Tcash Samba Member
Posted: Sun Jul 28, 2013 10:27 am Post subject: |
grandpa pete wrote: |
Two peices of pipe and 1 hour..1/2 inch nipple and 1 1/2 inch nipple
Not pretty but it works...remember to grind off galvanising before welding
Plumbing fitting to tap in seal..1 1/2 to 3 inch adapter
Thanks to all who contributed |
Tcash Samba Member
Posted: Sun Jul 28, 2013 10:28 am Post subject: |
scirocco_crazy wrote: |
Ball Joints....... I thought that I could locate the tool to press them out and poof I would be on my way. Here to find out that it will run me about $100 at a local shop for them to press them out. I have no problem paying someone with the skills and tools to do a job. But I cant seem to bring myself around to doing it. So I fabricated my own tool and will use the massive press at my work to do it myself. I just copied the tool I found at German Supply. i have not welded the guide plates in yet but will do that tomorrow. I wanted you all to see it prior to welding in case you wanted to make one of your own. The ball joint in the tool is used to hold it in position once I tack it.
[img][/img]
And the one from German Supply
[img][/img] |
Tcash Samba Member
Posted: Sun Jul 28, 2013 10:29 am Post subject: |
ratwell wrote: |
FYI. http://www.ploon.nl/bus/1998.php
Quote: |
Replacing the balljoints was also an item on the agenda. We didn't want to take the trailingarms of the bus, so we figured out a way to replace them with the arms still attached to the car. First you use an anglegrinder to weaken to top of the old joint (dont damege the árm the is pressed around it). Them your hammer on the bottom of the joint until the rod and ball unit comes out via the top of the bushing that is still pressed into the arm. Use a hacksaw to weaken the bushing and hammer it out.
To get the new one back in you take to plates of steel 10cm*10cm*10m. Make a 58mm hole in one plate and a 50mm one in the other plate. make 10mm holes on each corner of the plates and use 4 nuts & bolts to press the new joint into the arm
Skoolieman Samba Member
Joined: January 31, 2011 Posts: 573 Location: Chattanooga TN
Posted: Sun Jul 28, 2013 1:40 pm Post subject: |
Tcash wrote: |
[img][/img]
[img][/img] |
Be careful using this one, I think he said it exploded while trying to use it! _________________ '69 Westfalia Camper~Cassidy
1600dp with H30/31 carb 009 distributor and alternator conversion |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1084 Location: wherever my baywindow takes me.
Posted: Sun Jul 28, 2013 1:50 pm Post subject: |
Oil cooler pressure tester.
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Mon Jul 29, 2013 12:09 am Post subject: |
This is an idle stick for winter warmups. It has a notched end for unlocking the other door. It is not used for cruise control.
Aloha
tp |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Mon Jul 29, 2013 12:27 am Post subject: |
Tom Powell wrote: |
[img]
Aloha
tp |
Haha I like how you typed that AND it's on the stick. If you ever sell your bus, I would still hide that thing! _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
1967250s Samba Member
Posted: Mon Jul 29, 2013 1:26 pm Post subject: |
Wait, you're in Hawaii and need to warm up the engine? Or is that not HI? What's up with the insulation? |
Posted: Mon Jul 29, 2013 1:30 pm Post subject: |
1967250s wrote: |
I think his bus is primarily used in California for ski trips. _________________ Learn how your vintage VW works. And why it doesn't!
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3551 Location: San Diego (Encinitas)
Posted: Tue Feb 11, 2014 11:03 pm Post subject: |
Here's a home made tool to remove the nuts on dash switches.
To make:
- get a length of steel rod the diameter of the headlight switch nut.
- drill a hole down the rod centerline to allow the switch shaft to completely enter.
- turn a truncated cone on the end of the tool until the cone reaches the center hole.
- mill off material on either side of the tool centerline to leave a pair of prongs the right width to fit into the nut. Make the prongs slightly taller than the depth of the nut recessions.
- drill a hole through the othe end of the tool to take a small rod as a handle.
Should look like this when done:
_________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
Last edited by telford dorr on Sun Feb 16, 2014 12:27 pm; edited 1 time in total |
drs1023 Samba Member
Joined: October 20, 2011 Posts: 1682 Location: Georgia, USA
Posted: Sat Feb 15, 2014 6:58 pm Post subject: |
I had to replace the starter on my Gazelle today, and I used another home made tool to install the bushing. Years ago, I found that an air chisel with the .395" round end is great for aligning and bumping the starter bushing in place while the engine is still in.
After removing the old bushing with a tap, I put the old bushing on as a spacer and the new bushing on the business end. A few light taps with a small hammer and the bushing bottoms out easily.
Alex6373 Samba Member
Joined: August 05, 2007 Posts: 882 Location: Vancouver Island,B.C.
Posted: Sun Feb 16, 2014 10:09 am Post subject: |
Joey wrote: |
Using a drill press, some welded round bar and a cut washer for a valve spring compressor...
You should patten this ,fantastic idea!!! |
Tcash Samba Member
Posted: Fri Feb 28, 2014 5:42 pm Post subject: Home made tools |
Patrick199
Steering wheel removal tool Measurements in MM
Tool I made few yrs ago. Steering wheel puller. Works well!
Homemade flush clamps
Tire Changer
Crankshaft Tool
Making a homemade VW transaxle drain / fill plug tool. Use scrap metal, an old bolt with a 17 MM head, a welder
Homemade tubing roller
Homemade eshuchon removal tool. Made from a 3/8" nut driver using a Dremel
Home-made gland-nut tools
Homemade panel clamp
engine stand
Homemade valve adjustment tool and clutch alignment tool.
heres a homemade tool that pulls the transmission input shaft seal
homemade torque tool courtesy of Brian
Homemade ball joint tools
Home made engine stand
quote jeremyrockjock:Some people have asked me about my bender so here is a picture of it. It is made of c channel and a 4 ton floor jack with machined rollers and die.
English Wheel
Beam Bearing Puller
Homemade drum puller[/quote]
Works well with calipers as well.
Using a box wrench to gain leverage, to remove CV bolts.
Posted: Sat Mar 01, 2014 9:57 am Post subject: |
engine dolly
Aloha
tp |
