thechief86 Samba Member
Joined: January 18, 2012 Posts: 860 Location: middle tn
Posted: Tue Jan 21, 2014 8:19 am Post subject: Body work. |
Hey guys, I just got the motor in my bug after a mild rebuild, and I need to address the body work. I don't have a rust problem, really, just a couple of places where a PO had put on a thick layer of bondo and it let go of the metal underneath. Both places are right behind the doors on either side. I assume I need to get the remaining bondo off, and try to push the metal further out from inside the car. Once I do as much of that as I can, what is next? I figure more bondo, but how do I keep it from cracking this time around? How can I ensure that it will adhere to the metal? I am sure I can push the dents out to need a lot less of the stuff, so that alone may help... _________________ "A poor workman always blames his parts... Ya gotta have skillz to hang junk." -johnnypan |
DrummerDaveB Samba Member
Joined: March 25, 2005 Posts: 504 Location: Louisville, KY Area
Posted: Tue Jan 21, 2014 9:55 am Post subject: |
Keys to bondo sticking are
1) Proper thickness
2) Bare metal.
If it is due to dents and not rust, pushing the metal out so your bondo is thin, and making sure you strip the surface to clean bare metal it should be just fine. _________________ 79 SB Vert, in pieces.
Kadrons, SVDA. |
Hyperspace Samba Member
Joined: January 03, 2013 Posts: 1166 Location: South Africa
texson Samba Member
Joined: June 13, 2009 Posts: 180 Location: Nacogdoches, Tx
Posted: Tue Jan 21, 2014 11:20 am Post subject: |
Hyperspace wrote: |
bare metal with a good bonding surface, say 50 to 8 grit sanding paper, proper panelbeating so you do not have to use thik bondo. |
True that, I found bondo in places on mine that a hammer to the back side was enough to straighten it out. |
Walking Contradiction Samba Member
Joined: August 14, 2013 Posts: 453 Location: Oregon, OH
Posted: Tue Jan 21, 2014 11:22 am Post subject: |
When applying Bondo you never want the layer to be more than 1/8'' thick, and only apply it to bare metal. That is how you keep it from cracking.
-Sam _________________ Samuel Hartford
1974 Super Beetle
Board Member of the Greater Toledo Volkswagen Club
Member of Northwest Ohio Region SCCA |
Posted: Tue Jan 21, 2014 10:14 pm Post subject: |
Thanks guys! This crap was like 1/4" thick, although I think I can push the metal out far enough to need very little of it. Is fiberglass better for this than bondo? Or is bondo ok as long as I don't need to gob it on so thick? _________________ "A poor workman always blames his parts... Ya gotta have skillz to hang junk." -johnnypan |
