syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12007 Location: Santa Cruz, CA
Posted: Mon May 09, 2011 1:03 pm Post subject: |
Quote: |
Are they driving lights or fog lights? |
I have had hella 550 clear fog lights, cibie oscar plus+ fogs, and now Lightforce lance 140's with a wide angle filter.
I agree with IdahoDoug that pencil beams aren't the best solution for driving as you are limiting your vision to a single point in front of you and you will miss out on anything on the side of the road waiting to jump out. |
plummerdesign Samba Member
Posted: Thu Jan 30, 2014 5:48 pm Post subject: Hella 500 bulbs |
Well gosh darn it I done burned out one of my Hella 500 fog lamp bulbs. Finding the replacement bulb was no problem, but shipping costs made it spendy.
Today I installed the new halogen bulbs from ECO Safety Lights and they give off a nice, sharp white light. The best part was that the twin pack cost only $5.81 with free shipping out of Chicago. That was fully ˝ the price of a single bulb on Amazon, without added shipping! Find them at ecosafetylights.com
Cheers,
Jeffery _________________ It is old and green and it makes me grin.
1984 Westfalia 1.9 |
onemat Samba Member
Joined: November 17, 2011 Posts: 418 Location: Ashland City, TN
Posted: Fri Jan 31, 2014 3:43 pm Post subject: |
Here's mine. Hella 500s. I think these are driving lights or combo driving/fog lights.
_________________ '82 Vanagon GL with 2.0 4-speed. Long term plan is to turn it into a camper. |
rc3 Samba Member
Posted: Fri Jan 31, 2014 3:58 pm Post subject: |
mine are from Wal-Mart.
Syncro Jael Samba Member
Posted: Fri Jan 31, 2014 6:15 pm Post subject: |
I know fog lamps should be low and throw a wide beam.
I still haven't figured out how to mount them low enough without them being damaged off road. So I opt to just throw a bunch of lumens out there.
Top bar is 5 Hella HID 50W 15,000 Lumens @ 60 Lumens per Watt
South Africa Grill has 80W/100W H4 10,800 Lumens (all on) 30 Lumens Per Watt.
Front LED is 72W 24x3 11,520 Lumen @ 160 Lumens per Watt.
Total Lumens 37,320.
I run the front LED as a daytime running lamp also.
A stock Vanagon throws about 2400 lumens. 35/65 Watt @ 12 Lumen per Watt.
At least whatever I hit will see me coming!
And yes, the alternator feels all these lights on. But I am old and still scared of the dark.
Oh, I am sure someone will find fault in my calculations... _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
dubbified Samba Member
Joined: March 03, 2010 Posts: 1406 Location: Redmond, WA
Posted: Fri Jan 31, 2014 10:48 pm Post subject: |
Damn..
I got nothin'.
Not compared to that.. damn.. what kinda alternator you got maaan?
narendra.vw Samba Member
Joined: February 07, 2013 Posts: 440 Location: Bangalore India
Posted: Sat Feb 01, 2014 1:45 am Post subject: Fog lamps |
Big ones are Hella Rally 2000 & Small ones are Hella OE. All carry 100 watts each.
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Sat Feb 01, 2014 8:10 am Post subject: |
Syncro Jael wrote: |
Oh, I am sure someone will find fault in my calculations... |
Great photo, very nice set-up. Portable de-icer |
onemat Samba Member
Posted: Sat Feb 01, 2014 8:21 am Post subject: |
rc3 wrote: |
They look good too... _________________ '82 Vanagon GL with 2.0 4-speed. Long term plan is to turn it into a camper. |
turbotransporter Samba Member
Joined: February 19, 2006 Posts: 459 Location: Bainbridge Island WA
Posted: Sat Feb 01, 2014 10:14 am Post subject: |
I just mounted a set of Hella 500 driving lights from the Van Café. I used the wiring harness included with the lights, used a stock Vanagon fog light (3 position) switch mounted in the instrument cluster blank spot, and wired them so I can turn them on when the key in is in the "run" position only.
(It's an 87 with stock rectangle headlights were swapped out for round Bosch H4's with 80/100 bulbs on relays)
I also added a second fuse panel (Blue Seas) wired directly from the battery so as not to put additional load on the stock fuse panel. That's a Bosch 70A relay to control the fuse panel and the grey stuff is Lizard Skin sound deadener. It's a mid project photo... I've made a few minor changes, removed the temporary blue tape and used my label maker to keep things tidy and clear.
Posted: Sat Feb 01, 2014 1:21 pm Post subject: |
turbotransporter wrote: |
I just mounted a set of Hella 500 driving lights from the Van Café. |
Those look sweet!
If you want to triple your lumens and reduce your wattage by half try this HID replacement. That is what I did and you cannot believe the difference in light output!
angrychicken Samba Member
Posted: Sat Feb 01, 2014 3:53 pm Post subject: |
^ that is a clean/simple retrofit!
I had these IPFs that I had for my skid bar on one of my Imprezas.
I opted to mount them and put in a $5 rocker switch where the OEM fog lights go until I can find a deal on an OEM switch (I'm cheap).
The fog lights came with a harness that I still need to wire up but I think the covers seam decently well with the grill.
bluefirefly Samba Member
Joined: March 16, 2011 Posts: 438 Location: Calgary, Ab
Posted: Sat Feb 01, 2014 4:23 pm Post subject: |
I don't remember seeing a 72W Led bar going over 6000lm. Where did you get yours, what brand name if you are willing to share?.
Thanks _________________ 86 Syncro Tintop G60
work in progress ...as always! |
ehoff Samba Member
Posted: Sun Feb 02, 2014 8:15 am Post subject: |
bluefirefly wrote: |
Thanks |
I was just going off of an led chart that showed 160 lumens per watt.
Here is the lamp. 5400 Lumen.
http://www.superbrightleds.com/moreinfo/off-road-l...1218/2859/
Still a pretty bright lamp. _________________ 1987 Syncro Westfalia Hightop - NAHT
RainierSyncro Samba Member
Joined: February 26, 2013 Posts: 809 Location: Seattle
Posted: Sun Feb 02, 2014 3:09 pm Post subject: |
Here's my GL with a couple of Hellas mounted above the bumper. I had them wired come on with the high-beams. Fills in that darkish area below the high-beams and a little bit on the sides of the road. Helps out a lot on the way to work.
Posted: Sun Feb 02, 2014 3:15 pm Post subject: |
ehoff wrote: |
I am also running the TerraPodz, which actually do emit quite a bit of usable light at night.
Too bad the TerraPodz couldn't be fashioned to install some fog lamps.
Those really look sweet with the SA grille. _________________ 1987 Syncro Westfalia Hightop - NAHT
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sun Feb 02, 2014 7:26 pm Post subject: |
Nice looking setup. I was wondering if you saw your engine temps go up with the winch cover blocking the lower grill? |
Posted: Mon Feb 03, 2014 10:34 am Post subject: |
Nope, I have not noticed any change in the engine temps. With the neoprene cover off there quite a bit more opening exposed for air passage. It has only been on since December so I have not had it exposed to excessive ambient temperatures yet. If it does make a difference I can carry it on the back receiver if needed. This is one reason I went with the portable system is being able to move it around and even to anyone elses vehicle if needed. Sometimes your buddy just gets in too far!
