Manfred58sc Samba Member
Posted: Fri Jan 31, 2014 9:09 pm Post subject: type 4 valve job tool |
I'm stumped, need to find source for this tool in 351 thousands plus (type 4 exhaust) Thanks so much (for Sioux wheels please). _________________ Fat chick owner/operator |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3777 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Fri Jan 31, 2014 9:47 pm Post subject: |
Get in touch with Len Hoffman or Adrian at Headflow Masters. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
modok Samba Member
Joined: October 30, 2009 Posts: 26740 Location: Colorado Springs
Posted: Fri Jan 31, 2014 10:05 pm Post subject: |
Well that's the stumper..9mm isn't working. I think these heads had a strange non-spec rebuild. Nothing we have works. Got some good leads thanks so much! Trying to save every type 4 head that has been stored on the shelves at the shop forever. _________________ Fat chick owner/operator |
modok Samba Member
Posted: Fri Jan 31, 2014 10:06 pm Post subject: |
huh strange..... what size are the exhaust valve stems?? |
fastone Samba Member
Posted: Fri Jan 31, 2014 11:00 pm Post subject: |
Never mind that PM I Sent All I have 9mm/.354 Pilot's
Maybe the guides where honed to some worn out stems. |
modok Samba Member
Posted: Fri Jan 31, 2014 11:12 pm Post subject: |
It is(or was) possible to regrind the stem and re-chrome it, and that was done in olden days when chrome was cheap and valves expensive. I have seen that a few times. But with a type-4?? That's gotta be a bad idea. |
mark tucker Samba Member
Posted: Sat Feb 01, 2014 10:40 am Post subject: |
I get my pilots off flebay usualy 1/4 the price for new or neeer new.odd ball sizes are usualy cheeper because nobody uses them. |
