Gizmoman Samba Member
Joined: September 10, 2011 Posts: 1554 Location: Nevada
Posted: Sat Feb 01, 2014 1:41 pm Post subject: Shift linkage box - is something missing? |
My transmission (the shift linkage) has been making a lot of noise since I rebuilt by engine. Today I was going to attempt to stop the noise as I just think it's out of adjustment.
I removed the shift linkage box and after looking at the Bently, it seems a guide may be missing.
I have never seen it and never had an issue shifting other than the shift rod vibrates and makes a lot of noise unless I hold it just so.
Can anyone tell me if the missing bit is essential? I can make stuff pretty easily but I have no idea what it looks like. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Oversize spare carrier - stock location (no longer for sale). |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Syncro Jael Samba Member
Posted: Sat Feb 01, 2014 2:01 pm Post subject: |
Ha, I was only a minute behind!
That is usually where I come in.
Hahaaa _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9936 Location: Orbiting San Diego
Posted: Sat Feb 01, 2014 2:11 pm Post subject: |
You are not missing the aluminum shift guide piece that everyone is talking about. Your year did not have that. Your year had a flat plastic piece that snapped into the holes. I don't think it is available anymore.
Mark
Last edited by crazyvwvanman on Sat Feb 01, 2014 4:48 pm; edited 1 time in total |
Posted: Sat Feb 01, 2014 2:25 pm Post subject: |
Thanks for the replies - and I did look my well-worn Bentley. It does show that something is there but not enough detail to tell what it was.
Mine is an 82 but that doesn't mean it has the stock linkage. The transmission is from a gasser.
I'll make a plastic strip and bolt it in place. Hopefully that is where the noise is/was coming from.
Thanks for the replies. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Posted: Sat Feb 01, 2014 3:36 pm Post subject: |
OK,
I sliced a piece of a block of UHMW I had, milled it flat, and tapped it for two screws.
Here's a shot of it installed:
The tab on the shift lever sits against it nicely when in 4th.
I believe my rattling noise will be gone now. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
ewalt98 Samba Member
Joined: October 19, 2009 Posts: 94 Location: Corvallis, MT
Posted: Sat Feb 01, 2014 4:32 pm Post subject: |
Funny, I just had my box out a couple days ago to clean and re-grease the mech, and went through the Bently to see what I was missing in that same spot. My Bently calls it a "rubber stop plate". I can't imagine rubber holding up too well, but your solution looks like it would.
Let us know how it works out. _________________ Eric
82 Westfalia Camper (Currently getting a little bit fixed up)
85 944
72 GT6
88 F350
03 F150 |
Posted: Sat Feb 01, 2014 8:34 pm Post subject: |
Thanks, yeah it is a bit thick but it did quiet things down quite a bit. I must have something out of adjustment. From what I read following your link, it shouldn't even touch the box. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Posted: Sun Feb 02, 2014 7:50 am Post subject: |
Maybe when everything was new it didn't rub much on that side of the box. Perhaps the increased rubbing over time is what does in the plastic rub strip. You can see by your first photo above that there was some rubbing on the metal side of the box after the strip was gone. Did you drill new holes higher up in the box for your screws to hold the new rub strip? It looks like the rubbing was taking place where the existing holes were.
Mark
Gizmoman wrote: |
Thanks, yeah it is a bit thick but it did quiet things down quite a bit. I must have something out of adjustment. From what I read following your link, it shouldn't even touch the box. |
Posted: Sun Feb 02, 2014 8:31 am Post subject: |
crazyvwvanman wrote: |
Mark |
"When everything was new", thats some funny stuff right there
It was rubbing slightly, just enough to wear off the paint. The biggest issue is that the metal shifter tab (which also has a missing bit of plastic) was resting against it and making a rattling noise that was driving me nuts. It still makes a faint noise but quite tolerable now. The extra thickness really tightened up the shift pattern and I may mill off a bit more. I also have some 1/4" rubber sheet I might use which may eliminate the noise entirely.
I drilled new holes near the ends of the stip - outside the travel of the shifter.
The Bentley explains how to adjust the linkage is detail. However, my brain can't seem to follow it I do think it needs some fiddling though as I doubt it's where it's supposed to be. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Posted: Sun Feb 02, 2014 10:21 am Post subject: |
Your early shifter never had plastic on that tab, only the other tab. With the plastic strip on the side of the box none was needed on the tab on that side. Later years had the aluminum gate/guide added and no plastic strip. Since the tab then sometimes contacted metal it was fitted with a plastic ear.
Mark
Gizmoman wrote: |
It was rubbing slightly, just enough to wear off the paint. The biggest issue is that the metal shifter tab (which also has a missing bit of plastic) was resting against it and making a rattling noise that was driving me nuts. ...... |
Posted: Sun Feb 02, 2014 10:38 am Post subject: |
Just for reference, I have a brand new NOS pad here (VW calls it a "buffer") and it measures exactly 3.15mm thick. The pad is made of a semi-hard, transparent rubber or urethane-like material. I would liken it to a 85A urethane in it's hardness.
And, as always, Mark is correct in that there never was a plastic tip installed on the early shifters like yours, just the short metal tab. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
a2d2 Samba Member
Joined: March 28, 2013 Posts: 366 Location: EastVanagon, BC
Posted: Sun Feb 02, 2014 11:29 am Post subject: |
Christopher Schimke wrote: |
Just for reference, I have a brand new NOS pad here (VW calls it a "buffer") and it measures exactly 3.15mm thick. The pad is made of a semi-hard, transparent rubber or urethane-like material. I would liken it to a 85A urethane in it's hardness. |
I found that a wax scraper for skis/snowboards was just about exactly that thickness and works well if you decide to replace the UHMW with something thinner. Probably a bit more brittle than it should be but it is supported by the metal box so it shouldn't matter. It is nice and "slidy" though.
Too bad the original "snap in" holes in the box line up so perfectly with the shifter guide tab or they could have been re-used easily for a nut/bolt to hold the replacement part in.
_________________ 1981 Vanagon, Aircooled 2.0 AFC
1978 Baywindow Bus (R.I.P.) |
Posted: Sun Feb 02, 2014 12:29 pm Post subject: |
And, as always, Mark is correct in that there never was a plastic tip installed on the early shifters like yours, just the short metal tab. |
Great info Christopher.
I'll shave it to 3.15 mm.
Also good to know my shifter isn't missing anything as I thought.
Samba - yeah! _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Mon Feb 03, 2014 8:23 am Post subject: |
Did you disconnect the shift linkage from the transmission when you dropped the engine? Did you pull the engine with the transmission attached? If you dropped the engine with the shift lever attached, it is possible you may have bent the shift rod or the pivot pin. You might also check for the bushing over the fuel tank. It too is NLA last time I checked as well as the pivot bushings at the end of the first section.
There is a preception that you need to move the shift lever to the right to engage 3rd and 4th gear. That is not correct. At rest, pushing the shift lever straight forward or back selects 3rd and 4th. Side movement is required for only 1,2 and reverse. So, if the shift lever is adjusted properly, it really should not be riding along that side of the box unless you are pushing the shift lever to the right of the passenger compartment.
Early notice part number 10.
Later
_________________ ☮️ |
Posted: Tue Feb 04, 2014 7:54 pm Post subject: |
Thanks for the pointers.
I left the transmission in during the swap but I'm fairly confident I didn't bend anything.
The NLA bushing you mention I turned from some UHMW as well. The previous one was in bad shape but it was definitely softer than what is there now. That may be the issue as there is zero give now. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Scottn59c Samba Member
Joined: December 22, 2016 Posts: 308 Location: Northern CA
Posted: Sat Jan 11, 2020 10:58 am Post subject: Re: Shift linkage box - is something missing? |
Does anyone know if anyone is making or 3D printing the plastic guide in the shift box for the earlier AC vans? I've come up empty. _________________ Farfignewton! |
82westyrabbit Samba Member
Posted: Sat Jan 11, 2020 4:50 pm Post subject: Re: Shift linkage box - is something missing? |
Vanagain had all the earl shifter parts the last time I checked. I installed all late models shifter parts in my van when I was in there but that’s not the right answer for most people. John |
