lugo2214 Samba Member
Joined: January 16, 2014 Posts: 134 Location: Pinckard, AL
Posted: Fri Feb 14, 2014 9:01 pm Post subject: |
This thread was inspiring _________________ RoRo's Campeter
1973 Tin Top Campmobile
Type 4 ENG / 2.0 HYD LIFT
003 Auto Trans 😆/😣
Dual Empi 44
009 Ignition
Ice Auto Air A/C kit 50% installed |
justcruzin Samba Member
Joined: July 31, 2005 Posts: 1493 Location: United States
crownline Samba Member
Joined: September 10, 2010 Posts: 592 Location: Northwoods of WI
Posted: Sat Feb 15, 2014 7:40 am Post subject: |
Kim, I love the colors looks nice and clean. Is that all powder coat? Or paint _________________ 1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL] |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22446 Location: Escondido CA
Lionhart94010 Samba Member
Joined: January 04, 2005 Posts: 1417 Location: SF Bay Area / Silicon Valley / So Cal
Posted: Sat Feb 15, 2014 3:28 pm Post subject: |
justcruzin wrote: |
Here's my new 1776. What can I say, I'm a girl and I like pink and purple.
Kim, you’re engine looks great, my 2yold daughter would go crazy if she saw it she love, cars and those are her two favorite colors :0)
Just and FYI, if your manifold heat risers do not burn off all the pink paint until it looks flat white/gray then it is not working properly and your bus will not run as well as it should… _________________ Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm |
Posted: Sat Feb 15, 2014 3:46 pm Post subject: |
Lionhart94010 wrote: |
justcruzin wrote: |
Just and FYI, if your manifold heat risers do not burn off all the pink paint until it looks flat white/gray then it is not working properly and your bus will not run as well as it should… |
Thanks!
On the heat risers I knew they would burn the paint off. That is one of the things I did forget to check before installing though. I was thinking they were clear because I remember cleaning them out a while back, but after thinking about it, it was the single port we cleaned out. So far the paint is just turning color at the point it is hooked to the exhaust and up about 2- 2.5 inches up. That will be a project for later down the road. Next time we have to pull the engine I will check them. I was told if they were plugged, it wouldn't warm the carb up as fast and cause issues with the warm up. After running for a bit it would run ok with them clogged. Maybe I was misinformed? At any case, it seems to run good and only takes about 3 or 4 minutes to warm up enough to idle on its own. I think my carb isn't the greatest either though so that may be part of why it won't idle from the jump. I bought a new one and am waiting for a friend to come and install it and dial it in. I don't like doing the dialing in part. _________________ Kim
Sacramento, CA
1964 Split Window Bus
1966 Beetle Build Thread= http://www.thesamba.com/vw/forum/viewtopic.php?t=472933
1969 Delivery Van= http://www.thesamba.com/vw/forum/viewtopic.php?t=566282
1970 Westy Build Thread= http://www.thesamba.com/vw/forum/viewtopic.php?t=479538
1971 Squareback Build Thread = http://www.thesamba.com/vw/forum/viewtopic.php?p=6652459#6652459
1970 Single Cab, Samson = http://www.thesamba.com/vw/forum/viewtopic.php?p=8022609#8022609 |
eche_bus Samba Member
Posted: Sat Feb 15, 2014 4:40 pm Post subject: |
justcruzin wrote: |
I just can't help myself.
Posted: Sat Feb 15, 2014 4:41 pm Post subject: |
Quote: |
Thanks!
Kim
Sacramento, CA
Re: I was misinformed?, sorry but I think yes, due to the long intake run and the effects of vaporizing the fuel, the intake manifold can get cold even on a hot day; that may cause pour fuel mixture and could cause engine damage (my understanding is that it may cause it to run too lean(lose power and /or get to hot) and/or have un-atomized fuel droplets dilute the oil film on the cylinder walls= faster Ring/cylinder wear) (un-atomized fuel droplets, same reason why you want them working when it is started from cold) _________________ Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Sat Feb 15, 2014 5:02 pm Post subject: Kim's Engine colors |
Kim, now you need to move to Santa Cruz and drive up and down Pacific avenue with the lid open.
Seriously, it looks really, really Good. _________________ V.W.owner since 1967 |
vince1 Samba Member
Joined: December 14, 2003 Posts: 823 Location: Burgundy, France
Tcash Samba Member
Posted: Sun Feb 16, 2014 10:07 am Post subject: |
Those colors pop.
Just a thought. Good Luck |
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5274 Location: Taoswest, USA
Posted: Fri Mar 07, 2014 10:16 am Post subject: |
Did a search and did not find what I was looking for. Has anyone installed a type IV engine into an early Bay (68-71)? Is there a thread about it?
I have 2.0 and 6 rib transmission from a 78 bus and a friend of mine sold me a slew of Raby parts, upright fan housing, etc. and have been toying with the idea of installing it in my 68 Westy.
Thoughts? _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
babysnakes Samba Member
Posted: Fri Mar 07, 2014 2:46 pm Post subject: |
Yes it has been done. Raby even produced a mustache bar for that conversion. I'll be doing the same with my '69 SC. My only concern is the mid point/rear tranny hanger that is not present in early bays. This just leaves the front tranny and mustache bar mounts. |
Brian Samba Moderator
Posted: Sun Mar 09, 2014 12:09 pm Post subject: |
babysnakes wrote: |
My thought would be to weld in the transmission hanger. Because both components are heavier. But I'm guessing the engine support can still hold it. I'm curious as well. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
nathansnathan Samba Member
Posted: Sun Mar 09, 2014 12:42 pm Post subject: |
lustig69 wrote: |
babysnakes wrote: |
My thought would be to weld in the transmission hanger. Because both components are heavier. But I'm guessing the engine support can still hold it. I'm curious as well. |
The conversion Jake did on the pickup didn't use a middle mount. He cited that a 914 doesn't use one either and came that way from the factory. |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Sun Mar 09, 2014 12:45 pm Post subject: |
And so does a 911... Even a 2014 GT3. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
Posted: Sun Mar 09, 2014 1:40 pm Post subject: |
Good to know. Thanks Nathan and Jake. |
