mountainkowboy Samba Member
Posted: Thu Jan 23, 2014 10:09 pm Post subject: |
To bad your not closer....I have 2 perfect doors from a 76, that I'm no gunna use on anything. _________________ Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater" |
Chanbob Samba Member
Posted: Sat Jan 25, 2014 10:17 am Post subject: |
Nice build so far. You are on a role. Seeing your build has given me some ideas for my 74 Super. What area of Eastern Washington are you in? I am near Boise. Good to see some Super love in the area.
Your pic inside Bow Wow was a shock at first. Hopefully you found what you needed from them. I gave up going there about a year ago. It used to be a great store, the people who run/own it now either don't have a lot of knowledge about ACVW's or they just don't care.
Keep up the good work, I am looking forward to your forward progress. |
baxsie Samba Member
Joined: August 09, 2005 Posts: 606 Location: Eastern Washington State
Posted: Sun Feb 02, 2014 9:36 pm Post subject: Removing the Gas Flap / Door Finger Notch |
Walking Contradiction> Don't feel bad about using Bondo . . . As long as it is never applied more than 1/8'' thick
That is certainly my goal to keep it (much) less than 1/8"
Chanbob> Nice build so far
Thanks for the kind words.
Chanbob> What area of Eastern Washington are you in?
A bit south of Spokane.
Chanbob> Your pic inside Bow Wow was a shock
A pilgrimage I had to make. Looked pretty much like the last time I was there in 1980
As detailed long ago (in "Making Gas Door Release Inside Again"), we put a latch on the gas door, so we would not have to mess with locking gas caps. Bashr52 asked "Are you going to fill in the indent in the body for the old style door?" At the time, I thought I would leave it to the body shop, but We are getting a bit braver so I thought I would give it a shot on my own.
We started with some spare bod metal shaped to fit the opening:
Bent that so it filled the notch:
Used some tape to hold it in place and tack welded:
Then made several short welds to complete it, allowing full cooling between:
We used the carbide burr in an air powered die grinder to smoothe the welds out:
Here is the first pass on the bondo. I am a bit surprised how far the bondo goes beyond the weld until it feathers. I guess that the welding must have warped things down a bit, despite my attempts to keep things cool. I used a long block sanding block to make sure I followed the plane of the panel. The center of the sanded bondo is still a little low:
A quick test fit with the gas flap:
And a final picture after the second shot of bondo is sanded smooth:
Nice way to spend a couple of hours in the warm shop on a cold Saturday. _________________ 1975 LaGrande Super Beetle Build Log / Farm boy hinge pin puller / Farm Boy Chassis Rotisserie
"I'm not getting older, I'm getting bitter." |
baxsie Samba Member
Posted: Sun Feb 09, 2014 9:26 pm Post subject: Making Super Beetle Front Fenders Wider - Filler & Prime |
It has been quite a learning experience on making these fenders wider (Skip back to here to see the start of the fender widening). We have done a few things right the first time. Mostly, however we get things right after several tries. Lots of pounding, grinding, etc. Lots of doing things slow that should be fast.
We finally got the filler close enough to brave showing it to the body shop who will do the final painting. He said "it was better than he expected". He gave us a bunch more tips and strategies and back we went for more work on the fenders. More blocking, "pecking" at the highs spots, skim coats, sanding, blocking . . . here are the results:
Today we went ahead and shot the fenders with the 2K epoxy primer to cover the bare metal and seal the filler. There are some small flaws, but the magic of the camera hides most of that:
We then shot over the 2K epoxy primer with some sandable primer. Next will be a guide coat and more blocking. _________________ 1975 LaGrande Super Beetle Build Log / Farm boy hinge pin puller / Farm Boy Chassis Rotisserie
fabricator john Samba Member
Joined: October 09, 2009 Posts: 510 Location: manassas va. now Venice Fl.
baxsie Samba Member
Posted: Tue Feb 11, 2014 11:40 pm Post subject: Making Super Beetle Rear Fenders Wider - Marking |
That looks pretty cool. After I run out of the spray can of guide coat, I'll look at getting one of those.
Fresh off the relative success of the front fender widening project, we decided to tackle the rear fenders. The front fenders meet the body at nearly a 90 degree angle along most of their length so moving them outward was relatively simple. In contrast, the rear fenders meet the body at a pretty good slope along much of their length.
After quite a bit of head scratching, we have the fenders marked for cutting like this:
The inside of the tape will be the outer fender cut line, the outside of the tape will be the inner fender cut line:
The bumper hole will be entirely on the inner fender, so that geometry will not get messed up. The tail lights will move out and be entirely on the outer fender.
We duplicated the marking on a total of four fenders:
The right fender is in pretty bad shape, and as we left the shop, I noticed we have another right fender in better shape, so we will probably end up marking one more. _________________ 1975 LaGrande Super Beetle Build Log / Farm boy hinge pin puller / Farm Boy Chassis Rotisserie
Posted: Wed Feb 12, 2014 9:52 am Post subject: |
Looks good, I like how the front turned out. Good luck on the rear. |
Posted: Wed Feb 12, 2014 5:21 pm Post subject: |
the powdered guide coat is amazing stuff i became addictted to it years ago , no dry time , finds every scratch and pinhole , dosent booger the paper, haz a zillion uses .... fabricator john |
baxsie Samba Member
Posted: Thu Feb 13, 2014 10:54 pm Post subject: Photo of wider front Super Beetle Fenders Installed |
We mounted the primed fenders so we could measure the finished distance from the fender lip to the tires. Looks like ~1 1/4 to ~1 1/2 depending on where you measure. We wanted to make sure the rear fenders had about the same amount. Took a photo from the front while we were at it:
We test fit the running board to make sure that would not be an embarrassing fit. I think it looks pretty good:
baxsie Samba Member
Posted: Thu Feb 13, 2014 11:14 pm Post subject: Making Super Beetle Rear Fenders Wider: Cutting and Test Fit |
We cut along the lines indicated on the post above, and quickly slapped the two together. Looks pretty hopeless:
We then used sheet metal screws to adjust and tweak the position, not looking so bad:
We aligned the new and old fenders based on marking from the top-most fender hole. Oddly, the rear edge lines up very nicely:
After we made some radial cuts, the tail light area actually lay down quite well. The upper-left quadrant is "high", so we will need to adjust that in before welding, and the area between the tail light opening and the bumper strut opening is "low" so again that will need to be bumpped out before welding:
The front edge appears to be way too long:
It does not line up with the running board at all very well. I need to look at how this area is on a factory car so we can shorten the fender if needed:
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Fri Feb 14, 2014 4:48 am Post subject: |
Terrific work and good ideas for my own 1303 projects |
VWCOOL Samba Member
Posted: Fri Feb 14, 2014 4:50 am Post subject: |
baxsie Samba Member
Posted: Sun Feb 16, 2014 8:28 pm Post subject: Super Beetle Rear Fenders Wider - Cutting & Welding |
After cutting the fenders, we adjusted the overlap and used sheet metal screws to hold them where we liked them. We then used some spray paint to mark where the top fender lays on the bottom fender:
From there, we marked out by the widthe of the flanging tool, and then trimmed and flanged the fender:
Here is a shot of some of the warly welding on the driver side:
We left the tail light area for the last. Here are the tabs welded, then smmoothed:
Some pounding to counteract the warpage, then more smoothing, and it is getting close to ready for the 2K primer:
Ethan was back on the welding when we moved to the passenger side, so the welding is a bit nicer:
Considering that he did not know how to weld at all when this project started, he is knocking out some beautiful beads. And this is on the thin fender material:
baxsie Samba Member
Posted: Mon Feb 17, 2014 8:39 pm Post subject: Super Beetle Rear Fenders Wider - Shortening Front Part |
I was directed to a discussion on Silicon-Bronze MIG wire, so we held off the remainder of the welding on the passenger side in hopes that the silicon-bronze will do less warping.
We did tackle shortening the front part of the drivers side rear fender. There is such a slope where the fender meets the body in that area that the fender moves moves down about as much as it moves out. Here is a pic of where we were cutting:
And here is the frankenstein patch job. We did not see why to make the under-cut which seems to weaken the fender right where it could use some strength for the running board. So it is now more rectangular:
baxsie Samba Member
Posted: Mon Feb 17, 2014 8:48 pm Post subject: Fog lights in front fenders, DRL in bumper |
We installed the bumper to make sure there was not any problem with the fog light's position. Even if there was a problem, there is not much we would be willing to change at this point. In any case, the setup looks pretty good. It is intentional that the bumper "trims" the fog light slightly on the top. The cutoff is still due to the optics in the fog light, but the bumper does help trim some of the "overspray" light:
The cutoff of the Hella Micro DE fog lights is pretty sharp:
Here is a deer's-eye-view of the fog lights only on:
The LED DRL (Daytime Running Lights) only:
And, just for kicks, both the fog and DRL on:
Beetlebaum Samba Member
Joined: December 04, 2008 Posts: 2180 Location: Virginia Beach, VA
baxsie Samba Member
Posted: Sun Mar 02, 2014 11:27 am Post subject: 1975 Super Beetle Rear Fenders Wider |
Beetlebaum wrote: |
Nice work! |
Thanks man. Always a boost to receive kind words
We got some silicon-bronze MIG welding wire. It is very interesting. Can't say it is better or worse than the steel wire at this point. Certainly different. It looks like a brazed seam, with lots of copper color. Here is steel weld sandwitched between the silicon-bronze beads, after rough grinding and bead blasting. Not sure if the warping is better or worse--we were getting "pretty good" at welding with the steel 0.023 MIG wire, but are back to being beginners at this 0.030 Silicon Bronze wire:
We continued with shortening the front part of the other rear fender. We mounted them to each other to make sure they matched--this also made them easier to handle and less floppy.
These look pretty rough. We will do more metal work to get them closer to where they need to be:
Mounted up agin to check for symmerty and some more hammer work:
We bead-blasted the welded and ground area to make sure the 2K epoxy primer could get a good bond, then shot the outside of the fenders. The idea here is that the 2K will give the filler a good grip, and will seal any small imperfections in the welds, keeping moisture from getting under the filler:
The uniform color of the 2K epoxy immedaitely makes it look better, although there is certainly evidence of the welds:
The first pass of body filler and rough sanding with 80 grit on the linear air sander shows the multiple high spots that we missed in the initial hammer work. We will tap those down and fill/sand/repeat:
In this shot the camera is lined up carefully with the front and rear outer edges of the fender, so we can see how far the wheel is tucked under the fender. Looks about right to me:
The seame kind of shot, but on the front fenders:
Maddel Samba Member
Posted: Sun Mar 02, 2014 10:11 pm Post subject: |
Posted: Mon Mar 03, 2014 9:30 am Post subject: |
I am with this guy. |
BugMan114 Samba Member
Joined: March 22, 2007 Posts: 3744 Location: Ellenwood, GA
Posted: Mon Mar 03, 2014 10:51 pm Post subject: |
Just finished reading all 15 pages of this thread. Man, you do VERY nice work. And forgive me if I steal some of your ideas . I believe you said you got those window actuators for your pop outs, from a mini-van. do you remember exactly what van it was? I'd love to do this, I just wish I didn't order all new latches and knobs for mine, lol.
And I was just trying to figure out where to mount my oil cooler. I have the exact same one as you, and now I know where I'm mounting it, XD. _________________ 1974 Super Beetle: Custom resto in progress
1972 Super Beetle: Daily Driver
1971 Std. Beetle w/ 1929 Mercedes Benz Gazelle kit
1960 Baja Bug
1969 Baja Bug
Sand Rail- Homemade
Sand Rail- FUBAR
Aircooled Airheads
Why the hell do they call it a gland nut. its obviously a big fat bolt!!! |
