. You said that without the pulley installed, you have end play and it goes away with the pulley installed.? The only things that affect end play are the crank, flywheel, front bearing, shims between flywheel and bearing, and the gasket between flywheel and crankshaft. The case has nothing to do with setting endplay. You can set endplay before you ever drop the crankshaft into the case. |
Geezer Samba Member
Posted: Mon Jan 20, 2014 6:44 pm Post subject: I give up |
I have .030" end play with the pulley installed. I have to relieve the flywheel counterbore in the area of the O ring. I am having trouble locating shims. Seems everyone is out of them. I need a .008" or .007" shim to get my .005 to .006 end play. I suggest that the case does have lots to do with the end play as the main bearing is located in the case. Maybe I'm wrong? |
Posted: Mon Jan 20, 2014 6:50 pm Post subject: |
Sounds similar to what you have to do to put a common 200 mm flywheel onto a common 64 mm crank. |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Tue Jan 21, 2014 11:02 am Post subject: Re: I give up |
Geezer wrote: |
That main bearing should fit snug in the case . . . no fore/aft movement allowed there! _________________ Jesucristo es mi Seņor y Salvador! |
Posted: Tue Jan 21, 2014 11:25 am Post subject: Re: I give up |
57BLITZ wrote: |
Geezer wrote: |
That main bearing should fit snug in the case . . . no fore/aft movement allowed there! |
I missed that comment but yes you are wrong. The thrust surfaces are on the crank, bearing, and flywheel. It is not on the case. If the bearing isn't tight in the case, you can't set end play unless you do it as I mentioned earlier by doing it before you drop crank into case. That is why you must be sure the bearing doesn't move before resetting end play on a used engine. The easiest way to check for a loose bearing in the case is to assemble with extra shims until the crank binds as to not turn and then see if you still have end play. If you do, the bearing is loose in case. |
Posted: Wed Jan 22, 2014 3:13 am Post subject: |
I think you will solve your problem by opening up the bore on the "O" ring flywheel so it mates with the "paper gasket" style crankshaft. I've got one now that will be changed to 6vt flywheel for that same reason and (of course- I need a 6vt motor for my bus.)
Keep us informed- love a happy ending. _________________ some days I get up and just sit and think. Some days I just sit.
